Struts on lowered springs
    Results 1 to 6 of 6
      Apr 2016
      Pacific NW
      I have some bad wear on inner front tires due to lower control arms getting sloppy. I plan on putting in new struts as I'm in there.
      I see that Bilstein HD has a strut specific for lowered Volvos. But I do not really see other manufacturers doing that. So that got me thinking that probably most people just put standard struts in on lowered V70's. Anyone have long term success with any other brands and standard dimension struts on lowered cars? $250 each side is a bit pricey for a commuter car IMHO. Looking for a stiffer ride.
      2002 V70T5 - IPD Stage 1, H&R Lowering Springs
      Jun 2015
      SK, Canada
      Koni FSDs are another choice for lowered people, but are also pricey.
      I've been riding lowering springs on stock struts / shocks for 20,000km with no issue. I think I've heard it will wear them prematurely but YMMV.
      2001 V70 T5 | 400,000 KM | Vogtland springs + Enkei BR7, ARD tune @ 18psi, Snabb "Big" intercooler & piping, catless DP + Vibrant Ultra-Quiet + Magnaflow 5x8, do88 3" intake, Snabb TCV, Xemodex ETM
      2002 XC70 | 402,000 KM | Bone stock, winter beater
      Member McShake's Avatar
      Jun 2011
      Near Oslo, Norway
      I went for sport shocks when I lowered mine, I wanted a stiffer ride too, but plenty of people run lower springs on stock shocks without issue, depends on how much you lower it. In retrospect I think I'd stick with stock shocks, and I really recommend Eibachs Pro Kit, they're 30mm lower and considerably stiffer when you push it, but being progressive springs they're also really comfortable when you just want to calm things down. Friend of mine has it on stock shocks, great ride.
      That said, a stiffer ride will most likely mean more wear and tear, and you'll have more negative camber that needs to be dealt with.
      '07 V70 AWD D5/6spd auto - #becauseracediesel (link)
      '99 V70 AWD - B5254T, M58, Coral Red - sold, sadly
      Ray McShake @ Facebook & Instagram - ponchoadventure@snapchat(at your own risk)
      Follow @volvocarclubnorway on Instagram
      Apr 2016
      Pacific NW
      great advice. I'm really battling the "while it's open might as well replace everything" principal. I see that they sell a lot of kits for essentially all brand new strut components (seats, mounts, etc.). How can you tell if those other parts are going bad or is it just not worth it to guess, just replace all?
    7. #5
      Jun 2011
      Near Oslo, Norway
      Generally there's tells, and some things are so cheap you do it anyway. Spring seats and endlinks are the latter. Strut mounts should rotate freely without grinding or play. If you push down on one corner of the car, it should rebound and oscillate once more (up, down, up) and no more, or your shocks might be going. LCAs should be tight and without bushing play, and spring upward when pushed down and released, a little difficult without removing the strut.
      After one 850, one P80 V70 and my current V70 I am so sick and tired of working on McPherson setups I generally do more than one thing when I'm under there. Feels very good to have a nice and fresh front end too, and it''s so much more satisfying bolting clean and rust free parts together, than the alternative.
    8. #6
      Member wagonfan00's Avatar
      Jan 2015
      Long Island
      Coilovers or nothing if you're replacing everything...extra $200 give or take and full adjust-ability....might get some done before my weekend so I can do some auto cross....
      Current: 2002 V70 Base N/A M56 161k (Straight pipe, short shift kit) 1988 745T AW-71L 249k (BC coilovers, Hydras, eBay MBC @13psi, 2.5" Catless exhaust **for sale**)
      Past: 2008 Mini Cooper S Clubman R55 Getrag 6 Speed (Stock) 1997 855 T5 Auto 300k
      IG: psychocross_v70
    9. Remove Advertisements
