Got the IPD exhaust on
    Results 1 to 7 of 7
      Junior Member BellevilleV70's Avatar
      Mar 2006
      Belleville,Ontario
      Installed after work today, (thanks for the info TunedXC60!) The s60 exhaust fits perfect, don't know why they dont list as such. Anyway, I'll post some pics here, and a few of my pros and cons. I trimmed the bumper cover a touch with a dremel(30 sec a side......super easy) , you can see in the pics, the white part I trimmed. The OE tips are smaller, and this way bigger tips fit right up in. Note the pics are taken lookin up, u dont usually see the white part on the ground. The muffler also slides a fair bit left and right in the hangers, so I put a hose clamp and kept it to the right, as pipe is close to gas tank, and this will also keep tips from moving as much. Install took an hr, but I do this for a living too, i'm a dealer tech
      Pros: MUCH better sound,should have sounded this way stock, at least the Rdesign.... fits great, looks great with big tips. Quality hangers
      Cons: Pipe same size as stock, so I don't think its a great system for big power added with other mods.Lots of room, not sure why they stayed the same size. I also don't like design of resonator....If you look inside, its a flat wall where it goes to 1 pipe,and a quick step.... OE is straight through also, and there is a lot more space open before it transitions to the outlet. Knowing this now I would have Bought the system that started behind the resonator(viva I think?) Would be a MUCH better design if it had a nice smooth Y-pipe if front of resonator , then straight through. Muffler design looks great(pro I guess) Clamps aren't very good, they have no wedge where ends meet so it pinches the pipe a bit and u have a small leak, I'm going to source some good stainless ones. Also didn't come with a gasket, so had to grab one from dealer....I emailed IPD but never heard back. And lastly, there is a bit of drone/noise at 60-75 mph....surprised at this, considering its mellow sounding system( sounds SO good around town). I'm gonna try some sound deadening on the back end floor, was going to anyway, as I find road noise a little loud back there. Now this sounds like a long con list, but its not, just trying to carefully explain what I mean. I really don't like res. design though....may swap on OE at some time, I'm sure its better flow. Sorry, should have took some pics of the inside of both.
      02 V70 2.4T - EST exhaust/Elbrus 18x8s/Conti DW/Eibach/Koni FSD/Polk Audio/Boston Acoustics/Infinity ---- for sale
      13 XC60 T6R-Design-Ice White-IPD exhaust-Soon:do88 intercooler
      15 Chrysler 200c ---- Mopar Tech
      Mar 2006
      Belleville,Ontario
      Junior Member tunedxc60's Avatar
      Oct 2016
      USA
      Looks good! Nice idea on the hose clamps to keep the hanger from sliding on the rubber insulators. I didn't have the problem with the hangers sliding until I swapped the OEM insulators for the longer aftermarket ones. Also, the IPD exhaust is supposed to come with the replacement Volvo gasket.
      2016 XC60 T6 AWD Platinum/Inscription - Full bolt ons (Snabb air intake & turbo pipe, Do88 Intercooler, Viva Hybrid Turbo, Ferrita downpipe, IPD exhaust catback, H&R Springs), Stage 3 Hilton Tune: Dual JL Audio 10" stealth subs & 750Watt amp
      May 2014
      NYC
      Looks good. Any chance you can post some sound clips?
      i want to get the exhaust but as much as i would like the sound improvement, i would prefer to see gains for the the amount they are charging.
      2015 XC60 R-Design
      2005 G35 -modified
    7. #5
      Mar 2006
      Belleville,Ontario
      I didnt feel any gains
    8. #6
      Mar 2006
      Belleville,Ontario
      If your looking for gains, or further mods down the road, maybe look at some other than viva or ipd, as they are stock size piping, and IMO is on the small size for the power these are making. Should be a min. 3in for power and good thermal management above 350hp. I didnt look into other systems as other than an intercooler, I'm not doing anything else.
    9. #7
      Thanks for the idea with the hose clamp. Mine slides around a bit and now with the clamp it stays perfect!
      2015 V60 T6 AWD R-Design - Passion Red/Off Black, Platinum/Tech/Climate/BLIS/19" Ixion II, KN Filter, IPD Catback Exhaust, IPD Rear Swaybar {His}
      2016 XC60 T6 AWD - Osmium Grey/Off Black {Hers}
      FS Items: XC60 Cargo Cover
      SOLD:1994 940 Turbo/2004 S40 LSE/2007 S60R/2010 Mazda3 i-touring/2012 S60RD/2013 S60 T5AWD
    10. Remove Advertisements
