S60 d5 auto 2002 vibrates when accelerating
    Results 1 to 12 of 12
      Hi.
      i have a problem with my s60. when i are out driving and go 35mph and above my car is vibrating like hell when im accelerating.
      as soon as i let go of the throttle it stops. usally it stops when im driving downhill to.
      it is almost none vibration in the steering wheel.
      the wheels are brand new and balanced.
      anyone got any idea?
      the car is vibrating so mutch and i am afraid it is going to fall apart XD
      but as i said the steering wheel have almost none vibration.
      i am going to take the car to a garage in a week or 2 but would be great to maby figure it out before i use tons of money at the shop.
      expencive in norway XD
      Apr 2017
      L a s V e g a s
      My 05 S60 does some mild shaking between 30-45 mph when I floor it. I'm not sure what causes it but I'm curious to know what people suggest for you to check, I'll be piggy backing the advice lll
      _____________________________________
      A Swede living in Las Vegas Nv
      {} 2015 S60 T5 Premier
      {} 2005 S60 Premier
      {} 1997 960
      -Below are Volvos in the family-
      {} 2013 S60 T5 Platinum
      {} 1997 850 R
      It's an 02 scrap it
      Apr 2015
      So Cal / Inland Empire
      Sounds very much like an axle/drive shaft that needs to be replaced. Not very expensive if you're able to buy a new one and replace it yourself. You have to identify if it's the right or left one first however. Don't scrap the car off that's the only issue with it.
      Sent from my HTC One_M8 using Tapatalk
      2004 S60 2.5T - Stock for now...
    7. #5
      Quote Originally Posted by Bryce Anderson View Post
      It's an 02 scrap it
      Some of us likes the older cars. And this one is in really good condition other then the vibrating. No rust at all..
      Sent fra min E6853 via Tapatalk
    8. #6
      Quote Originally Posted by Phixion View Post
      It is almost no vibration in the steering wheel. Is that possible if it is the axel/driveshaft?
    9. #7
      Apr 2015
      Yes that is possible if it's not too severe. Generally vibration under acceleration only is an axle issue. If not much steering wheel vibration, then it could be bad motor mounts or torque mounts that connect to the transmission. Also possible to be bad exhaust mounts or if the exhaust is touching anything, but that I'd think you'd feel at idle too, same with motor mounts.
    10. #8
      Junior Member Mario2hr's Avatar
      Apr 2015
      Zagreb/Croatia
      It is halfshafts for sure. I`ve had same problem some time ago. When accelerating it was shaking insane. I changed halfshafts and since then it was ok. It is one of main problems with automatic S60 from 2002-2010.
      VW Golf II - 1995-2000
      Audi 80 B4 - 2000-2003
      Suzuki Swift GTi - 2003-2008
      Audi A6 C4 - 2008-2014
      Volvo S60 D5 - 2014 and continue
    11. #9
      Quote Originally Posted by morpheusbd View Post
      No haha I own an 02 it's got the ****ty trans though also I've gone through three axles in the last 6 months
    12. #10
      think i found the problem today.. this video is of the right driveshaft
      https://www.youtube.com/watch?v=w-NOY3qAspc
    13. #11
      Apr 2015
      Zagreb/Croatia
      Anyone know diference between AT and manual halfshafts?
    14. #12
      Jul 2010
      Ontario, Canada
      Quote Originally Posted by Mario2hr View Post
      Inner seal surface diameter is different, I believe. Manual axle will physically fit but won't seal the transmission and you'll leak transmission fluid.
    15. Remove Advertisements
