Thermostat Housing leak (middle gasket) Need bolt torque . . .
    Results 1 to 9 of 9
      Apr 2006
      CA
      My thermostat has a slight leak at the middle of the thermostat housing
      There are two bolts and a gasket
      Going to use some permatex and re seal it
      What is the torque for the two bolts ?
      Member
      Nov 2013
      Louisville, Ky
      I would just get a new thermostat and housing man.
      04 S60R, M66, Titanium, Nordcap, Sport Kit, NAV, Pioneer Double Din, Hilton Stage 3 Tune, Viva Hybrid Turbo, Snow Performance Stage 3 Methanol Injection, Five O Motorsports 750cc Injectors, Aeromotive Fuel Pump, Audi RS4 MAF, IPD catback, OBX Catless DP- custome electric dump welded in, Custom FMIC with Sabb piping, Snabb Intake, Forge CBV, iPd OTE, Silicone Rad Hoses, BC Coilovers, iPd/ Elevate Sway Bars, Etc... Just ask
      Apr 2006
      CA
      Quote Originally Posted by adsinnott1 View Post
      A new housing isn't needed:
      http://forums.swedespeed.com/showthr...mostat+housing
      Easy fix
      Just want to know the torque for the bolts
    5. #4
      Oct 2016
      Victoria BC Canada
      just make them tight. if it leaks, tighter.
      I did the same thing, split the housing, resealed with permatex, no issues and no need to spend the money for a whole new housing
      | 04 V70R Titanium Grey/Nordkap M66 | Mototec DP & Touring Exhaust | ERST Springs | 18" Pegs |
    6. #5
      Member BaxtR's Avatar
      May 2014
      Tampa,FL
      yea i rtved it as well and i put them tight but no torque wrench lol everything been cool since
      2007 S60R Nordkap & Black Sapphire Metallic. Auto. Holset HY35, 2.3 Block shimmed, Forged pistons, H-Beam Rods. 3" DP, Meth Inj.
    7. #6
      If it's old enough to leak, it probably warrants replacement...
      To each their own. I'm not 100% sure, but I think those bolts are M7. Generic torque for M7 threads as per volvo should be 17 nm.
    8. #7
      Apr 2006
      CA
      Quote Originally Posted by Enraged View Post
      Quote Originally Posted by BaxtR View Post
      Did you guys take the whole housing out . . . or just separate it leaving the lower half attached to the block?
      I don't have a tool for the small tube with the oetiker clamp . . .
      May have to separate the housing and work on it with the tube attached in the confined space
      You guys do it this way?
    9. #8
      Oct 2016
      Victoria BC Canada
      Left the lower housing in the car, left the hose clamped to the upper housing
      Also, replaced the bolts holding the halves together with hex bolts.
    10. #9
      May 2014
      Tampa,FL
      cut the clamp off, used a hose clamp, left the other half on the block.
    11. Remove Advertisements
