Has anyone done the 90c SAS "fix"?
    Results 1 to 14 of 14
      Senior Member JRL's Avatar
      Apr 2003
      Devon PA
      If so, is this https://www.matthewsvolvosite.com/fo...ic.php?t=58391 correct and does it really work?
      Thanks
      Email: jrl1194(at)aol.com
      If the subject is car purchase related please use jrl1194(at)gmail.com
      2007 V70 2.5T White/Oak 108K miles, new daily driver
      2000 V70R wife's. Won't sell, now near 141,000 miles and still near perfect!
      2000 S70 GLT SE 30,005 MILES, A time capsule! JUST SOLD.
      Member T501's Avatar
      Mar 2005
      Florida
      Quote Originally Posted by JRL View Post
      Thanks
      It sure does! Just solder the diode onto the ECM and say goodbye to the SAS DTC and the SAS system itself. I did it to my Dad's S70 about 4 years ago.
      David - '01 S60 T5 GT 178K+ miles OWNED SINCE DAY ONE - Bilstein Sport + TME, ipd sway bar + endlinks, UR chassis braces (upper F+R), Powerslot /Akebono pads, Snabb Intake, HD coils, iMIV Original engine, transmission replaced at 79k miles
      Wife -'13 C30 T5 R-Design Dad - '98 S70 T5 160K + miles, Bilstein TCs, IPD HD rear springs, SAS delete Mom -'10 S80 V8 Executive Sis - '02 S80 T6 Backup car -'13 S60 T5
      Junior Member Saffron-R's Avatar
      Aug 2008
      Portland, Oregon
      Jim, that method described on that MVS link is correct and it does work. As for finding a Radio Shack that hasn't been boarded up and closed is another story!
      I kind of can't believe you've not done this before, given all the vehicles you've owned and the fragility/ expense of repairing SAS system.
      1998 V70R, M58 AWD Manual, B5244T5, 4T4 turbo, Beüst COP, DW300 fuel pump, DW 650cc injectors, ipd diverter, ipd intercooler, DO88 RIP, turbo inlet, and aluminum radiator, Audi A8 3" MAF housing, R manifold, 3" CJ downpipe, Magnaflow dual exhaust, Kaplhenke dbl adjustable front&rear coilovers, ipd sways/strut brace, Porsche BBK front, rear '00 VR vented rotors/calipers, Heico Volution X's, '04 Jewels.
      Member b2fkb0's Avatar
      Oct 2010
      Kalamazoo, MI
      Yep did it on my 98v70r.
      00 V70R Emerald, 98 v70R saffron, 98 v70r black, 04 v70xc nautic, , 06 xc90 v8 gunmetal, 83 242 Group A med blue metallic, 82 242 DL, 2006 s40 t5a, s40t5m awd RED, s40t5m awd Black, 04 s60r silver.
      Sold-98V70Rm silver, 93 245 silver, 98v70xc sandstone, 96 855r black totaled/parted, 96 855r white, 98 xc70 olive, 99 s70r, 05 s40 t5m (x2) silver, 94 854 na turquoise:
    7. #5
      Member
      Aug 2008
      Scottsdale, AZ
      Helped installing this for Washdup, worked just fine.
      '98 V70 T5 (Auto) Currently 427,000 miles on car, now my daughter's.
      '99 V70 T5 M Purchased from JRL: 207,000 miles. future mods coming
      2013 S60 T6 Rdesign Mine
      2016 XC60 T6 Rdesign Wife's
    8. #6
      Apr 2003
      Devon PA
      Quote Originally Posted by Saffron-R View Post
      When I was dealing with the FEW 98s I bought and sold, I think I may have had to replace one (1) pump. This fix was not known but I found a good used one back then at a very good price.
      As for R/Shack, the one near me is open, but unless it's in stock, I'm SOL. They will not order any parts until the Chapter 11 is dealt with.
      I suppose that diode must be available somewhere.....
    9. #7
      Apr 2003
      Devon PA
      EDIT and answer.
      On sale from RS on line TWO for .78c !!!!! and available
    10. #8
    11. #9
      Apr 2003
      Devon PA
      What does a diode do?
    12. #10
      Global Moderator R-Pow3R3d's Avatar
      Apr 2015
      Pittsburgh, PA
      Blocks current flow in one direction, but allows it in the other.
      2004 Volvo V70R MT TiGray/Nordkap - Replica 18" Pegs - Handbrake Mod
      2006 Volvo S60R GT TiGray/Gobi - '06-'07 Transmission Valve Body Info
      2007 Volvo XC90 V8 Sport Passion Red/Off-Black - Serpentine Belt, Tensioner & Idler Pulleys - Spark Plug Replacement
      VIDA/DICE Owner - SS Lurker Since 2009
    13. #11
      Apr 2003
      Devon PA
      Thanks
      Learn something every day
    14. #12
      Yes, I did it to my 98. Modifying the vehicle harness side with the diode is best in cases where you wish to swap ECUs.
      -Paul
      '98 V70 T5M, M56H, Signal Red(601)/Light Beige(3960); IPD susp, ARD Green tune
      SOLD '98 S70 T5M
    15. #13
      eBay
      -Paul
      SOLD '98 S70 T5M
    16. #14
      Apr 2003
      Devon PA
      Ordered the diode.
      $7.00 for a 78c. part (shipping) *&^$(#$^&*(#
      All still existing Radio Shacks around here do not have any.
      I priced out a new air pump, haven't bought one in over 11 years.
      I almost fell out of my chair!!
      Now over $500 WHOLESALE for both parts and the gasket so I guess we will be doing the mod.
      Oh, does anyone remember the correct wire numbers? There seems to be a difference which number wire is the right one 32 or 33?
    17. Remove Advertisements
