More 98 T5M questions
    Results 1 to 15 of 15
      Senior Member JRL's Avatar
      Apr 2003
      Devon PA
      I also need a new lower dog leg (tranny) mount.
      Different than the mounts for an automatic
      Not made anymore, what are my choices (if anyone knows)?
      For those that have installed poly bushings, how much vibration is there in a manual T5M if all other mounts are stock rubber.
      Thanks
      Email: jrl1194(at)aol.com
      If the subject is car purchase related please use jrl1194(at)gmail.com
      2007 V70 2.5T White/Oak 108K miles, new daily driver
      2000 V70R wife's. Won't sell, now near 141,000 miles and still near perfect!
      2000 S70 GLT SE 30,005 MILES, A time capsule! JUST SOLD.
      I have a 98 T5M and I'll check the lower mount. I don't remember it being different when I did my '95 swap. It may not be until later today or tomorrow.
      New website >>> http://www.yother.com
      Member ScottishBrick's Avatar
      They're the same. I've used p2 mounts on the p80s several times. The torque mount that is. The only specific mount is the passenger lower engine mount and those are still available for t5m
      1999 V70 T5 - Emerald/Graphite M56H - 119k - The Garage Queen
      1999 V70 T5 - Pewter/Graphite AW42 - 241k - The Daily
      1995 945 Turbo - 425k, 1994 945 Turbo - 234k, 1993 945 Turbo - 318k
      Apr 2003
      Devon PA
      I said LOWER rear, the dog bone mount, it is different.
      Never said anything about P2s.
      The P/N's are different and they're NOT available anymore
      Aug 2008
      Scottsdale, AZ
      Jim, do you have a pic of the part you're talking about to avoid confusion?
      '98 V70 T5 (Auto) Currently 427,000 miles on car, now my daughter's.
      '99 V70 T5 M Purchased from JRL: 207,000 miles. future mods coming
      2013 S60 T6 Rdesign Mine
      2016 XC60 T6 Rdesign Wife's
      I have ipd upper eng mount, ipd firewall mount, and ipd trans mount on my orig 98 t5m and zero vibration at idle or cruise. I also have Volvo front engine mount and 200K mi left and right hyd mounts which I've considering replacing but why at this point.
      Note: I also have everything new in front and rear suspension exc the trailing arm end links, new steering inner/outer ties, new oem brakes, straightened wheels, perfect four wheel alignment, correctly adjusted ebrake, rear ipd sway bar, ipd springs, upper strut mount tie bar, and good tires.
      -Paul
      '98 V70 T5M, M56H, Signal Red(601)/Light Beige(3960); IPD susp, ARD Green tune
      SOLD '98 S70 T5M
      Member LloydDobler's Avatar
      Aug 2007
      Littleton, CO
      I have poly upper and lower mounts on my C70 manual and it is tighter and more vibey under acceleration but at idle and cruise not noticeable. When it was automatic and stopped in gear it was terrible. Put it in neutral and it was fine, but loaded it vibrated the whole car.
      2003 C70 T5M Convertible - Eibachs, Koni FSDs, Enkei RSF5s, OBX downpipe, Snabb intake, RIP kit, & drop-in intercooler, Quaife LSD, 19T, Green Giants, 22 psi Hilton tune.
      2006 V70R M66 - Sonic Blue/Nordkap, 2.4 T5 motor, Pure Turbos Hybrid, Snabb intake & intercooler, IPD oval exhaust, JZW tune.
      1966 122s - Collectible project, restoration and many mods on the way.
      Member JaredR's Avatar
      Jan 2014
      Boston, MA
      ^what Lloyd said. My T-5R came with poly torque mounts and I just shift it into neutral at lights. It is just awful if you don't; takes me right back to my days growing up in the back seat of the American econoboxes we had when I was little.
      Apr 2003
      Devon PA
      This is not for ME. It's a customer car
      Quote Originally Posted by JRL View Post
      The PN's have been changed and super ceded many times.
      https://www.volvopartscounter.com/oe...-strut-9141042
      https://www.ipdusa.com/products/5824...n-torque-mount
      https://www.eeuroparts.com/Parts/835...Soft-30680750/
      If this is the mount youre talking about please clarify.
      Apr 2003
      Devon PA
      Thanks and yes!
      They are the same for either application, automatic or manual transmission.
      Just because the part #'s are different, doesn't necessarily mean they are different. This goes for all manufacturers, not just Volvo. Often times, different part numbers, different prices, same part.
      Apr 2003
      Devon PA
      I know.
      That P/N that ipd shows for a manual is for automatics, so I have to assume it will work.
      That one I have here, so when we do the clutch next week is when I'll find out.
      Why T/F would Volvo list the manual mount being discontinued if it's the same?
      I (and the parts dept) would really love to know. (I'm being nice here) *(&^#*$^#&*
      I know.
      Probably because its not EXACTLY the same. There used to be two versions: oe hard and oe soft. Also remember that when volvo was owned by ford a good part of the old catologue part numbers got axed and replaced and then listed as discontinued. Its a mystery to me as well but thats the story i got from my preferred volvo parts guys when we were trying to figure out late 00 XC motor mounts versus R (302 brakes and my S70's T5 engine in the xc now) for 00.
      Junior Member Saffron-R's Avatar
      Aug 2008
      Portland, Oregon
      I know.
      The P80 AWD "dog bone" transmission torque mount is NLA and has been for a few years (sigh). The FWD mount will work with either Auto or Manual transmission.
      Jim, glad you're still surly as ever.
      1998 V70R, M58 AWD Manual, B5244T5, 4T4 turbo, Beüst COP, DW300 fuel pump, DW 650cc injectors, ipd diverter, ipd intercooler, DO88 RIP, turbo inlet, and aluminum radiator, Audi A8 3" MAF housing, R manifold, 3" CJ downpipe, Magnaflow dual exhaust, Kaplhenke dbl adjustable front&rear coilovers, ipd sways/strut brace, Porsche BBK front, rear '00 VR vented rotors/calipers, Heico Volution X's, '04 Jewels.
    18. Remove Advertisements
