Fairly lame answer, as I haven't managed to research a source for the genuine articles...Any Ace or True Value hardware store (and probably others) will have a large selection of grommets in the nuts and bolts aisle. You should certainly be able to find ones that would work well for most locations. The exception is the large grommet where the choke cables go through the firewall, which is a non-generic design.
I'd use some closed-cell foam rubber (doesn't soak up water) for the steering shaft hole. There's a bent wire retaining clip that attaches by a single sheet metal screw above the column -- if you're missing that, it's easy enough to make one up.
