Cure for Volvo's pitiful iPod capability (and non-existent XM radio) - Page 3
    Page 3 of 3 FirstFirst 1 2 3
    Results 71 to 84 of 84
    1. #71
      Re: (pattyweb)
      very helpful diagram. Are the extra speakers connected to RR/LR for the cargo area speakers or is there a pair of speakers in each rear door like on the front doors?
      Patty thankyou for the diagram. Using Molex connections to keep it OEM is a great idea.Where did you order your molex plugs? You also order the tool? Thanks
    4. #73
      Member
      Jan 2005
      Central Florida
      Re: (midospike)
      I had ordered parts and connectors from Mousers. You can request a free catalog from them. It's very big. I already have various crimp tools. I think I got some of the ones on their online page 1151 (Molex Mini-Fit Jr). Radio Shack sells some but I don't like them. Big, bulky, loose fitting, etc.
      I just cut the volvo speaker wire cables and then added my own male/female connectors inline. Then I tested the factory system still worked.
      06 XC90 V8
      98 V70 T5M
      Nov 2006
      Tampa, FL
      Re: (avolvofan)
      avolvofan: I installed the AVIC-Z1 in my XC90 today, and I am getting all kinds of interference through the speakers. this happens when the car is running or not (even worse when it is running). Did this happen when CC installed your unit? How did they attenuate the noise? I have totally isolated the original radio equipment from the aftermarket system. I have chased every lead, isolated every ground, nothing works. I will try a noise suppressor in-line at the battery lead.
    7. #75
      Re: (aubieron)
      aubieron - Did you get that interference worked out? How did the install go? Any tips for me? I'm going to attempt an install in a few days.
      pattyweb - Did you get a molex connector that plugs directly into the wiring harness connected to the factory amp? I'd like to make a connector that plugs/plays without cutting any factory wiring.
      Thanks in advance.
    8. #76
      Member
      Jan 2005
      Central Florida
      Re: (carlog)
      Quote, originally posted by carlog »
      I could not find factory connectors. Even if I had, then I would of needed to reconnect all the other wires in the connector. If you really want factory connectors, I guess you could research the motorola bluetooth module. I read that it comes with a harness that plugs into the factory amp and then the factory plug plugs into the harness.
      Instead I just bought some basic 10 pin mini molex connectors from http://www.mouser.com/. I then cut the 10 gray speaker wires and reconnected them to my connectors. I then made sure all the factory stuff still worked. The new speaker wires from my new amp end with a connector and I just swapped the plug from the OEM amp to my amp.
      06 XC90 V8
      98 V70 T5M
    9. #77
      Re: (pattyweb)
      Thanks for the quick reply.
      Did you have a center channel speaker? How did you connect/wire it?
      I saw the bluetooth harness from Volvo, and it is about $70-80 + shipping. That's pretty crazy for a wiring harness, but I believe it is designed to switch between one audio source (bluetooth phone) and another (factory CD/radio), so maybe there are some built in relays that come with it.
      I'm surprised (sort of) that the connector is not something you can readily match somewhere.
    10. #78
      I did some looking around behind the factory radio today. I see that there are 2 fiber optic cables that connect to the display module, and 2 fiber optic cables that connect to the CD changer. I've heard that I will need to leave the display module connected in the car to keep the climate control features working, but what about the connectors to the CD changer? I'm also worried about tripping the airbag light if I do not reconned anything fiber optic.
      Thanks for any info.
    11. #79
      did anyone get the steering wheel controls to work with an aftermarket stereo?
      I am on the verge of replacing my factory unit with a double din and would love to be able to control the stereo through the existing controls.
    12. #80
      Still haven't tried it yet. The declining value of the US dollar has made those units very expensive! I think it's up to $300+ now.
    13. #81
      Re: Cure for Volvo's pitiful iPod capability (avolvofan)
      I know that this thread's been dormant for over a year now, but I've just now stumbled upon it, even though I've been planning and researching the topic for over a year now. With the help of this and other threads, I now have a good idea as to what it's going to take!
      But one thing I've never seen mentioned are the OEM headphone jacks. I assume these are attached to the network via fiber as well? And if I replace the factory radio, will I just have to do without the headphone jacks?
      Thanks!
      2004 XC90 2.5T, 155K miles
    14. #82
      Apr 2011
      LA California
      software update?
      Did anyone have to have a software update when making the transition from factory to aftermarket stereo
      system. I had an aftermarket stereo installed and half of my electronics went out in the car. Did a little
      research and found out Volvo should do a software update to tell the cars computer to stop looking for the
      factory stereo. If not the computer gets an error message when it does not locate the factory stereo and
      then the computer starts causing other electronic problems. I called several Volvo dealerships and talked
      to the service departments and some of them were even unaware of this problem and the software update
      to correct it. Any thoughts about wether I should do the update or not?
    15. #83
      Member
      Jan 2005
      Central Florida
      Quote Originally Posted by joelq View Post
      Thanks!
      We have an aftermarket unit in our XC90 and the rear headphone jacks still work.
      06 XC90 V8
      98 V70 T5M
    16. #84
      Member
      Jan 2005
      Central Florida
      Quote Originally Posted by SgtO View Post
      system.
      I didn't
      Sounds like you completely removed the OEM stereo and/or left the fiber cables for the OEM cd changer dangling. You can't do that. The display of the OEM radio needs to stay plugged into the car. You can disassemble the OEM radio, unplug the two side button clusters, remove and bypass the OEM cd changer (but make sure to connect the two fiber optic cables together with some kind of splice, I think I remember I just shoved both ends into wire bullet connector). In the end, you're left with just a small little box that contains the OEM display. I just wrapped mine in foam and tucked it down underneath everything.
      For other tips, here's my afternarket thread: http://forums.swedespeed.com/showthread.php?61169
      06 XC90 V8
      98 V70 T5M
    17. Remove Advertisements
