+ Reply to Thread
Results 1 to 34 of 34
Thread: Advise me a BlowOff please
  1. 09-26-2006 04:48 PM #1
    Not sure lots of you like it but I will install,can you advise me a blowoff?
  2. 09-26-2006 05:03 PM #2
    I would advise a diverter valve instead. A blow off with trigger a CEL.
  3. 09-26-2006 05:13 PM #3
    Greddy Type S....if you can find one, they are no longer made.....sounds like wind-chimes when it blows off....
    Here's a link so you can hear it...
    http://videos.streetfire.net/s...1.htm
  4. 09-26-2006 06:22 PM #4
    the one that sounds like a whistle? it would be ricey
  5. Senior Member phuz's Avatar
    Jan 2005
    Reading, PA
    09-26-2006 07:08 PM #5
    Quote, originally posted by R_Rated »
    if you want a BOV, you will need one that remains closed at idle, or like josh said, you will throw CEL's all day long.
    Matt
    http://www.phuzzymotorsports.com
    2006 Volvo S60R - 6MT: FMIC, DP, Autotech Tune
    1993 S13 - 2JZGTE, Single PT6262 Billet Turbo, Haltech PS2000 Standalone, 1000cc Precision Injectors, Methanol Injection, 4" FMIC
  6. 09-26-2006 07:53 PM #6
    Can you explain the diverter valve? Does it still make a sound?
  7. Senior Member phuz's Avatar
    Jan 2005
    Reading, PA
    09-26-2006 08:06 PM #7
    Quote, originally posted by oliverbe »
    just like your stock one does...maybe louder.
    Matt
  8. 09-26-2006 09:29 PM #8
    I think it really is up to you, cause all BOV does the same thing... You should just pick 1 that you think looks the best.
    Or maybe 1 that matches the engine bay better.
    I've used Greddy, Apexi, HKS, Blitz, all sound different, and the sound will change depending on the pound you set. And to make adjusting "sound" difficult, it sounds different for different cars with different mods.
    I had a Apexi on my FC3S RX7 and my friend has the same BOV on his Eclipse GSX, we set it at the same pound but when it releases, the 2 car sounds drastically different...
    So My suggestion would be just pick 1 that you think looks the best!
    Good luck!
  9. 09-27-2006 02:39 AM #9
    Quote, originally posted by phuz »
    unless you use a blanking plate where the original CBV was, correct?
  10. 09-27-2006 02:43 AM #10
    most people like the HKS SSQV, but it also "whistles" and i think it sounds ricey.
    i, personally like the tial BOV, and if i decide to install a BOV, that's what i'd go with. sounds really nice.
    http://www.maxpowertuning.com/tialbovsound.WMV
  11. 09-27-2006 09:47 AM #11
    Are Blowoffs harmful for volvo's, doesn't it? I heard something like this before on this forum.
  12. Senior Member phuz's Avatar
    Jan 2005
    Reading, PA
    09-27-2006 09:51 AM #12
    Quote, originally posted by Selman »
    if its the kind that remains open at idle, it will suck in un-metered air and cause the ECU to throw a CEL.
    Matt
  13. 09-27-2006 09:56 AM #13
    Quote, originally posted by Cicada »
    Which ones close at idle then?
  14. Senior Member phuz's Avatar
    Jan 2005
    Reading, PA
    09-27-2006 09:59 AM #14
    Quote, originally posted by xenophobic »
    when i had a turboxs type-h, it remained closed at idle.
    i believe its the dual-piston type.
    just do a google search regarding blow off valves and MAF sensors.
    Matt
  15. 09-27-2006 10:01 AM #15
    Any "piston" type BOV's stay closed at idle...HKS SSQV, TIAL, Synapse......Diaphram ones tend to leak or "blow open" under high boost. They do have an adjustment nut and spring to take care of that, but then it makes you wonder if you have it tightened too much and if it's fully opening when you let off the gas.
  16. Senior Member phuz's Avatar
    Jan 2005
    Reading, PA
    09-27-2006 10:07 AM #16
    Quote, originally posted by s60rdood »
    exactly.
    a piston type will keep the same amount of boost on the "charge" side of the BOV as the piston side, keeping the whole thing in equilibrium, so you can run 50psi, and it sees it on both sides so it doesn't budge, but as soon as you let off the gas, you have high-vacuum on the piston side and high boost on the charge side, and it forces the piston open.
    Matt
  17. 09-27-2006 10:11 AM #17
    exactly.
    It is easy to find HKS here and I will try that.
    If the car throw CEL,any damage and etc,send the bill to you!
  18. Senior Member phuz's Avatar
    Jan 2005
    Reading, PA
    09-27-2006 10:30 AM #18
    i will PM you my address. rofl.
    Matt
  19. 09-28-2006 04:43 AM #19
    i'm going with the TIAL..at the end of all my other mods, of course. woudlnt want my car to simply 'sound fast'.
  20. 09-28-2006 05:27 AM #20
    Thanks
  21. 09-28-2006 07:10 AM #21
    http://www.wotm.com/tialbovs.html
    I will order one of these,is this the right one?
    Or this can be too or not?
    http://www.2kracing.com/produc.../4849
    Thanks.
  22. 09-28-2006 07:25 AM #22
  23. 09-28-2006 07:39 AM #24
    R_Rated,is this a BOV?Seems like something different...
  24. Senior Member phuz's Avatar
    Jan 2005
    Reading, PA
    09-28-2006 08:17 AM #25
    its just an aftermarket recirc valve. similar to the stock one, but MUCH nicer.
    Matt
  25. 09-28-2006 08:21 AM #26
    The "technical" term is diverter valve and some refer to it as a "compressor bypass valve".... either way, it acts as a BOV only recirculates the air back through the system.
  26. Senior Member phuz's Avatar
    Jan 2005
    Reading, PA
    09-28-2006 08:30 AM #27
    josh, is yours any louder than the stock "diverter" ?
    Matt
  27. 09-28-2006 08:41 AM #28
    that is not a fair question.... all bets are off with the different turbo. This one almost sounds like a flutter BOV. It is quieter than the standard Bosch unit. It is the least abrassive one i could find. The thing I like the most and reason I bought it is that this one metal and not plastic, has a piston instead of a spring and is VERY quick and percise. It is alittle more than most but when the best is only 20 bucks more than the average it is a no brainer.
  28. Senior Member phuz's Avatar
    Jan 2005
    Reading, PA
    09-28-2006 08:48 AM #29
    didn't know if you had ever compared the two. the turbo itself isn't going to change the sound of the BOV (or diverter)...its the amount of boost pressure once it opens. i assume one like yours would sound somewhat louder vs. the stock model.
    Matt
  29. 09-28-2006 09:04 AM #30
    then yeah it is louder than stock but I am running much higher boost levels. and a completely different turbo and not just a bigger version of the stock one.
  30. 09-28-2006 06:56 PM #31
    Can that be used with a BOV together?
  31. Senior Member phuz's Avatar
    Jan 2005
    Reading, PA
    09-28-2006 07:43 PM #32
    you could, but if they are in two separate locations, you are going to get some weird air-flow patterns in the chargepipe and possibly defeat the purpose of a BOV in the first place.
    Matt
  32. 09-28-2006 09:59 PM #33
    So, what are the advantages of a aftermarket BOV or diverter? Sound? Response time?
    Fill me in. I'm all for mods.
    regards,
    MAJ
  33. Senior Member phuz's Avatar
    Jan 2005
    Reading, PA
    09-28-2006 10:31 PM #34
    Quote, originally posted by digital_dreamer »
    regards,
    MAJ
    i haven't truly researched any numbers behind BOVs and diverter valves, but sound is the most popular reason for adding/replacing one. i would also guess that some of them have a quicker reaction time as well as capability to discharge more air than others, and therefore taking that backpressure off the impeller.
    Matt
+ Reply to Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
