Check Engine code PO193
    Results 1 to 4 of 4
      As stated above, I need to know where I can find what this code means. Last thing i need is to go in and them tell new its b/c my down pipe or something.
      I did the search as "PO193" "code PO193" "code P" nothing!
      Re: Check Engine code PO193 (ilalocal1922)
      i think i found my own question. Its from a Ford Focus forum but most should be the same.
      PO102---- Mass airflow (MAF) Sensor circuit low input
      PO103---- Mass airflow (MAF) Sensor circuit high input
      PO106---- Barometric pressure sensor circuit performance
      PO107---- Barometric pressure sensor circuit low voltage
      PO108---- Barometric pressure sensor circuit high voltage
      PO109---- Barometric pressure sensor circuit intermittent
      PO112---- Intake air tempature (AIT) sensor circuit low input
      PO113---- Intake air tempature (AIT) sensor circuit high input
      PO117---- Electronic coolant tempature (ECT) sensor circuit low input
      PO118---- Electronic coolant tempature (ECT) sensor circuit high input
      PO121---- In range Throttle posistion sensor (TPS) fault
      PO122---- In range Throttle posistion sensor (TPS) circuit low input
      PO123---- In range Throttle posistion sensor (TPS) circuit high input
      PO125---- Insufficiant Coolant Tempature
      PO127---- Intake air tempature sensor "A" circuit
      PO131---- Upstream heated O2 sensor low voltage (Bank 1)
      PO133---- Upstream heated O2 sensor circuit slow response (Bank 1)
      PO135---- Upstream heated O2 sensor heater circuit fault (Bank 1)
      PO136---- Downstream heated O2 sensor fault (Bank 1)
      PO141---- Downstream heated O2 sensor heater circuit fault (Bank 1)
      PO151---- Upstream heated O2 sensor low voltage (Bank 2)
      PO153---- Upstream heated O2 sensor slow response (Bank 2)
      PO155---- Upstream heated O2 sensor heater circuit fault (Bank 2)
      PO156---- Downstream heated O2 sensor fault (Bank 2)
      PO161---- Downstream heated O2 sensor heater circuit fault (Bank 2)
      PO171---- System adaptive fuel too lean (Bank 1)
      PO172---- System adaptive fuel too rich (Bank 1)
      PO174---- System adaptive fuel too lean (Bank 2)
      PO175---- System adaptive fuel too rich (Bank 2)
      PO176---- Flexable fuel sensor "A" circuit
      PO181---- Enginefuel tempature sensor "A" circuit range
      PO182---- Enginefuel tempature sensor "A" circuit low input
      PO183---- Engine fuel tempature sensor "A" circuit high input
      PO186---- Engine fuel tempature sensor "B" circuit range
      PO187---- Engine fuel tempature sensor "B" circuit low input
      PO188---- Engine fuel tempature sensor "B" circuit high input
      PO190---- Fuel rail pressure sensor circuit performance
      PO191---- Injector pressure sensor system performance
      PO192---- Injector pressure sensor low input
      PO193---- Injector pressure sensor high input
      PO300---- Random misfire
      PO301---- Cylinder #1 misfire detected
      PO302---- Cylinder #2 misfire detected
      PO303---- Cylinder #3 misfire detected
      PO304---- Cylinder #4 misfire detected
      PO320---- Ignition engine speed input circuit performance
      PO325---- Knock sensor circuit fault
      PO326---- Knock sensor circuit performance
      PO330---- Knock sensor 2 circuit malfunction
      PO331---- Knock sensor 2 range
      PO340---- Camshaft position sensor circuit malfunction
      PO350----Ignitioncoil primary/secondary circuit malfunction
      PO351---- Ignitioncoil #1 primary circuit fault
      PO352---- Ignitioncoil #2 primary circuit fault
      PO353---- Ignitioncoil #3 primary circuit fault
      PO354---- Ignitioncoil #4 primary circuit fault
      PO400---- EGR flow vault
      PO401---- EGR insufficient flow detected
      PO402---- EGR excessive flow detected
      PO411---- Secondary air injection system upstream flow
      PO412---- Secondary air injection system circuit malfunction
      PO420---- Catalyst system efficiency below threshold (Bank 1)
      PO421---- Catalyst system efficiency below threshold (Bank 1)
      PO430---- Catalyst system efficiency below threshold (Bank 2)
      PO431---- Catalyst system efficiency below threshold (Bank 2)
      PO442---- EVAP Small leak detected
      PO443---- EVAP VMV circuit fault
      PO451---- FTP sensor circuit noisy
      PO452---- EVAP fuel tank pressure low input
      PO453---- EVAP fuel tank pressure high input
      PO455---- EVAP control system leak detected, very small leak
      PO457---- EVAP control system leak detected, fuel filler cap loose/off
      PO460---- Fuel level sensor circuit malfunction
      PO500---- VSS Malfunction
      PO501---- VSS range
      PO502---- VSS intermittent
      PO505---- IAC valve system fault
      PO552---- Power steering sensor circuit malfunction
      PO553---- Power steering sensor circuit malfunction
      PO602---- Control module programing error
      PO603---- PCM keep alive memory test error
      PO605---- PCM read only memory test error
      PO703---- Brake switch circuit input malfunction
      PO720---- Out put shaft speed sensor, insufficient input
      hmmmm now that's a coincidence!
      Yes, P0193 is Fuel Pressure Sensor Signal Value High (or some such verbiage). It means the ECM picked up the signal from the fuel rail pressure sensor as being at its highest possible voltage (or near) – which it shouldn’t under normal conditions (allows the ECM to diagnose a bad sensor).
      I was driving along last week and had my check engine light pop on - had the same code. Dealer did a reset of the car because there were like 6 codes in other systems (*&^%! Why won't they just listen to me when I say ignore the others and deal with the only one that turned on the CEL). At any rate, the CEL was back on the same evening with the same code (no other codes in any systems - go figure) so it's going back Tuesday to have them look at it again. I'm sure it's just the pressure sensor that needs to be replaced (or possibly the bypass valve in the pump).
      I have a '04 S60R with just over 50K miles on it...what mileage are you at?
      Re: Check Engine code PO193 (we R obsessed)
      04 with 26,000 and the light comes and goes. It seems to comes on when I drive for more than 30 min at 65-80mph, i will make a app. with the devil this coming week.
    7. Remove Advertisements
