V70 Model Information
    Results 1 to 10 of 10
      V70 Model Line Information
      I put a thread together in the 800 series forum for model information. I was hoping to do the same in the second gen V70 forum. Take a look at the 800 model info post and reply if you have any similar info you want me to add to this post.
      http://forums.swedespeed.com/zerothread?id=14333
      After I add your information I will delete your post to keep the thread clean.
      Thanks
      * This information is only accurate for the U.S. market, different markets had different configurations.
      In addition to this information there is a wiki article here: http://en.wikipedia.org/wiki/Volvo_V70
      Volvo Cars Owner information here: http://www.volvocars.us/tools/OwnersInfo
      The second gen V70 series was available in the U.S. for 7 years.
      It was available in 6 trim levels over the 7 years.
      We will refer to these trim levels as follows:
      Variant 1 - Base
      Variant 2 - low pressure turbo
      Variant 3 - high pressure turbo
      Variant 4 - AWD
      Variant 5 - XC
      Variant 6 - R
      Please let me know if any of this information is not accurate.
      Engine Information:
      2.4 -
      168 hp
      Superior fuel economy
      Continuously variable valve timing
      Advanced emission control
      2.4T -
      197 hp
      2.5T -
      208 hp / 236 lb-ft @ 1500 - 4500 rpm
      Dual continuously variable valve timing
      T5 -
      247hp
      R -
      300 hp / 295 lb-ft @ 1950 - 5250 rpm
      Double overhead camshafts, 20 valves
      Dual Intercoolers
      Stereo Information:
      Speaker sizes
      Head Unit models
      Common Problems & Recalls:
      2001
      Variant 1 - Base - 2.4 non-turbo
      Variant 2 - 2.4T - 2.4 low pressure turbo
      Variant 3 - T5 - high pressure turbo
      Variant 5 - XC - 2.4 low pressure turbo + AWD
      2002 – Non XC AWD trim introduced.
      Variant 4 - 2.4T AWD - 2.4 low pressure turbo + AWD
      Variant 5 - XC AWD - 2.4 low pressure turbo + AWD
      2003 – The AWD system was updated for 2003+ to a newer haldex electronic system. The AWD models got a displacement bump from 2.4 to 2.5 Liters. The V70XC AWD was renamed to the XC70 AWD.
      Variant 4 - 2.5T AWD - 2.5 low pressure turbo + AWD
      Variant 5 - XC AWD - 2.5 low pressure turbo + AWD
      2004 – The R trim level was introduced. The 2.4T was updated to 2.5T for the non-AWD model.
      Variant 2 - 2.5T - 2.5 low pressure turbo
      Variant 6 - R AWD - 2.5 high pressure turbo + AWD
      2005 – The 2.5T AWD trim was dropped.
      New center stack dash layout, new cup holder design for front passengers
      2006 – The T5 was dropped for '06?
      2007
      XC70 has gauges similar to the R but with a black face.
      Front side blinkers are now integrated into the mirror housings
      Please contribute!
      His: 2011 Nissan Leaf - No Gas... Just Electrons...
      For Sale: 2007 S80 V8 AWD
      Hers: 2010 XC70 T6 AWD
      Junior Member cargusjoh's Avatar
      Dec 2002
      Broomfield Colorado
      First COOOL!!!
      Head Units:
      HU-613 1 cd 1 tape with hidden equalizer
      HU-803 Pro-logic 4 cd with hidden equalizer menue
      HU-805 Pro-logic 6 cd with no (known) hidden equalizer
      Amps:
      The HU-803 and HU-805 use external amp located under passenger seat. Two types, one is PA200(amp) and PA300(amp). 4ohm speakers should be used as these are rumored to be weak. I used 8ohm, but don't seriously crank tunes.
      Door Panel:
      Two styles, the premium had place for 3 speakers in door. The other had place for 2.
      Speakers:
      There was low end, mid quality, and highest quality. Highest was Harmon Kardon 4ohm (I am pretty sure) with 3 speakers in front door panel, mid were no-name 8ohm ( I had these, replaced with Infinities 8ohm, should have used 4 ohm as amp is pretty weak I am told), and low ends I know nothing about. Note: If moving to surround sound adding center speaker, there is a plastic tray that can be removed and forms a speaker mount if "adjusted". There is also a thread in the audio section with tons of part/description info...
      Best,
      Carl
      2004 V70R MT Gobi 149k. Sorely missed 2000 C70HPT Coupe Black totaled (Lesson: never let !ANYONE! drive your car). Along the way owned 2005 XC90, 1998v70, 1995 850 wagon (great car!), 940, 740, 92ish 240 and 75 245, 73 1800ES, 71 1800E, 67 1800S (most favorite 1800, great car!), 61 544 (tank!).
      Re: V70 Model Line Information (Kaizai)
      varient 3 - 247hp / 243 lb-ft
      10 PSI Boost
      0-60 second - 7.2 sec
      Common problems - ETM
      this was provided by IPD
      '06 had T5 in the S60. I apologize in advance if this information is useless in a V70 FAQ (which I overlooked)
      http://www.scandinavianimports...63732
      "06 S60 T5 #2425 (Titanuim Gray Pearl) Limited Edition T5 "Dynamic Edition" which includes "Cassopia" wheels and chrome mirror caps and door handles and sport mats and Dolby surround sound Pro Logic II HU-80X 225 watt CD radio WITH SIRIUS radio, 257hp high output engine,.."
    7. #5
      2006 trims should show 2.5T AWD (I have one).
    8. #6
      Junior Member Dasrah's Avatar
      Dec 2009
      Kansas City
      [LEFT]Some More T5 Details:
      ENGINE- B5234 T3
      2.3L
      20 valve
      Max Torque- 243 ft lbs @ 2400-2500rpm
      Bore- 3.19" (81mm)
      Stroke- 3.54" (90mm)
      Compression Ratio- 8.5 : 1
      ]Firing Order- 1-2-4-5-3
      TRANSMISSION-
      *VERY common Failure!*
      Aisin Warner 50-50/51
      Fluid- 7.9qt / Volvo gearbox oil or *tip*- Toyota uses the same 3309 compliant fluid, so just ask for Type IV transmission fluid from your local Toyota dealer. Price=$5 a quart
    9. #7
      Junior Member Wildwagonz's Avatar
      Mar 2013
      Browns Mills, NJ
      Some engines info:
      2.4Litre Non-turbo is designated B5244S and has Variable valve timing on Intake cam only, available in auto or manual trans(M56) but FWD only
      2.4Litre Light pressure turbo (2.4T) is designated B5244T and variable valve timing on Exhaust cam only.
      2.5 Litre Light pressure turbo(2.5T) is designated B5254T2 (VIN code 59)and variable valve timing on both cams and was only avaiable(in the US) with an auto trans
      2.3Litre High pressure turbo(T5) is designated B5234T3 (VIN code 52?)and uses the same KKK K24 turbo charger as the R models and is only available in FWD
      2.5 Litre High pressure turbo(R) is designated B2524T4 (VIN code 54) has variable Valve timing on both cams, has KKK K24 turbo and is only available in AWD
      2005 saw introduction of plastic headlamps(except R models), high pressure headlamp washers instead of wipers(except R models), LED rear marker lamps, non-diffuser tail lamp lenses and body colour mouldings
      ETM throttle was used form MY2001-2002 and was subject to a 10years/200,000 mile extended warranty. MY2003 saw introduction of standard type electric throttle assembly
      Poor maintenance can result in clogged PCV system and lead to excessive crankcase pressures causing bypass into intake tubing(appears as thought turbo is leaking but it's not)
      Mine: 2004 V70 2.5T FWD Titanium Grey "Idunn"
      Hers: 2005 XC70 Barrents Blue
      73 Triumph GT6 MkIII
      Previously 92 245 5spd Dk Emerald Green "Frigg"
    10. #8
      I have an 01 v70 t5 that the thermostat gives off temperatures. That in turn tell the ac not to turn on. At the same time I get codes for plate and brake lights not working. In fact they alway do. It also may or may not be affected by the rear hatch occasionally being slammed. Any ideas on a repair?
      Sent from my A0001 using Tapatalk
    11. #9
      Mystery Designation
      I am considering for purchase a 2002 V70 wagon. The badge on the back of the car does not read xC or AWD, I think it is CD or CG. VIN: Yv1sz58d721080911. Anybody know what car this is?
    12. #10
      Junior Member rich1068's Avatar
      Apr 2015
      UK
      Quote Originally Posted by jbuyer View Post
      https://www.vindecoderz.com/EN/check...sz58d721080911
      There are a few of these about. Just Google Volvo VIN decoder.
      2005 Volvo V70 2.5T SE AWD
      2014 Volvo XC90 D5 Executive
    13. Remove Advertisements
