NJ/NY R Drivers - EZ-Pass mounting?
    Results 1 to 35 of 35
      Hey NJ/NY drivers...on your R where the heck do you mount your EZ-Pass device?
      The configuration of the rear view mirror (it's huge!) on this car would force you to mount the device so low to be centered, that it's just unacceptable.
      Do you all have the license plate mounted version of the EZ-Pass transmitter? I just can't see mounting regular one which would have to go practically in the middle (vertically and horizontally) on my windshield under the mirror!
      What have the rest of you done? Right now, mine is riding in the dash cubby next to the radio...but that's just temporary.
      Trish
      '10 XC90 Magic Blue/Soft Beige
      '04 XC90 Silver/Charcoal - For Sale
      '01 V70 T5 5MT Silver/Charcoal, too many mods.
      '72 142 Dark Green Metallic / Tan-Black two tone interior. Volans.
      Re: NJ/NY R Drivers - EZ-Pass mounting? (1800girl)
      Mine is just to the right and slightly behind the rear-view mirror and I've never had a problem. In that location, I really can't see it, so it's not in my way and the signal is picked up every time-unfortunately!
      2006 S60R 6MT>>>>>> SOLD on 6/12/10
      Global Moderator
      Nov 2005
      The Woodlands, TX
      Re: NJ/NY R Drivers - EZ-Pass mounting? (jrgoffin)
      Quote, originally posted by jrgoffin »
      Same here, behind the black stuff. No problems with reception at all.
      You can see it peeking out on the left side here behind the mirror, to the left of my V1.
    5. #4
      Maybe I am making a big deal because I don't want it to be too visible...or ugly. I'm not too worried about the reception.
    6. #5
      I've mounted mine to the right behind the mirror. I never see it, and you can't really see it from the outside either. Works just fine. I generally forget I have it until I need it.
    7. #6
      what...PA drivers aren't invited into the EZ pass thread?
      i have mine mounted a few inches to the right of the rear view mirror and about 1 inch down from the top.
      Matt
      2005 XC90 V8
      2006 Volvo S60R - 6MT
      2012 Volvo XC60 T6 R-Design
      1993 S13 - 2JZGTE, 600rwhp
    8. #7
      Member Lightspeed's Avatar
      Jul 2005
      work- ct,ny,NJ,pa,de
      Technically, our cars do not qualify for a plate mount per EZPass guidelines. I wrote a letter stating I had a touring option with specially treated windows. Took two attempts, but they finally replaced my window mount with a plate mount.
      Really don't like the look of the interior badge.
      06 VR 6M, Sapphacama, 207miles, loaded and modded.
      "…it must be made to look the best and most evil in its evilness." - Helmut
    9. #8
      Re: (phuz)
      Yes, sigh...I guess PA drivers can play too.
      Maybe there's more room there than I thought. The housing around the base of the mirror mount seems so bulky.
      Trish
    10. #9
      Junior Member bill d cat's Avatar
      May 2003
      Jersey Shore
      Quote, originally posted by EZ PASS »
      Your E-ZPass tag is installed using fasteners that come with your tag. The tag should be installed approximately one inch below the top of your windshield above your rearview mirror. If there is not enough room above your mirror, the tag should be installed to the right of the mirror, approximately one inch below the top of your windshield. Be sure to read the E-ZPass Customer Guide that comes with your tag for detailed instructions on proper installation.
      Lined up correctly with the mirror, it is essentially invisible from inside the car. I sometimes used masking tape to find an "invisible" spot to locate the pass, but I've had it on 5 or 6 cars and couldn't see it from inside the car, at least not to the extent that it was bothersome or intrusive.
      '98 V70 T5, 5-speed manual, white, 207K mi, original clutch, third AC evaporator, heated tan velour seats (FIXED!), cracked dashboard, factory HD suspension (1998 only), front IPD stabilizer bar, rear HD Bilsteins, Volvo strut tower brace and skidplate, XC grill, C70 E-Code headlights, fog lights, no spoiler, hard-wired V-1, Lidatek, IPD stuff, JB Weld, 3M Duct Tape, zip-ties, Mobil-1 since new.
    11. #10
    12. #11
      Global Moderator
      Nov 2005
      The Woodlands, TX
      Quote, originally posted by 1800girl »
      Oh, women......
      Would I give you an ugly, visible location? No, of course not.
      Only visible inside if your passenger is checking out the mirror.
      Completely invisible from the outside. (Excuse the dirty windshield.
      (P.S. Notice how well the Lexol conditioner works on the seats...that's 50k miles there! And the side bolster behind the seatbelt isn't worse!!!)
      Modified by Needsdecaf at 6:02 PM 3-13-2007
    13. #12
      Got mine in the same spot on both cars
    14. #13
      Re: NJ/NY R Drivers - EZ-Pass mounting? (Needsdecaf)
      Quote, originally posted by Needsdecaf »
      Oh, women......
      Ok. Cool. Thank you! A+ for effort...adding all those pics. It's all about the details!
      Trish
    15. #14
      Member rollie's Avatar
      May 2001
      Sammamish, WA / San Jose, CA
      I have the EZ-Pass as well as the equivalents for the Texas toll-roads, SoCal, etc. I've used them on both my own P2 Volvos and on Hertz's and have never had a problem with the passes mounted behind the black sunblock stuff.
      I too keep mine on the passenger side out of my line of sight.
      Gone: 1994 850 Turbo, 1998 S70 T5, 1999 S80 T6, 2001 V70 T5, 2003 XC90 T6, 2004 S60R Ata
      Current: 2005 XC90 V8, 2009 BMW M3 DCT sedan
    16. #15
      I keep my "FastTrak" (it's called here in SoCal) in the vertical slot next to my HU and I never use it, they just bill me by my license plate number.
    17. #16
      I didn't do this on my S60R but an option is to get the license plate mounted EZ pass and mount it on the front of the radiator behind the grill w/ zip ties. I will try and dig up some pics. Nice and hidden....never had any issues.
    18. #17
      Jul 2005
      Re: NJ/NY R Drivers - EZ-Pass mounting? (NUHuskyfan)
      Quote, originally posted by NUHuskyfan »
      That is a great idea, and it worked well on my 2000 Passat wagon, where you could pop the grill with a good tug to access the plate-type tag. It doesn't seem so easy on the V70.
      Also, occasionally I will get a misread at the Brooklyn-Battery Tunnel. They use gates, and an officer will use a mobile scanner to read the barcode on the tag and then grant passage. If they cannot scan (ie no access to tag) there is a $2.50 service fee!. "Extra paperwork", they say.
    19. #18
      Senior Member JRL's Avatar
      Apr 2003
      Devon PA
      Newsflash, you can have it on your lap and it will work
      Email: jrl1194(at)aol.com
      If the subject is car purchase related please use jrl1194(at)gmail.com
      2007 V70 2.5T White/Oak 108K miles, new daily driver
      2000 V70R wife's. Won't sell, now near 141,000 miles and still near perfect!
      2000 S70 GLT SE 30,005 MILES, A time capsule! JUST SOLD.
    20. #19
      Re: NJ/NY R Drivers - EZ-Pass mounting? (Lightspeed)
      Quote, originally posted by Lightspeed »
      Ironically i had a misread outside of NYC (I can't remember where exactly) and the guy came running out to scan my pass. I explained where it was and he said "give me the cash so I can get these people to stop honking at you."
    21. #20
      My car pic is Pamela Anderson. Joes is like a dungeon
    22. #21
      Re: NJ/NY R Drivers - EZ-Pass mounting? (Helmut Ranff)
      Quote, originally posted by Helmut Ranff »
      Helmut -
      What the F is that?
      Move that up behind the black shaded area - you are making us all look bad
      2011 Highlander limited - Loaded
      2009 Infiniti G37S Conv 6MT - all options
      2008 XC90 V8 Exec - Elec Silver
      2007 S80 V8 - Elec Silver
      2004 S60R 6MT - Silver / Nord
    23. #22
      Junior Member doubleb26's Avatar
      Aug 2005
      Wake Forest, NC
      I have a 2006 V70R and it is mounted to the lower right side of that black spot on the windshield.
      I basically sat in the driver's seat and placed it on the window until I could not see it anymore.
      Never had an issue with it not working.
      On my 1996 850, I mounted it even higher...bordering the top tint (or whatever you call the top of the windshield where it is tinted) and I never had an issue with it their either.
      2006 V70R - GT - Electric Silver / Nordkap (just plain ol' stock)
    24. #23
      Aug 2005
      Wake Forest, NC
      Re: NJ/NY R Drivers - EZ-Pass mounting? (JRL)
      Yes it will, but in NY some of the tolls have the bars that rise when you drive through them and if it doesn't register it immediately, you get stuck in the toll...now the capper...they give you a ticket right there on the spot.
      It MUST be mounted in NY, not sure about other states.
    25. #24
      Why thanks! Now if only it would vibrate too!
      Trish
    26. #25
      Apr 2003
      Devon PA
      Re: NJ/NY R Drivers - EZ-Pass mounting? (doubleb26)
      Quote, originally posted by doubleb26 »
      Big deal, then you just pick it up and hold it. It works, trust me on this
    27. #26
      Apr 2003
      Devon PA
      I'm sure I can make something work here.....
    28. #27
      You can always paint them black if you're worried about it being seen from the outside.
    29. #28
      Same location as Needsdecaf, never had any problems at all.
    30. #29
      Moderator adykes's Avatar
      May 2005
      Bay Area, CA
      It's easier in CA, it works in my glove box. And here FastTrak will scan license plates and charge you via that if you have no transponder or it cannot be read, no gates. It's great for visitors, hand then your transponder and they get billed by your transponder, you get billed with your plates. It's a win-win.
      2006 V70R Gone but not forgotten | 2009 Saab 9-7x Aero | 2006 Jaguar Super V8 | 2000 Jeep Grand Cherokee | Car Of The Week
    31. #30
      Apr 2003
      Devon PA
      Re: (adykes)
      We ain't got no stinkin' front plates
    32. #31
      Member teknicktion's Avatar
      Aug 2005
      Nutley, NJ
      LOL LOL
    33. #32
      May 2005
      Bay Area, CA
      Re: (JRL)
      Neither do I They take a picture of the back plate...
    34. #33
      Junior Member timxc90's Avatar
      Jan 2007
      florida
      Re: (adykes)
      I had the windshield mount but, after I got my windshield tinted it would not work anymore. They gave me the license plate mount. I looks so much better the box in the window looks junky and takes away from the appearance of the car.
    35. #34
      Global Moderator
      Nov 2005
      The Woodlands, TX
      Re: (timxc90)
      The way I have it mounted, it is completely invisible from the outside.
    36. #35
      Re: NJ/NY R Drivers - EZ-Pass mounting? (bill d cat)
      i would get the one that attached to the license plate bracket - if you have a front plate. otherwise, one of those suction cup holders to place on the windshield...it's not that big.
    37. Remove Advertisements
