1981 Volvo 240 carb change to SU HIF 6the carb on my 81 volvo to an su hif6 from a
    Results 1 to 7 of 7
      Hi,
      i just changed my carb from a zenith 175cd to an SU hif6.
      I need some help with getting the vacuum hoses correct for the advance/retard and pcv system.
      Any help or links wouid be appreciatted.
      This SU has a small outlet just before the throttle plate and a larger out on the carb flange.
      If you need any more info please ask.
      Thx, A
      Senior Member
      Aug 2004
      Temple, Texas, USA
      Re: 1981 Volvo 240 carb change to SU HIF 6the carb on my 81 volvo to an su hif6 from a (andybot)
      The small outlet is for vacuum-controlled engine timing and the large is intake for crankcase ventilation.
      Did the Zenith have any electrical connections?
      George Dill
      Re: 1981 Volvo 240 carb change to SU HIF 6the carb on my 81 volvo to an su hif6 from a (gdill2)
      Thx George,
      no electrical connections on the zenith carb.
      Do you know if the crankcase ventilation tube is suppossed to come from a connection on the flame guard, or is there another position?
      Im still lost on where the timing retrad line is suppossed to go.
      Thx Again George.
      A
      ps.
      one last question. There is an idle bypass adjustment on the intake manifold where the carb attatches. When tunning this carb is there a nominal postion for this as it doesnt mention it in the tuneup procedure im using.
      Thx
      Senior Member
      Aug 2004
      Temple, Texas, USA
      Here are some SU carb PCV options...
      http://www.volvop1800club.se/a...8.jpg
      http://www.volvop1800club.se/a...5.jpg
      These are for B18/20 engines but show different approaches to positive crankcase ventilation.
      Does your car have a flame trap collection box? Does the distributor have vacuum connections?
      The choke bypass setting depends on the type of choke set-up on the carb.
      Might play on this for more SU HIF6 stuff...
      http://www.volvoadventures.com/index.html
      Any pics of your set-up?
      George Dill
    7. #5
      Senior Member
      Aug 2004
      Temple, Texas, USA
    8. #6
      Thx G,.
      worked out what i needed to know with the help of your links.
      Any info on replacing a windshield on this same car?
      Tha Again
    9. #7
      Senior Member
      Aug 2004
      Temple, Texas, USA
      Windshield replacement is a two-person job as the sealant must be applied just so and the glass pressed into place in perfect alignment. Also, it is a real chore to reuse the trim around the glass.
      George Dill
    10. Remove Advertisements
