Check Engine Light/Code PO193/Question??
    Results 1 to 6 of 6
      Hey guys looking for some insight into this code?
      I know it means /Fuel Rail Pressure Sensor Circuit High Input\
      So in Lamens terms, what needs to be replaced??
      I'm going to take it into the dealership this Friday, and want to know what I'm talking about when I talk to my service advisor about it.
      I did do some searching, but nothing definitive on what was actually replaced to get rid of the code
      Thanks everyone
      Hi
      Replacing the fuel pressure sensor fixed the P0193 error code for me.
      I had exactly the same problems as those explained in the Recall thread at the top of the forum. Your car may be covered by the recall..
      My symptoms were the engine would stall randomly, hesitate when accelerating, and throw the P0193 DTC code...
      Hope this helps
      Phil
      Re: (philwoolger)
      Quote, originally posted by philwoolger »
      Hi
      Hope this helps
      Phil
      It does thanks. Hopefully that will solve the problem.
      Did your car have any noticable performance improvement after the fix?
      How long did the dealer have your car for the fix?
      Re: (Gabe)
      This sounds exactly like the recall pinned at the top of the page.
      I had that and some misfire codes when my pressure sensor was replaced.
    7. #5
      Not really any performance increase, it just became a reliable overtaking car again, plus it no longer stalls randomly
      Unfortunately my car is out of warranty, so I replaced it myself, which took probably about 1/2 hour to fit.
      Phil
    8. #6
      Re: (philwoolger)
      Phil
      Ok that gives me some info that I needed
      Thanks....
    9. Remove Advertisements
