+ Reply to Thread
Results 1 to 7 of 7
Thread: OBD-II Readers
  1. 10-01-2007 11:51 PM #1
    Does anyone know by chance what a good way to read the s40's OBD-II, that is case a code should be thrown in the car I could read what's going on? Or better yet, some program where I could hook the computer to the car, scan it and be able to take diagnostics over a run to see how that cars functioning? Or do the softloaders like BSR or IPD's ECU PRogramming also scan for codes as well, in the event I decide to chip the car using a softloader?
  2. Member cicatrizdare's Avatar
    Mar 2005
    Miami/Jacksonville,FL
    10-02-2007 12:00 AM #2
    ipd should have one
  3. 10-02-2007 04:18 AM #3
    auterra. works fine.
  4. Member V50_T5's Avatar
    Jun 2005
    Schweinfurt, Germany
    10-02-2007 11:27 AM #4
    Yes , IPD has an OBD 2 code reader as an option for their softloader. The BSR doesn't . JC whitney has some great code readers for about $99 that show not only the fault code but also the fault (insted of having to look it up in a seperate book)
  5. 10-02-2007 09:48 PM #5
    http://www.obd-2.com/
    You need a laptop, but you can check and clear codes, run tests, calculate HP-MPG-boost and a ton of other stuff. You will need the TRICAN version, $240. Student and other discounts available.
  6. Senior Member phuz's Avatar
    Jan 2005
    Reading, PA
    10-03-2007 10:20 AM #6
    PCMSCAN FTW.
    Version 2.0+ has more features than you can handle.
    Matt
    http://www.phuzzymotorsports.com
    2006 Volvo S60R - 6MT: FMIC, DP, Autotech Tune
    1993 S13 - 2JZGTE, Single PT6262 Billet Turbo, Haltech PS2000 Standalone, 1000cc Precision Injectors, Methanol Injection, 4" FMIC
  7. 10-24-2007 07:53 PM #7
    I've looked on JcWhitney, Can I get any OBD-II reader, I have a 2006 S40 T5 FWD. Or do I have to have C.A.N. enabled for the reader.
+ Reply to Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
