Volvo s40 T5 Engine Sucking Air Weird noise Solution
    Results 1 to 16 of 16
      I have a 2005 Volvo s40 T5, the engine was making a weird noise, so I looked around and I found out that when I took off the oil fill cap or the dip stick the noise went away, also if I put my hand over the oil fill cap it would suck my hand to the opening, so I looked around here and found that the problem was the Oil Trap "Oil filter housing" here is the post that I found this info and someone posted some good pictures on page 2 - 4
      http://forums.swedespeed.com/z...age=1
      Solution: go to your Volvo dealer and buy the oil trap it costs about 120.00 usd, get two hose clamps
      oil, the oil trap should come with a oil filter
      Total time on the ground less than 2 hours
      if you are tech with all the proper tools, probable less than a hour
      to replace the oil trap:
      1: disconnect the air tube that crosses across the valve cover there are a few air hoses connected to this tube so be caution, then remove the plastic cover on the valve cover it should be a t27 hex bit.
      2: on the air filter box, remove the air filter, then to the left of the air filter is a breather tubs, remove them so you can gain access, next it might require a little force, pull the air box up, it is held in by rubber grommets there are about three, once you get it up a little, on the right side of the air box there is a plastic cover remove it and you will see two plugs for wires, you will need to push in a tab and lift the right release tabs out and the two plugs will release, next on the back of the air box there is a hex screw holding the wires you just released to the box, remove this and pull the wires away form the box make sure there is no other tubes or wires connected to the box and wiggle the air box as far as you can to the drivers side of the car, note you don’t need the air box out of the car, and you can leave the radiator fans, and the intake manifold still inside the car, no need to remove them. so you now have the air box to the right Good.
      3: on the oil trap you will see a plug, remove this from the oil trap, then remove the oil dip stick bolt, should be 10mm socket, also there are two more 10mm bolts that hold on some air tubes do the bottom one in the next step, next remove the one top bolt for the oil trap it is on the top right side of the oil trap, next on the air tube that goes from the oil trap to the valve cover you should remove both hose clamps and remove if you can you only will need one side free to get the oil trap out.
      4: under the front of the car, remove the plastic splash guard, should be 7 hex screws three in the front, two on the side, and two in the back, once removed you will be able to see the bottom of the oil trap where there are three 10mm bolts holding it on, before removing the bolts remove the bottom bolt of the air tubes from step 3, now remove the three bolts on the bottom of the oil trap, the trap will leak some oil, go back to the top of the car and gently pull the oil trap down to release a hose hooked to the intake, and pull the oil trap out a little, there is a group of wires that are connected to the oil trap you will need to free them it is best if you use long needle nose pliers, once that is removed you can then gently pull the oil trap out between the air box, intake, and radiator, it might be a little tight but it will come out,
      5: so you have the new oil trap put the short hose on the oil trap the one with the 90 degree bend, and put the long hose that goes to the valve cover on at this point, you might want to put on a hose clamp at this time, next the screws that you removed to get out the dip stick and the air hoses, you might want to screw though into the oil trap before you put it in so you can thread the holes for the self taping bolts, then remove the bolts before putting the oil trap in, done good
      6: put the oil trap in, first you will want to clean the contact area mainly where the three holes in the engine block are you want a good clean contact for the oil seals on the oil trap, all clean now it is time to put the oil trap in, make sure you don’t get any wires or hoses between the oil trap and the engine block, once you have made contact put the oil trap bolt in the top right corner of the oil trap, just make it finger tight, next put in the three bottom bolts also finger tight now tighten them hand tight do not over tighten, if not sure call your Volvo dealer to get the tighten specs, now the rest is just putting every thing back together and do the rest of your oil change,
      7: all back together, and oil is filled and oil drain plug is tight, good, time to start the car and turn it off immediately, and do it two more times this is to make sure you have oil pressure, after the third time leave the car running, make sure your oil light is not on in your cluster panel, next with the car running open the oil fill cap and see if it is still sucking air, it will have a little but it should not create a suction to your hand,
      Member volvoNB's Avatar
      Jan 2004
      Dallas, TX
      Re: Volvo s40 T5 Engine Sucking Air Weird noise Solution (brodilyle)
      Before doing this, I would try to complain to the dealer first. They might fix it for free since it is a known problem.
      2005 S40 T5 BSR Stage 3
      Member genjy's Avatar
      Aug 2007
      Glendora, CA
      Thanks. Nice guide for the DIYers.
      Thanks much for taking the time to share & post your info. I feel I might need to use it one of these days,
      Steve
    7. #5
      thanks, I may do this as good insurance. repeat every 40k.
    8. #6
      I just followed these directions last night to do this to a 2006 S40 T5 (coincidentally, with just of 30k miles - which seems to be when these things fail). These directions are great, couple of hints though from my experience.
      1) When taking off the air tube over the cylinder head there are two bolts holding it on, one is really easy, the other is down across from the battery. I found it easier to get to the second one by removing the rubber hose between the tube and the airbox (you have to scrunch it up to do this - but if it isn't brittle, this shouldn't be a problem) . . . that allowed me to get light in there and see what I was doing, and gave a little more hand room.
      2) The directions get a little confusing talking about the bolts that mount the wires, dipstick, etc, to the unit. One of these bolts is easier to get from the bottom - keep that in mind (if you read through the directions carefully in their entirety before you do it that will probably make sense).
      3) The hose that comes out of the unit and runs to the top of the cylinder head is VERY fragile (at least mine was, after 5 years and 30k miles). I ended up breaking it and instead of buying a new one I used a rubber hose directly off of the unit and then joined it up to the firmer (upper) part of the existing tube. I routed it the same as the other tubes - I just used coolant tubing to do it - that tubing has to be at least 3X as tough as what was on there.
      So far no issues. Thanks to the original poster.
    9. #7
      Oh, one more thing. The original poster said 1-2 hours. I think this took me around 4-5 hours (I'm not the best mechanic, but I've been working on cars for 20 years). If I did it again, I'm sure I could eliminate half that time - but if you're doing it for the first time definitely give yourself some time.
    10. #8
      Global Moderator tmtalpey's Avatar
      Jun 2004
      Eastern MA
      Missed these tips when they were posted back in 2007, added to sticky.
      BTW, my 2005 V50 T5 has over 53K miles and still hasn't had this issue, or the hardened-breather-hose one either. It's definitely not a lock to be an issue at 30k miles. In any case, both are covered on the extended warranty since they're emissions-related items.
      2005 V50 T5 AWD 6MT w/Heico tune, Heico exhaust, Bell intercooler, IPD TCV, Viva Forge CBV, Elevate rear swaybar and torque mount, Snabb shift kit, etc.
      2016 XC60 T6 AWD
      1956 PV444 complete, running
      1956 PV444 very original, very rough
    11. #9
      Moderator aldebaran's Avatar
      Jul 2005
      Greensboro NC
      Quote Originally Posted by brodilyle View Post
      I have a 2005 Volvo s40 T5, the engine was making a weird noise, so I looked around and I found out that when I took off the oil fill cap or the dip stick the noise went away, also if I put my hand over the oil fill cap it would suck my hand to the opening, so I looked around here and...
      Wait...I thought suction at the oil fill cap/dip stick is an indicator of a functioning PCV.
      I missed the date of the original post also.
    12. #10
      Jun 2004
      Eastern MA
      Slight suction is by design. Any significant pressure, positive or negative, is not.
      2016 XC60 T6 AWD
    13. #11
      Jul 2005
      Greensboro NC
      Ah okay, I've learned something new. I have always thought PCV failures only resulted in positive crank case pressure.
    14. #12
      Thanks to tmtalpey - I am following up with Volvo about the warranty issue to see if I have any recourse there.
      Also, very good to know that the one I just installed may last longer than 30k miles - it just seemed to be the trend on the posts I read that 30k miles was it. As you can see from the age of my car, it took some time to get to 30k miles (5 years), and then boom, issue. The car has not had a tough life, so not sure what the extenuating circumstances are.
    15. #13
      Jun 2004
      Eastern MA
      2016 XC60 T6 AWD
    16. #14
      Lightbulb
      Regarding the warranty discussion, I just had a quick conversation with Volvo about this and they confirmed that there are things covered outside the normal Volvo warranty. However, they said most of this work could only be diagnosed and performed under warranty at a Volvo dealership - which makes sense, but is not real convenient (I live in a metropolitan area and it's still a hassle to get to a Volvo dealership). I know I saw a few people mention that they had been reimbursed for the work after the fact - I believe them, but I am not sure the $ amount (the most I could get would likely be the $120 for the part given that I did the work myself) is worth the fight for me. Ultimately it is my fault for not reading the Warranty and Service Records Information booklet that came with the car. Lesson learned. Anyone else having this issue may want to delve into this before deciding where to take their car for service (dealer vs. independent) or deciding to do it on their own.
      I did a quick search but did not see much on this topic on swedespeed - but maybe this is common knowledge to recent car owners (I haven't owned a car newer than 1993 other than my wife's last two cars - the first of which was under warranty - so this wasn't really an issue for me before). Again, lesson learned.
      Specifically, this is what is in the 2006 Volvo S40 Owners Manual . . .
      "Applicable warranties - U.S/Canada
      In accordance with applicable U.S. and Canadian regulations, the following list of warranties is provided.
      New Vehicle Limited Warranty
      Parts and Accessories Limited Warranty
      Corrosion Protection Limited Warranty
      Seat Belt and Supplemental Restraint Systems Limited Warranty
      Emission Design and Defect Warranty
      Emission Performance Warranty
      These are the federal warranties; other warranties are provided as required by state/provincial law. Refer to your separate Warranty and Service Records Information booklet for detailed information concerning each of the warranties."
      Thanks again to the folks that pointed this out. Now that I own cars built in this century this is important information to be aware of.
    17. #15
      tmtalpey. Good link, thanks. In my reading before doing it myself I checked the recalls for my vehicle and came up with nothing regarding oil trap / pcv - but judging by that thread I could have had worked it from a dealership had I had my stuff straight - I was in too much of a rush to get it done. Once again, lesson learned.
    18. #16
      On second thought, maybe I will try for some reimbursement.
      http://www.theeshadow.net/files/ew205.pdf
    19. Remove Advertisements
