Camshaft Sprocket alignment “how to align the cam shaft to the camshaft sprocket”
    Results 1 to 9 of 9
      I have a 2004 Volvo S40 T5, I went to replace the camshaft oil seals, so I pulled the Timing belt off and took out the camshaft sprocket bolt and removed the sprocket and replaced the seal, now the problem begins, there is no guide pin or marks on the sprocket to align the camshaft sprocket to the Camshaft, I have taken the valve cover off which also is the cam shaft bearing cap, which holds the camshaft in place not a problem thought, now when I look at the exhaust camshaft I see that the first two lobes are up aligned with the timing mark on the camshaft sprocket. Now is it safe to say that on the intake camshaft the first to lobes should also align with the timing mark on the sprocket, any help would be great
      Global Moderator tmtalpey's Avatar
      Jun 2004
      Eastern MA
      Re: Camshaft Sprocket alignment “how to align the cam shaft to the camshaft sprocket” (brodilyle)
      Sent you email...
      Tom.
      2005 V50 T5 AWD 6MT w/Heico tune, Heico exhaust, Bell intercooler, IPD TCV, Viva Forge CBV, Elevate rear swaybar and torque mount, Snabb shift kit, etc.
      2016 XC60 T6 AWD
      1956 PV444 complete, running
      1956 PV444 very original, very rough
      I have a 2006 Volvo v50 turbo, I went to replace the camshaft oil seals, so I pulled the Timing belt off and took out the camshaft sprocket bolt and removed the sprocket and replaced the seal, now the problem begins, there is no guide pin or marks on the sprocket to align the camshaft sprocket to the Camshaft, I have taken the valve cover off which also is the cam shaft bearing cap, which holds the camshaft in place not a problem thought, now when I look at the exhaust camshaft I see that the first two lobes are up aligned with the timing mark on the camshaft sprocket. Now is it safe to say that on the intake camshaft the first to lobes should also align with the timing mark on the sprocket, any help would be great
    7. #5
      halo is anybody on there
    8. #6
      Camshaft Sprocket alignment “how to align the cam shaft to the camshaft sprocketI have a 2000 Volvo S40 T5, I went to replace the camshaft oil seals, so I pulled the Timing belt off and took out the camshaft sprocket bolt and removed the sprocket and replaced the seal, now the problem begins, there is no guide pin or marks on the sprocket to align the camshaft sprocket to the Camshaft, I have taken the valve cover off which also is the cam shaft bearing cap, which holds the camshaft in place not a problem thought, now when I look at the exhaust camshaft I see that the first two lobes are up aligned with the timing mark on the camshaft sprocket. Now is it safe to say that on the intake camshaft the first to lobes should also align with the timing mark on the sprocket, any help would be great
    9. #7
      Am I going potty or why has the same text been altered a few times by new members from different years!? SPAM?
      If you read this, then you haven't understood, that my posting is above this text!
    10. #8
      i dont think is spam, perhaps same guy different accounts lol..
      Selling aftermarket 19" wheels, installed by previous owner.
      Sticking to stock 17"
    11. #9
      Sep 2008
      Detroit, MIchigan
      Quote Originally Posted by brodilyle View Post
      Let me know if moderator tmtalpey answered your question, if you need help i can write it up for you as I have done it before.
      2005 S40 T5 Automatic Tune, 3" Custom downpipe, cherry bomb in place of Cat, 3" Cat back and magnaflow dual outlet Muffler
      1991 Dodge Shadow 2.5 Turbo 5 speed MT... many mods
    12. Remove Advertisements
