How to flush auto transmission fluid?
    Results 1 to 8 of 8
      Member 1999_V70's Avatar
      May 2003
      Main Line, PA
      I need to flush the trans fluid in my V70. I have a rough idea on how to do it, but would love a step by step DIY.
      Basically I'll drain it as much as possible. Add new fluid, run it through the gears and then drain and refill again? I refill through the dipstick right?
      2013 Volvo S60 T5 Premier
      Caspian Blue / Beechwood
      http://www.ipdusa.com/product....ord=1
      This is a quick and easy way to do it! I still haven't done mine and I got it in a month ago. Call me lazy
      I'm sure there are other ways aswell...
      May 2003
      Main Line, PA
      Re: (sjbdeebo2)
      I looked at that but can't jusify 30 bucks for a piece of $3 hose. I can get the 3/4 hose at the store.
      Besides, isn't there a drain plug on the bottom of the trans?
      Nov 2006
      Birdsboro Pa.
      Re: (895meztz94)
      I drained and refilled mine 3 times last summer after I bought my 98 S70. Now I'm on a once a year change using the same fluid. Just have plenty of new crush washers at hand. I had to modify my funnel and put a longer tube on it to reach the dip stick tube. Its slow putting the new fluid in with my set up, but it gets the job done....I also measure how much comes out so I can put exactly the same amount back in....I'm happy with my T5. Rob
    7. #5
      Re: (895meztz94)
      There is but there is only a few quarts that come out at once. IPD use to have a pdf link and I can't find it... $20 was how much I spent and it was a lot, I just figured I'd do it their way. What can I say I'm lazy.
    8. #6
    9. #7
      Member MadeInJapan's Avatar
      Aug 2003
      Knoxville, TN
      Here's a good write-up I helped put together. It works well and have done it with both of our cars without a hitch. http://www.matthewsvolvosite.c...=8767
      '98 S70 T5 Emerald Green IPD and other Upgrades/ '07 S40 T5 M-66 MT Mystic Silver Metallic, Heico Sports Suspension & Cone Air Filter, OZ 18" Wheels, Elevate Dual Exhaust Intake Manifold BOV & Stage 1 Tune, 27mm Racing Beat Rear Sway, Proforged Rear End Links, Ultra Racing Strut Tower brace & E-Focus Mount/ '04 V70 2.5T Ruby Red - IPD Upgrades (wife's car)/ '07 S60 2.5T Barrent Blue (son's car) All: Mobil-1 synthetic @ 5K miles.
    10. #8
      May 2003
      Main Line, PA
      Re: (MadeInJapan)
      Quote, originally posted by MadeInJapan »
      Excellent! Just what I needed.
    11. Remove Advertisements
