S70, V70, V70XC Buying Guide: Links and Suggestions
    Results 1 to 14 of 14
      Junior Member volvie!'s Avatar
      Jan 2008
      Sacramento, CA
      Hi Swedspeeders!
      I've noticed a few similar questions about a buying guide, but have yet to find one definitive topic with all the links and suggestions, so I thought I would try to compile a list.
      The goal?
      A one stop information shop for future potential Volvo owners!
      If you have any other suggestions or information, please post a reply and I will edit this first post so all the information can be found here.
      Let's try to make this so good it gets pinned to the top!
      So without further ado, the Buying Guide:
      Dear Potential Volvo Owner,
      Welcome to Swedespeed!
      We hope you find a Volvo to call your own and enjoy many happy years of Volvo ownership!
      But, we would also be remiss if we did not first warn you:
      1. Volvos are European cars, with all that that entails
      Quoted from dmorga1:
      Rules for buying a Volvo are like any other European car--you pay for the pedigree of the car. Few owner history with documented excellent maintenance history costs up front. A dog car? Well, you can get that cheap. Owners dump these cars all the time with no maintenance done, and you'll be up to your eyeballs (i.e., $2000-4000) in work in the first six months. No sh$t. Just a cautionary note--they are wonderful cars, but you get what you pay for!
      2. The 1999 and 2000 models may have Electronic Throttle Module (ETM) issues. Refer to this link for more information:
      https://forums.swedespeed.com/zerothread?id=39438
      Okay, now that we got that out of the way, lets get to the good stuff:
      -Typical problems of the series?
      https://forums.swedespeed.com/z...68442
      -Cosmetic differences?
      https://forums.swedespeed.com/z...71321
      Quoted from glsable:
      As to cosmetic differences between '98 and '99/'00 S/V70s, some others I have noticed are:
      - the '98s have a blacked-out area on the rear doors near the lower edge of the windows. The '99s and '00s just leave this painted body color. I guess for an automotive designer this was an important visual styling point! (but I have noticed that the blackout paint is wearing away a little on one of my doors).
      - Early '98s have flatter twin-nozzle windshield washer sprayers (same as the 850s?). Later-'98s, '99s and '00s have the square-lump style (single-nozzle). Mine is a July-98 build and has the square lumps.
      - I have heard a rumour (or read it somewhere?) that the '99/'00s might have cup holders in the rear seat armrest? Is this true? If so, I wish my '98 had these!
      Quoted from MadeInJapan:
      '99 and '00 V/S/XC/ and C's (I assume) have a pocket under the glove box to put things. My '98 does not.
      Quoted from 1999s70:
      Here are a few other model year observations:
      1998 has a "Volvo" label at the rear of the front quarter panels. 99 and 00 have turn signal marker lights in these positions.
      2000 saw the S70 SE model, which did not exist (or was not imported to the US) in previous years.
      The engines are unique to each model year, too:
      1998 has the 850 throttle setup (wired connection), distributor ignition (meaning that there's a cap and rotor that are part of routine maintenance), etc. with a peak of 162 hp for the NA engine
      1999 has the electronic throttle and coil packs at each spark plug (no distributor), also with a peak of 162 hp
      2000 is the 1999, but now with variable valve timing, adding 6 hp at peak (now 168 hp for the NA engine) and a few more ft-lbs of torque
      -Interior Photos of Model Differences:
      https://forums.swedespeed.com/z...09664
      -Youtube video walk-around of 1998 S70 T5:
      http://www.youtube.com/watch?v=c1sMP8aOjCg
      -V70 Cross Country/XC70:
      The only thing I have heard is that the older models (pre-2003?) are very sensitive to tire diameter, so it is important to keep all four tires* of the same brand/size/tread depth.
      * or is it just side-to-side that is important?
      And apparently lots of AWD 70s are running around in fwd-only mode (rear driveshaft removed) to avoid replacing expensive parts!
      -Things to check-out at before buying?
      http://www.volvo-forums.com/t3...r.htm
      -General advice, quoted from t5p0wer:
      expect to purchase a decent car for around 4-8k depending on the car, (T5, GLT, or an R) and expect for it to be relatively high-mileage... over 100k miles. and one last thing is to budget for replacement of parts that have been worn out over the years. this stage is called "Stage 0". here's a tutorial on what things to replace when purchasing a high mileage volvo:
      http://volvospeed.com/vs_forum...21017
      -Another take on Stage Zero by our own [email protected]:
      https://forums.swedespeed.com/zerothread?id=128807
      -S70 and V70 Repairs and Fixes:
      http://www.matthewsvolvosite.c...70s70
      -Volvo Recalls and Technical Service Bulletins:
      http://www.volvoforums.com/rec...e.htm
      -Wiring Diagrams (PDF):
      (Website is in Polish-- look under "Schematy elektryczne Volvotechinfo")
      http://mojevolvo.pl/wiki/Volvo_V70
      -Owner's Manuals (and other documents):
      1998:
      http://new.volvocars.com/owner...0.htm
      1999:
      2000:
      If these links do not work, go to Volvo Cars website:
      http://www.volvocars.com/us/Pages/default.aspx
      Select "Volvo Owners Info" from the menu on the top
      Register your e-mail address or sign in
      Select "Owners Library" from the menu on the left
      Enter your year/model information
      Other documents are also available (VIN Decoder, maintenance milestones, etc.)
      -Other model specific documents (with European specs) can be found at the UK Volvo Owner's Club site:
      http://www.volvoclub.org.uk/
      -The Volvo Club of America (VCOA) does not have model specific information, but with membership you can save on parts and service at Volvo dealerships. Here's the website:
      http://vcoa.org/
      And link to member benefits:
      http://vcoa.org/theclub/
      -General advice for looking on Craigslist, etc.:
      -Make sure you discuss important definitions. We found that seller's had very different ideas about what makes a "good" car and what "well-maintained means." Which leads me to my biggest piece of advice:
      -Get the car inspected (by someone who knows Volvos and/or the model you are considering) before you purchase (unless you are very mechanically inclined and know a lot about Volvos). The results of this inspection help prioritize what needs to be fixed now, later, or eventually. It can also help with price negotiations.
      -Search in bigger and/or wealthier city areas. The cars there are usually better maintained and often have more variety/selection available. I don't know how far you are looking to drive to find a car, but the bay area in CA (http://sfbay.craigslist.org/car/) usually has a good selection of Volvos of various models, vintages, and prices.
      -Check the listings often; cars are always being uploaded and sell fast on craigslist.
      Some other general advice:
      Even if you plan to do all the mechanical work yourself, say hello and make contact with the independent Volvo shops in your area. When you find a good one, you should be able to ask a lot of questions to help guide you what to look for, what to avoid, etc. as well as to point you towards good resources in your area (including other reputable independent Volvo shops in the other cities where you may be searching).
      -Quoted from MadeInJapan:
      Get a CARFAX
      -Reliability:
      Micheal Karesh (mkaresh) over at True Delta is gathering information about the reliability of various manufacturer's, including Volvos. But, at this time, there are not enough cars enrolled in this series to be included in the most recent results (hopefully this will change over time).
      Here is the link to the most current results:
      http://www.truedelta.com/reliability.php
      And, the home page:
      Other Volvo-related forums (in no particular order):
      -Volvospeed: http://volvospeed.com/vs_forum/index.php?
      -Turbobricks: http://forums.turbobricks.com/index.php
      -Brickboard: http://www.brickboard.com/
      -Matthews Volvo Site: http://www.matthewsvolvosite.com/
      -Volvo-forums: http://www.volvo-forums.com/
      -Volvoforums: http://www.volvoforums.com/
      -V70R: http://www.v70r.com/
      -Swedishbricks (listserve): http://www.swedishbricks.net/home.html
      Hope that helps.
      When you find a Volvo you like, feel free to highlight it here to get your car-specific questions answered.
      Good luck and happy hunting!
      (Make sure you post photos of your new purchase too! We love impromptu photographic car shows! )
      Take care.
      Modified by volvie! at 4:15 PM 3-8-2009
      Modified by volvie! at 3:13 PM 11-4-2009
      Sacramento VCOA: http://www.sacvolvoclub.org/
      1980 244 DL - 1998 S70 GLT - 2004 V70 2.5T
      Senior Member JRL's Avatar
      Apr 2003
      Devon PA
      Re: S70, V70, V70XC Buying Guide: Links and Suggestions (volvie!)
      Well said
      Email: jrl1194 ( at ) AOL (dot) com
      2007 V70 2.5T White/Oak/Tan/Arena, 117K miles. My DD with no plans to sell it anytime soon
      2000 V70R, Wife's, she won't sell. Now she hit 158,000 miles and still near perfect!
      Member MadeInJapan's Avatar
      Aug 2003
      Knoxville, TN
      Yes, very well done. This should be pinned for this section!
      '98 S70 T5 Emerald Green IPD and other Upgrades/ '07 S40 T5 M-66 MT Mystic Silver Metallic, Heico Sports Suspension & Cone Air Filter, OZ 18" Wheels, Elevate Dual Exhaust Intake Manifold BOV & Stage 1 Tune, 27mm Racing Beat Rear Sway, Proforged Rear End Links, Ultra Racing Strut Tower brace & E-Focus Mount/ '04 V70 2.5T Ruby Red - IPD Upgrades (wife's car)/ '07 S60 2.5T Barrent Blue (son's car) All: Mobil-1 synthetic @ 5K miles.
      Senior Member
      Jul 2007
      Hi. I'm really not the one to quote on the AWD S70s/V70CCs/XC70s - I know nothing about them except what I've read here on this forum. Someone who is more familiar with them should summarize the pitfalls!
      Best regards,
      glsable
      Jan 2008
      Sacramento, CA
      Re: S70, V70, V70XC Buying Guide: Links and Suggestions (glsable)
      Hi glsable,
      I appreciate your hesitation about the AWD/XC models, but so far, you are the only one with information that I have come across. If you find a direct source, please let me know. And, if someone else has something to add (or correct), I'll make the changes.
      Thanks for sharing your observations about cosmetic differences-- I'll add it to the top in a few minutes.
      As for the cup holders in the rear armrest, our 1998 S70 GLT has them, but I do not know if it is standard equipment. Anyone have any thoughts on this?
      Apr 2003
      Devon PA
      Quote, originally posted by glsable »
      Piece of pre cut tape, 4 bucks from Volvo
      Aug 2003
      Knoxville, TN
      Jan 2008
      Sacramento, CA
      Re: (MadeInJapan)
      Hi MadeInJapan,
      Glovebox pocket observation added above.
      Junior Member 1999s70's Avatar
      Sep 2008
      Pleasantville, NY
      Re: (volvie!)
      Hope this helps.
      Best regards,
      George
      1999 S70, Pewter, Non-Turbo, Auto Tranny, 530K miles, Original Owner, XemodeX ETM
      I'm not the fastest off the line, but if the race lasts a million miles I just might win.
      Jan 2008
      Sacramento, CA
      Re: (1999s70)
      Hi 1999s70,
      Thank you for sharing this information. I have quoted/added it above.
      Take care,
      volvie!
      Administrator chris@swedespeed's Avatar
      Dec 2000
      DC Metro
      Wiring diagrams in PDF format: ( the section listed as: Schematy elektryczne Volvotechinfo )
      2016 V60CC Platinum | Beechwood Brown interior swap | 20-inch Cratus wheels
      2016 S60CC Platinum with lowered sport chassis | Polestar Performance Springs |
      19-inch Polestar wheels | Elevate GT5 Exhaust, rear sway bar, brake lines, rear spoiler
      2017 XC90 Momentum Plus (family)
      Previous:
      2017 S90 Inscription T6 AWD, 2019 XC40 R-Design T5 AWD, 2017 V90 Cross Country T6 AWD , 2018 V60 Polestar #103/1500, 2016 XC90 R-Design, 2013 C30 Polestar #141/250,2015.5 V60 R-Design,1998 V70 T5M, 1999 S70 GLT, 2000 V70R, 2004 V70R, 2006 V70R Sonic Blue, 2006 V70R Electric Silver, 2007 V70R Passion Red, 2003 XC90 2.5T, 2007 XC90 V8 Sport Electric Silver, 2007 XC90 Sport V8, Passion Red
      Jan 2008
      Sacramento, CA
      Re: S70, V70, V70XC Buying Guide: Links and Suggestions ([email protected])
      Quote, originally posted by [email protected] »
      Hi [email protected],
      Great addition!
      I've added the link above.
      Take care,
      volvie!
      Re: (1999s70)
      The S70SE was available from start but only in Sweden/Europe at that time being (1996).
      The car came in several options:
      S/SE , 2.4L (2435cc) 144hp
      GLT, 165hp
      and a 2.4L (2435cc) lightpressure turbo, 193hp.
      T5 2.3L, 240hp
      In 1997 the S70R (your choice of FWD or AWD) was introduced with 250hp, and a new color was added: Saffron Yellow
      Member andyb5's Avatar
      Sep 2009
      Troy, NY
      Why was this un-pinned?
      1999 V70 R -- gone, but not forgotten.
      2000 V70 R -- 04 B5234T9 w/ 18T, Stevo tune, M66, CX Racing coilovers, 996TT front BBK. Always working on something...
    17. Remove Advertisements
