What did you do to your car today? - Page 353
    Page 353 of 353 FirstFirst ... 253 303 343 349 350 351 352 353
    Results 12,321 to 12,334 of 12334
    1. #12321
      Apr 2018
      Quote Originally Posted by davidw View Post
      haoef: RMM = ? could please provide Powerflex part number for the "small bushings form Focus st/rs". where do the "small bushings" go? thanks
      Hi, it's PFF19-1221, the bushing is located in rear motor mount torque arm.
      Nov 2003
      New Brunswick, NJ
      bushings
      Quote Originally Posted by haoef View Post
      haoef: thanks for the info. I was going to replace that bushing when I redid the entire suspension, but could not find comentary by anyone who had done that. its a shame to waste money to replace that large piece of aluminum when all you need is that itsy bitsy bushing. something else to add to my V50-to-do list. sheesh
      1994 850 wagon 5spd N/A
      2007 V50 T5 AWD 6spd
    4. #12323
      Aug 2019
      Ottawa, Ontario
      I forgot to take a pic of the new hardware, but I removed the old exhaust manifold heat shield bolts (they were in rough shape) and replaced them with new ones. The heat shield itself seems fine.
      I did this as I eventually plan to replace some parts that will need this removed, and thought I might as well get this out of the way while I have the time.
      Replacement part numbers:
      2 x 985661 - Long bolts for springs
      2 x 30713395 - Springs
      2 x 982793 - shorter bolts
      2010 V50 T5 AWD M66
      SwedeSpeed.com
      Aug 2019
      Ottawa, Ontario
      Washed and waxed. Needs some paint repair in a bunch of places..
      2010 V50 T5 AWD M66
    7. #12325
      Aug 2019
      Ottawa, Ontario
      Installed OEM rear spoiler thanks to the great guide in the stickies.
      2010 V50 T5 AWD M66
    8. #12326
      Junior Member LittleRedRidingHood's Avatar
      Nov 2016
      Kingston, Ontario
      Quote Originally Posted by sirloins View Post
      Looks great to me!
      2007 Volvo V50 T5 AWD M66 - Passion Red
      2006 Volvo S40 T5 AWD M66 - Titanium Grey
      Hilton Tuning Stage 2 ~ Mototec 3" Downpipe & Sport Exhaust ~ Do88 Intercooler ~ Snabb Intake Pipe
      RIP - 2007 Volvo S40 T5 AWD Geartronic - Passion Red
    9. #12327
      Jan 2009
      Took the Black Pegs off the V50 and put silver Pegs with new TPMS sensors. Black Pegs are for the V70 now.
    10. #12328
      Jan 2009
      Nice job!
    11. #12329
      Aug 2019
      Ottawa, Ontario
      Looks great J5T, I prefer the silver ones but they both look great.
      Today I installed the DO88 intercooler, put on my summer tires and changed the M66 Transmission fluid.
      2010 V50 T5 AWD M66
    12. #12330
      Jan 2009
      I put in the Do88 in the V50 2 weekends ago. I picked it up at EST when I was in Oakville to check out their new location. I asked about the IC and I just bought in on the spot. The instructions said there some things to trim but on my 2010 I didnít have to trim anything. The Do88 came in at 16.75 pounds and the OEM IC at 4.25 pounds. What a difference. I am just slightly ahead of you sirloins with the IC and winter tires. Behind you on the other maintenance. Keep up the good work.
    13. #12331
      Aug 2019
      Ottawa, Ontario
      Quote Originally Posted by J5T View Post
      Oh yes good point about not having to trim anything on the bumper. I also did not have to trim anything, I was careful re-fitting the bumper and wasn't seeing any interference. So for anyone else with a facelift model, maybe you won't have to trim anything either. I believe their instructions are for a 2005. Also the stock bumper bolt that you have to remove to install their bracket was 10mm IIRC not 12mm, not that it is a big deal.
      2010 V50 T5 AWD M66
    14. #12332
      Junior Member EricVolvoR's Avatar
      Feb 2017
      North of Montreal
      Love that red V50
      We dont have many V50/S40 clean as that here in Quebec
      Envoyť de mon iPhone en utilisant Tapatalk
      2007 M66 S60R Custom Interior, Custum Piggyback ECU (AEM Infinity). Project not done yet (In Progress)
      2010 M66 AWD S40 R Design
      D088 Intercooler, Viva Catback, Becker Dowpipe, K&N Intake. No Tune yet.
      Ceika BBK and Ceika Coilover
    15. #12333
      Junior Member edgar.a.montoya@gmail.com's Avatar
      Mar 2020
      Colorado
      In the process of upgrading/replacing the Turbo Control Valve and Turbo Bypass Valve on my 2008 S40 AWD T5. I knew it would be a bit of work, but it’ is quite a bit of work for a simple upgrade. I have not seen any write ups or -how to- on this, but it requires removing the passenger side CV Axle support bracket in order to access one of the bolts on the bypass valve. Plus it is very difficult to reach the connector on the exhaust of the turbo that the TCV hooks up to. It really requires some patience.
      Afterwards, I will install a bigger FMIC I bought on eBay for $75. Its suppose to be direct from a Ford dealer and OEM for the Ford ST. Hopefully it goes on without any issues. I‚€™️ll also be replacing the fuel pressure sensor and wrapping the turbo inlet pipe in heat wrap as well as the inter-cooler outlet pipe.
    16. #12334
      Aug 2019
      Ottawa, Ontario
      Installed some more parts I had around.
      Replaced accessory belts, tensioners and harmonic balancer. I used an impact gun to remove the 30mm bolt.
      I tried to change the gear oil in the angler/bevel gear. I didn't get much out so maybe I will try again later.
      Installed the last silicon hose from the IPD intercooler hose set, the hose that goes from the hard pipe to the turbo. Still using the original hard pipe, but I had previously sanded and painted it to get rid of rust.
      2010 V50 T5 AWD M66
    17. Remove Advertisements
