Cabin air filter writeup
    Page 1 of 5 1 2 3 4 5 LastLast
    Results 1 to 35 of 162
      Senior Member mattdoc's Avatar
      Oct 2007
      Here's how I replaced the cabin air filter. It took me 60-70 minutes; this was the first time I did it. This was definitely designed for a right-hand drive vehicle! I removed my floormat, slid my driver's seat back all the way, and tilted my steering wheel up to give me all the room possible.
      1. Go out and buy 3 M6-1.0 nuts to replace the gas pedal lock nuts with.
      2. Torx 25 3-places, remove cover below steering column. Requires first popping off panel to its left (the one with the rubber air vent that touches the door) and the panel behind the radio screen (panel is about 12x8") first.
      Disconnect the floor light wire and the other one up between the steering wheel and radio if you have it. I think that's for the interior temperature sensor, so you might not have it.
      3. Remove the 3 bolts that hold the gas pedal to the firewall. One is at its bottom left, the other two are up top. I got at them with a 10mm deep socket 1/4" drive, u-joint, and 10-12" extension to a ratchet. You'll want the extension long enough to get your ratchet past the pedals. The lock nuts are the hardest part of this whole job. That's why you bought 3 non-lock nuts to replace them with, right?
      4. Some say disconnect the gas pedal wires and remove the pedal. I didn't want to break the clips so I just zip-tied it to my clutch pedal to get it out of my way. It was still in my way a little bit, but it was manageable. If you know how to undo the clip, go for it, it will help a little.
      5. Roll the carpet down a bit by the filter. Using a 7mm socket, remove the filter cover. Pull the filter out and watch leaves fall everywhere. Brush the edge of the filter compartment out with your fingers in case there's a little bit of gunk left.
      Old filter coming out:
      My carpet was clean when I started; this all came out of the filter/housing:
      6. Put your new filter in. It requires some cajoling of the filter. Squish and bend it a bit; the corrugated design allows it. Once in, replace cover plate. From Tom: "The direction of the air flow is indicated on the top of the filter. Ensure that the filter is installed with the text side facing up and so that the arrows on the filter point straight back into the vehicle."
      7. Reattach gas pedal with new non-lock nuts. Reassemble panel covers.
      Some of the tools I used:
      Modified by mattdoc at 6:10 PM 4-12-2009
      Junior Member AlaskanAWD's Avatar
      Feb 2006
      Eagle River, Alaska
      Re: Cabin air filter writeup (mattdoc)
      Excellent writeup and pictures, thanks! We have heard nothing but complaints about how hard it is to change this filter, but nobody took the time to take pictures and provide step by step instructions for over 4 years.
      2005 S40 T5 AWD, Barents Blue W/Silver Hood, Roof and Trunk, IPD Pegasus R Wheels, BFGoodrich g-Force COMP-2 A/S & Bridgestone Blizzak's
      200,000+ Alaskan miles and counting
      Global Moderator tmtalpey's Avatar
      Jun 2004
      Eastern MA
      Stickied! Thanks.
      SwedeSpeed.com
      Oct 2007
      Can someone confirm the air flow direction is supposed to be from front to rear? The one I took out was like that, so I followed its lead.
    7. #5
      Member
      Jul 2008
      Morristown, NJ
      Re: (mattdoc)
      I thought the cabin air filter was on the right side of all Volvo's. Hmm.
      2015.5 XC60 R-Design
      Black Metallic, Platinum, Climate, BLIS
    8. #6
      Member -ForceFed-'s Avatar
      May 2008
      Bellingham, WA
      Re: (vivek9856)
      Volvo pulled a smartypants and made the S40's cabin filter accessible for a RHD car, and for some reason didnt bother to correct it in the 05+ model years lol. The air flow direction should face forward if i remember correctly.
      Current: 11 ISF | P2 V70R
      Past: 14 C300 AMG Sport+ | E46M | S40 T5 | NA1 NSX | Acura TL | LS-T DC4
    9. #7
      Junior Member Volvo S 40's Avatar
      Dec 2008
      Thanks for the procedure. Why do they have to make it so dam hard to replace the cabin filter.
    10. #8
      Jun 2004
      Eastern MA
      Re: (mattdoc)
      Quote, originally posted by mattdoc »
      Correct, air flow is toward the rear.
      From the book:
      Installation
      Installing the passenger compartment air cleaner (ACL)
      Note! The direction of the air flow is indicated on the top of the filter. Ensure that the filter is installed with the text side facing up and so that the arrows on the filter point straight back into the vehicle.
      Install the air filter by compressing it slightly and inserting it behind the brake pedal.
      Clamp the cover in place at the rear edge. Screw the cover into place at the front edge using the 3 screws.
      Fold back the carpet.
      Install the accelerator pedal (AP).
      Tom.
      2005 V50 T5 AWD 6MT w/Heico tune, Heico exhaust, Bell intercooler, IPD TCV, Viva Forge CBV, Elevate rear swaybar and torque mount, Snabb shift kit, etc.
      2016 XC60 T6 AWD
      1956 PV444 complete, running
      1956 PV444 very original, very rough
    11. #9
      Oct 2007
      I don't know if I put the text up or not. Looking at the one I removed, there does not appear to be much of a difference if it were flipped. I highly doubt an upside-down filter would harm anything, but am I wrong?
    12. #10
      May 2008
      Bellingham, WA
      Re: (mattdoc)
      Im sure it would probably filter the same but may not allow as much cfm's as the filter design was attended to allow.
    13. #11
      Junior Member Ride S40T's Avatar
      Feb 2006
      OK
      Freakin' awesome mattdoc! Thanks for saving the rest of us much time and frustration.
      Hers: 2013 C30 T5 / Polestar Limited Edition / 6M / #147 of 250 / Rebel Blue
      His: 2018 V60 T5 Dynamic / Passion Red / Vision & Tech Pkgs
      Son's: 2005 S40 T5 / Passion Red / Dynamic Sport / IPD Stuff (He will never part with)
      Son's: 2018 V60CC / Denim Blue / Vision Pkg
      In the past: 2016 XC90RD / 2015 S60RD / 2012 S60 T5 - Loved them all!
    14. #12
      Jan 2009
      I've still got no idea where this filter is really. I'm on a Right Hand Drive version of this car.
      Is the filter placed in the same position in the Right Hand Drive S40?
    15. #13
      May 2008
      Bellingham, WA
      Re: (Jonz)
      Perfect! Ive always wanted to ask how it is for a RHD car. It should be in YOUR passenger side as they did not change the filter placement. Pull your passenger side panels and it should be very easy to access.
      Ive been told the system was designed for a RHD car as its easily removable however choose not to correct the placement for LHD cars due to cost.
    16. #14
      Jan 2009
      Is there anything i need to remove? The passenger side panels - do I just pull it out? Any tools involved?
      I'll have a go at it soon once i'm sure of how to remove the side panels.
      I did try to locate the filter once before but I have no idea where it was and I found some sort of fuse box instead which was placed somewhere under the glove box area.
    17. #15
      May 2008
      Bellingham, WA
      Re: (Jonz)
      That would be the CEM, the tools that you would require would be a T25 torx for any screws you come across otherwise should be fairly easy to remove the panel and look up underneath the center of the dash where the filter sits.
    18. #16
      Member Veefifty T5AWD's Avatar
      Feb 2009
      Lakes Region NH
      Yeah, I had to laugh...I wet to the dealer to grab a filter to do this today...got to the cashier, $27! 27 freakin' bucks for a regular filter, not even the charcoal one! I took it back to parts and told them I could get one from ipd for $10.
      Logan
      2015 S60 T6 AWD R-Design Polestar
      2008 S40 2.4i - hers
      Former:
      2013 C30 Polestar Limited Edition #87/250 | 2005 V50 T5 AWD | 1995 Yellow 850 T5-R
    19. #17
      Member V50_T5's Avatar
      Jun 2005
      Schweinfurt, Germany
      Re: (Veefifty T5AWD)
      thanks for the write up, and I'll have to look into the $10 IPD one, I for one love to save money, but with Asthma, I need to replace this cabin filter soon
      For Sale, my 05 V50 T5 $11,900 obo. Colorado Springs !
      https://forums.swedespeed.com/showthr...lorado-Springs
    20. #18
      Feb 2006
      OK
      Re: (V50_T5)
      $10 at O'Reilly too.
      I am now a world class gymnast. Had to be to put this thing in. Took right at an hour. Would have been less but took a little time to find the right combo of extensions, etc.
      No arrows for airflow direction on filter (MicroGuard). One side was darker than the other. Would think the white side (looked to be a cotton mesh) would be toward the front to catch the air/dust first? Put the darker charcoal on the back closest to the cabin.
      Used the same lock nuts on the accelerator pedal. By far the most difficult part. Didn't have the third 7mm screw in the top of the filter door...didn't look like there ever was one...no markings of previous removal. Who knows if they ever replaced this thing during the free service period. Sure looked undisturbed.
      Would add one more tool - a thick towel to cover the seat rails, they chewed my ribs up.
      Modified by Ride S40T at 3:20 PM 4-14-2009
      Modified by Ride S40T at 4:53 PM 4-14-2009
    21. #19
      Nov 2009
      Re: Cabin air filter writeup some additional pictures and info
      I have two photos to add.
      As a new member perhaps I do not have upload privileges....
      One interesting thing - my wifes 2008 did not have the three 7 mm screws holding the cabin filter door closed.
      Instead there was only one screw that had a white plastic head on it shaped like a wing-nut. This was easy to unscrew by hand.
      Regards,
      Josh
    22. #20
      Member chromecarz00's Avatar
      Aug 2007
      Orange County, CA
      Re: Cabin air filter writeup some additional pictures and info (unclejosh)
      Quote, originally posted by unclejosh »
      Regards,
      Josh
      You have to upload it to a photo sharing source, such as photobucket then use the image codes.
      Welcome!
      a car.
    23. #21
      Nov 2009
      Re: Cabin air filter writeup some additional pictures and info (chromecarz00)
      Thanks chromecarz00 !
      Panels to remove and throttle pedal module:
      Bad boy is tucked up in here:
      Note small screw that removes cabin filter door. I guess this is a latest rev. - definitely better than the three 7 mm screws.
      Here is a link to the images on Picassa if these expire on ImageShack:
      http://picasaweb.google.com/Tu...tlink
    24. #22
      Member Vash13's Avatar
      Sep 2007
      Vancouver BC
      IPD website lists two pollen filters. Does it matter which one to get? The IPD one is more expensive than the OEM one. What's the reason?
    25. #23
      May 2008
      Bellingham, WA
      Re: (Vash13)
      I assume they list a standard and a multi pollen filter. Ive never seen a S40 use a multi filter other than some canadian cars but was unable to verify if it was even original or not. The multi filter is supposed to filter out particulates and pollen better.
    26. #24
      Nov 2009
      2 filter types.............
      They offer a filter with activated carbon - that may be the more spendy one.
      We sourced ours through through Napa - 35.00.
      Not the carbon one, lacked OEM filter foam on edges.
      I cut the edge foam off the old filter and affixed it to the new one with double sided take.......
    27. #25
      Great documentation!!!! I just did this on my 2008 s40 2.4i and it worked perfect. Only change would be on the job I did you don't need to go out and get replacement nuts for the gas pedal. Mine were not locking nuts and I was able to reuse them. Other than that Thanks so much.
    28. #26
      May 2008
      Bellingham, WA
      Re: Cabin air filter writeup (fleetingfunds)
      Thats correct, they changed the nut design due to the studs actually being pulled out while trying to remove them. Better yet, even later models now just have a wing nut on the filter cover than the 7mm screws
    29. #27
      Junior Member heico2.4i's Avatar
      Oct 2008
      Miami, FL
      Doing this is a pain in the ass and I will never do it again lol
      Volvo S40 2.4i / Premium Audio / Triple 10" MTX Sub enclosure / Eibach Pro Kit w/ Koni Yellows / IPD Rear Anti-Sway Bar / Akebono brake pads / K&N Drop in Filter.
    30. #28
      May 2008
      Bellingham, WA
      Re: (heico2.4i)
      More times you do it the easier it gets haha. I think I can do them in like 8 minutes I think now
    31. #29
      Sep 2007
      Vancouver BC
      Re: (ForceFed Motorsports)
      Quote, originally posted by ForceFed Motorsports »
      lol.. now I know who to go to when I need my changed
    32. #30
      May 2008
      Bellingham, WA
      Re: (Vash13)
      Not a problem, hit me up whenever.
    33. #31
      Oct 2008
      Miami, FL
      Re: (Vash13)
      Quote, originally posted by Vash13 »
      I will seriously drive all the way out there to bail on the install of the CAF... that and have Kyle turn off my DRLS... and activate my foglights... which i happened to have misplaced the codes again.... kyle lol
    34. #32
      Junior Member locutist's Avatar
      Feb 2007
      Grovetown, GA
      Re: (heico2.4i)
      I just did mine today. Why do the studs have to be so dang long? Don't know if I have the strength to put it back on. My wrist is in pain. I suppose I can take a 5min break and get back at it.
      2005 V50 T5 6-Sp Manual: Flint Grey Metallic- 20% Tint all around | 16" Caligo Alloy Wheels |Premium Sound System w/ 6-Disc CD Changer and Zune Media Player |De-badged Rear Hatch | E-Code Head Lights with 4300K H7 bulbs and Philips Silver Vision Turn Signals |Roof Spoiler |Dubstop black mesh grill w/ Heico Emblem | European Spec Wide Angle side view mirrors|America's answer for the MarkII Focus|
    35. #33
      May 2008
      Bellingham, WA
      Re: (heico2.4i)
      I can look em up again, just let me know which ones you need. Fog application and DRL right?
    36. #34
      Oct 2008
      Miami, FL
      yeah lol sorry man
    37. #35
      May 2008
      Bellingham, WA
      Re: (heico2.4i)
      DRL removal: 30679690
      Fog app: 30722 466 (manual level control)
    38. Remove Advertisements
