What did you do to your car today? - Page 323
    Page 323 of 328 FirstFirst ... 223 273 313 319 320 321 322 323 324 325 326 327 ... LastLast
    Results 11,271 to 11,305 of 11461
    1. #11271
      Jul 2015
      Charlotte, NC
      That’s from a P2 S80 2.9 NA.
      2000 V70R Venetian Red/Charcoal M56 Swapped 195k
      2003 S60 2.4T Silver/Black 112k
      1991 944 Turbo B230FT/AW70 173k
      1992 245 some of a B230F/AW70 249k
      2007 XC90 V8 AWD Sport Titanium Grey/Black 165k
      Sold-
      1998 V70 GLT Black/Beige 193k
      1998 S90- Silver/Gray 207k
      1995 850 GLT Tropic Green... crushed
      1993 944 B230F/AW71L 221k
      2000 S70 GLT Silver/Taupe 253k
      2001 S60 2.4T Black/Black 230k
      1988 744 Turbo M46 Beige Metallic/Beige 188k
      Need used parts? PM me!
      Member zmarshm1's Avatar
      Mar 2019
      Binghamton NY
      Well I was boosting around a few days ago and noticed smoke coming from the underside of the turbo heat shield,
      today this happened
      hoping it's the turbo lines/seals and not a head gasket. A/c wasn't on so I don't think it's the evap. I was not getting rising coolant levels, milky oil, or bubbles in the coolant before any of this.
      ||1998 s70 t5m - Stock, future gambler 500 car | 140k? miles
      ||2001 v70 t5 - IPD Sway bars | Delrin subframe bushings | Transmission cooler & mounted inline filter | Rostra long snout transmission solenoids | IPD catback exhaust & Rolling Motors 3" downpipe | Simota Carbon Charge Intake | Bilstein B4 & Eibach prokit lowering springs | 124k mi
      ||2003 v70 2.4t - First volvo | SOLD! Still driving around with 190k+ miles.
      Kanjo!!
    4. #11273
      Senior Member ScottishBrick's Avatar
      Dec 2014
      Connecticut
      Quote Originally Posted by andyb5 View Post
      It would also be an easier option to modify for a 5 cyl. RN to use a larger plenum and relocated ETM to simplify the IC piping design. Interesting, should be fun to see where you go with that Will.
      The manifold runner is from a P3 V70 with the I6?
      Variant of the 2.9 intake design. This is for a friends B5234T9 swap into a 98 T5M and he wanted to play witn intake setups so its gonna get a large log plenum welded on and then have the fuel rail anchor posts moved and rewelded.
      2003 V70 T5 - Mystic/Graphite - M56LK - 206k - K24/Greens/Do88/Quaife/SMF/P2R Clutch/DW300C/H&R/Bilstein TC/316mm & 308mm Brakes - SteveO Tuned
      1999 V70 T5 - Pewter/R Graphite & Alcantara - AW42 - 299k - Daily/Work Wagon
      1999 V70 T5 - Nautic/R Graphite & Alcantara - M56H - 177k - Rescued
      1999 V70 T5 - Emerald/Graphite - M56H - 119k - Garage Queen
      2000 V70 T5 - Mystic/Graphite - AW42 - 243k - Moms Unicorn
      2000 S70 GLT SE- Mystic/Graphite - AW42 - 218k - Sisters
      SwedeSpeed.com
      Jul 2015
      Charlotte, NC
      Quote Originally Posted by zmarshm1 View Post
      today this happened
      I'm betting your coolant drain hose let loose. As long as you didn't overheat it, I think you'll be alright!
      Time to order some silicone turbo coolant hoses to go with those silicone radiator hoses you just bought from me
      Quote Originally Posted by ScottishBrick View Post
      That'll be a cool setup. I'm interested to see how it goes.
      Sold-
    7. #11275
      Member andyb5's Avatar
      Sep 2009
      Troy, NY
      Cool, Iím excited to see how it turns out
      1999 V70 R -- gone, but not forgotten.
      2000 V70 R -- 04 B5234T9 w/ 18T, Stevo tune, M66, CX Racing coilovers, 996TT front BBK. Always working on something...
    8. #11276
      Sep 2009
      Troy, NY
      Quote Originally Posted by cbblunk View Post
      Yeah, should have clarified. Stoptech 309 pads. I'll follow suit as in your thread and clean the wheels to evaluate dust.
      Do you do any quantitative measurements on pad performance or just your impressions? I'd imagine there has to be an app that can give braking times/distance etc. Not as experienced with everything as a lot of you.
      Iíve had Stoptech 309s in my Porsche Brembo bbk for the last year. Theyíre a great daily performance pad. Not quite as dusty the Porterfield R-4S I ran previously, but quieter and better when cold.
      I havenít wrung the 309s out as hard as the R-4S yet, but they were fine with a dozen repeated 90-20 mph panic stops without fade when I was bedding them in.
    9. #11277
      Senior Member JaredR's Avatar
      Jan 2014
      Boston, MA
      Subjective feel. I would like to be more scientific but I need to dump these PZero AS+ and mount the Powerproof before I have tires good enough to really make the data useful.
      1995 850 T-5R Estate. AW50-42LE. Cream Yellow/Graphite. 297k.
      1997 850R Estate. B5234T9/M66D. Bright Red/Graphite. 270k.
      2007 S60 T5. M66W. Black Sapphire/Arena. 140k.
      Instagram: Jared's Volvo Page
      Past: |1997 855R. Bright Red/Light Beige. AW50-42LE. Totaled by wayward construction equipment. || 1996 854R. Black Stone/Graphite. AW50-42LE. Parts car || 1995 854 TURBO. Polar White/Tan. AW50-42LE. Parts car. |
      Dad: 1997 V70 T5 SE. AW50-42LE. Frost Green/Oak. 212k.Mom: NEW! 1999 S70 GLT Pewter/Oak. 101k. Past: 2004 V70 NA. AW55-50SN Ruby Red/Tan 269k. Sold to markj
    10. #11278
      Apr 2014
      Quote Originally Posted by JaredR View Post
      Definitely feels much firmer than OEM Volvo. Have not pushed it hard enough to hit abs or lockup, but definitely feel more G forces when I push hard.
      More data to compare. Have Akenobo on the rear with OEM 00R rotors. 2018 dated Zlines all around, SS flex lines all around.
      Under 100 miles so far, but no increase in noise or vibration.
    11. #11279
      Mar 2019
      Binghamton NY
      Quote Originally Posted by bmdubya1198 View Post
      Hope so! Itís getting looked at Monday and getting the pcv done too. It was burning a lot of oil so hoping itís all fixed when I get it back. And thanks again !
      Kanjo!!
    12. #11280
      Jul 2015
      Charlotte, NC
      Any time!
      Sold-
    13. #11281
      Jul 2015
      Charlotte, NC
      Oh joy... the padding is absolutely SATURATED.
      Iím gonna pull the cowl and check the drains near the fuse box tomorrow, but are my shifter cables too close to the AC drain? Itís a little wet around the base of that hose, but it doesnít seem to trail down the foam. Itís only on the bottom on the floor, only up the side on the left by the door. And even so, itís only maybe an inch up the side.
      Cleared the sunroof drains the other day, and they seem to be draining fine when I pour water down them. All this rain weíve gotten has been hell on all my cars... burned out the amp in my E90, now I have a stiff clutch pedal after driving through a puddle in this car yesterday.
      Plus Iíll probably have to pull the carpets in my E39 too. Iíve got at least two water leaks in that car.
      Sold-
    14. #11282
      Oct 2009
      I just ran into this issue as well, kind of. I had these pads saturated in coolant years ago when my heater core let go. I though I had dried them out sufficiently but apparently not, its now years later and I removed the dash to fix some cracks and give the whole interior a clean. That's when I found the rust on the drivers floor board, it was pretty bad. This photo shows it post grinder
      I cut the foam up close to the pedals and down the center tunnel to get it out of the car. Then I peeled the top rubber layer off of the foam and cleaned everything in car wash soap and used a large roller (like a rolling pin) to squeeze as much water out of the foam as possible. Two days sitting out in the sun and its all dry and smells so much better than it did before.
      20200526-165025
      20200526-165731
      I wish I could point you to where your water might be coming in, but I haven't the foggiest. Have you tried setting up a garden hose to spray water at the car while your in it to pinpoint where the water it coming in from?
    15. #11283
      Jul 2015
      Charlotte, NC
      I havenít tried that yet, I felt like it was too slow/small of a leak to show much. But with the insane amount of rain weíve had this past week or two, who knows. Iíll just be happy to get in the car and not have it steamy/moist. It doesnít smell bad or anything, but I just despise humidity.
      Fortunately the car passenger side carpet feels dry.
      I did the same though, cut it right below the pedals and on the side. On the tunnel the foam feels dry, so thatís a good sign. Itís also dry up higher behind the pedals.
      I really think itís that fuse box drain that Iím just now hearing about all over the place.
      Thank goodness my floor hasnít developed any rust yet! Very little standing water, dried it with a paper towel and vacuumed up all the crumbled pieces of the rubber liner and carpet backing.
      Sold-
    16. #11284
      Junior Member 850 GLT's Avatar
      Jan 2004
      Barrie/Ottawa, Ontario
      1998 Saffron/Charcoal C70 GT, 1998 Saffron/Charcoal V70R AWD, & 1998 Black/Charcoal V70R AWD
    17. #11285
      Jul 2015
      Charlotte, NC
      Quote Originally Posted by 850 GLT View Post
      Which system did you go with?
      And damn... those nebulas look so good!
      Sold-
    18. #11286
      Jan 2004
      It's custom.
      3" in to single Magnaflow muffler to dual 2.5".
      Bought locally from a private seller; full stainless, whopping $250 CAD cat-back.
      It's quite deep in tone, no rasp at all. Bit of drone when starting, but completely silent at 30-40mph and 50-60mph.
      The car finally has a voice now after all the years of the dual 98 mufflers.
    19. #11287
      Member CYB3RBYTE's Avatar
      Oct 2016
      Milwaukee, WI
      Does anyone have some good suggestions as to what material to replace that foam with if it was too destroyed to dry out?
      In the Garage
      Viveka / 1996 850 N/A, Polar White + Oak / 135,5xx /
      Quicksilver / 2011 C30 T5 M66 / Silver Metallic + Off Black / 91,6xx
    20. #11288
      Apr 2014
      It's custom.
      I'd be curious to hear the sound. I'm thinking of having something made up from a local shop.
    21. #11289
      Oct 2009
      Quote Originally Posted by CYB3RBYTE View Post
      It won't be. That is to say mine was really really bad, torn into 4 or five different jig saw looking pieces. I just washed, cleaned and dried them out as separate small foam pieces and they all just fit back together in the floor board. The weight of the rubber mat and carpet will keep in all in place.
      You could always try to hit up a junk yard or find someone with a parts car for a better used foam pad. They are molded to the floor pan so going aftermarket with just a flat piece of foam might make the carpet sit odd.
    22. #11290
      Jan 2014
      Boston, MA
      I agree ^
    23. #11291
      Dec 2015
      SLC Utah
      Damn thats a pretty wagon !
      01 S60 T5M Black, middle sons
      00 S70 GLT Black, youngest sons
      01 E46 325 XI Touring Silver, Wifes, totalled, bought back, repaired
      00 S70 GLT5 SE Moondisaster, T5 Swap, MINE !
    24. #11292
      Jan 2004
      I don't have any videos of it from outside, so I guess this will have to suffice for now.
    25. #11293
      Oct 2014
      Well I had to let the wife start driving my 2000 V70r (weekend run around ride) because she sold her Lexus yesterday. Been trying so hard to get her to like a new Volvo, even told her that we can do overseas delivery and take a trip. But the damn neighbor down the street brought over his buddy's Jeep Gladiator Rubicon this weekend and she wants one of those now. Now she is going to drive the R until she finds the right Jeep.
    26. #11294
      Dec 2014
      Connecticut
      Quote Originally Posted by Jaydiesel View Post
      Well thatís fixable:
      https://m.youtube.com/watch?v=zNHsE1wpqb4
    27. #11295
      Jan 2014
      Boston, MA
      Let's compare:
    28. #11296
      Jul 2015
      Charlotte, NC
      Got the carpet back into my car today, I had a good one without a hole in the corner from my cousin's old parts car, so I went ahead and put that one in. The weather has been sunny and dry the past few days (finally) so the foam dried quickly.
      Turns out the leak was the plugged up drain in front of the fuse box under the cowl. Cleared that out, hopefully my floor stays dry.
      Sold-
    29. #11297
      Global Moderator R-Pow3R3d's Avatar
      Apr 2015
      Pittsburgh, PA
      I'm starting to understand better why so many people add those stickers to their Jeep...
      2004 V70R MT TiGray/Nordkap - Replica 18" Pegs - Handbrake Mod
      2007 XC90 V8 Sport Passion Red/Off-Black - Serpentine Belt, Tensioner & Idler Pulleys - Spark Plug Replacement - Y-Pipe Replacement
      1990 745 Turbo Intercooler White/Beige
      2007 XC70
      VIDA/DICE Owner - SS Lurker Since 2009 - '06-'07 Transmission Valve Body Info - SR/VR Failing Throttle Body
      Current Non-Volvo: 2007 VTX 1800 F3, 2002 VT750DC
      Previous: 2006 S60R
    30. #11298
      Jul 2015
      Charlotte, NC
      Those engineers have some Ďsplaining to do.
      Sent from my carrier pigeon
      Sold-
    31. #11299
      Apr 2015
      Pittsburgh, PA
      2007 XC70
      Previous: 2006 S60R
    32. #11300
      Oct 2014
      Awesome guys for the Jeep stuff. Totally forgot about the Jeep flipping over during the lastest crash test. "Oh honey, check out what a Jeep can do to its self "
      Also I can't believe how expensive they are. For really nothing luxurious. My 2017 Chevrolet 2500Hd with a diesel is more expensive on the window sticker but with all the discounts I paid less than a Jeep Gladiator with discounts is going for.
      I been pushing for a Xc60 T8 too for her, but she wants a work truck/suv.
    33. #11301
      Dec 2015
      SLC Utah
      Agreed, i was stunned to see the price of the Gladiator Rubicon. All plastic, small bed, no advanced engineering or creature comforts. If she's really stuck on it....see if you can get a dealer to let you drive one for the weekend. After driving a lexus, she will more than likely hate the stiff bumpy ride of a Wrangler with a bed.
    34. #11302
      Jul 2015
      Charlotte, NC
      Wranglers already ride like crap from what I've heard, I could imagine how bad a pickup version would feel!
      Sold-
    35. #11303
      Mar 2019
      Binghamton NY
      I think an xc90 would work for a work suv
      Kanjo!!
    36. #11304
      Apr 2014
      Nice... definitely hear a little more growl from the cabin. I'm sure it would be better if I wasn't listening on my phone. Probably doesn't do it justice.
      Do you still have VC etc in? Does the single muffler sit behind the rear subframe under the spare tire area?
      Definitely would be cheaper to do one muffler and dual outlet!
    37. #11305
      Dec 2014
      Connecticut
      I have it on good authority (tech & parts ppl at chrysler) that the front half is wrangler and the rear is literally a 1500. The parts catalog says something along that lines for look up.
    38. Remove Advertisements
