OEM Side Markers with Harnesses
    Results 1 to 3 of 3
      Member washdup's Avatar
      Apr 2007
      Ventura County, CA
      Euro Side Marker Lights with Wiring Harnesses
      SOLD Pair of white side markers lamps, with wiring harnesses. Easy-to-do upgrade for 850's and early S/V70s. IPD sells just the lights for $94, plus $48 for the wiring harnesses. Easy instructions on the IPD website. Take these for only $40 shipped CONUS.
      From IPD's website:
      "Adding visibility to your Volvo is easy with original European Volvo turn signal indicators. The mounting hole is already stamped into the fender so there is no drilling required. All you have to do is remove the Volvo emblem and adhesive on the fender and you’ll find the odd shaped hole that was originally intended to accept these nifty European turn signal indicators. Very simple two-wire hookup using the wiring kit." Instructions here: http://www.ipdusa.com/uploads/...T.PDF
      Modified by pelicanflyt at 7:03 AM 9-12-2009
      Modified by pelicanflyt at 6:57 AM 9-15-2009
      1998 V70 T5m @200k miles; 18t, turboback, Quaife LSD, Koni FSD/Eibach, IPD sways, DO88 I/C, SNAAB intake, ARD Blue, greens, etc., 50% E85
      1995 850 Turbo Sold at @168k miles.
      2004 V70R 6mt SOLD in 2008
      Apr 2007
      Ventura County, CA
      Re: OEM Side Markers with Harnesses (pelicanflyt)
      Price drop--$40 shipped CONUS.
      Apr 2007
      Ventura County, CA
      ttt
