D2S HID retrofit, E46 projectors, Matsu****a Ballasts, Morimoto 5000K, 35W - Page 6
    Page 6 of 6 FirstFirst ... 2 3 4 5 6
    Results 176 to 206 of 206
    1. #176
      Member -ForceFed-'s Avatar
      May 2008
      Bellingham, WA
      Re: Re: (theshadow27)
      Quote, originally posted by theshadow27 »
      They are literally cheaper than Silverstars.
      Can thank bulk orders from china for that haha
      Current: B9 SQ5 | P2 V70R
      Past: 11 ISF | 14 C300 AMG Sport+ | E46M | S40 T5 | NA1 NSX | Acura TL | LS-T DC4
      Dec 2008
      For the record, there is no such thing as a 55w HID bulb. All bulbs sold for/with 55w kits are the same as the 35w bulbs... Rebased D2S. The difference is only in the drive current (from the ballast).
      That means that running a bulb at 55w will shorten it's life, but at DDM's prices, who cares? They are literally cheaper than Silverstars.
      Second that. Had to order my (55W) bulbs of a different color from sharphids, had a friend gave me 55w ballasts. Only one type of bulb for both 35w and 55w available.
      Used Dension GW500 for sale, free test and installation in Los Angeles area. S40 T5 sold.
    4. #178
      Junior Member mikamars's Avatar
      Jan 2010
      Re:
      I made my shields, but I don't really understand the results:
      Why is there yellow in the middle?? Here's my shield:
      My shields are working great with main beam solenoid controllers though:
      Any suggestions why there's yellow in the middle? I didn't really get the nice cutoff color either
      SwedeSpeed.com
      May 2008
      Bellingham, WA
      Re: Re: (mikamars)
      Quote, originally posted by mikamars »
      In this picture you see the screw their on the right side? By backing that out you can increase your color. Also the further you move the shield upwards the more the hot spot (the yellow) is covered and brings out more of the blue/purple.
      You using the clear lenses or the factory ones?
    7. #180
      Jan 2010
      Re: Re: (ForceFed Motorsports)
      I noticed that screw but didn't really think about adjusting it. Thanks for the tip I might have to adjust the shield a bit more upwards too. I'm using ZKW-R clear lenses.
      I guess I'll settle with a straight line for the cutoff. It's way easier.
    8. #181
      May 2008
      Bellingham, WA
      Re: Re: (mikamars)
      Back that screw out and pull the shields up just a bit. You will see the hot spot when the lights are just a few yards away against a wall. But once you get a decent distance away it should be solid blue
    9. #182
      Jan 2010
      I didn't notice any hot spots when using E46 projectors without the shields. It might be that they're just more obvious with the shields.
      I don't think I can adjust my shields without removing the projectors
    10. #183
      Member theshadow27's Avatar
      Sep 2009
      DC, USA
      Re: Re: (mikamars)
      I think Kyle adjusted the shields before he installed the projectors. That's what I would have done anyway...
      '05 S40 T5 AWD M66 sport/winter/ew. Michelin PS A/S+. 6000k 50w HID low/HIR1 high/full LED conversions. RiCA SW. Evoelate intake. IPD rear sway, skidplate, TCV.
      Writeups
      Full P1 (S40/V50/C30/C70) & P2 (S60/V70+R) LED conversion | P1 HID conversion & details | FM Modulators & interference | stalk cleaning | CEM Teardown
    11. #184
      Jan 2010
      Well, yes, that's what I did too I just adjusted them too low. The plastic against those screws is quite soft, and I don't think it'll hold up if the projectors are taken apart too many times.
    12. #185
      May 2008
      Bellingham, WA
      Re: Re: (mikamars)
      Yeah I got mine dialed in outside the vehicle. Pulled my car out of the garage and used the neighboring apartment complex to achieve my color lol.
    13. #186
      Member EngTech's Avatar
      Jan 2007
      Knight's of the Round Table - TN
      Re: Re: (mikamars)
      Looks Like very Good work , see You Guys got a Bunch of Snow .
      So is there a small slot behind washer to allow some movement?
    14. #187
      Junior Member ion's Avatar
      Jul 2009
      MD
      So... has there been any progress on replacing the stock halogen lenses with clear lenses? I'm about to order a couple lenses and get the job done this weekend. Do you guys have any pictures of the stock projectors so I can figure out what tools I'll need?
    15. #188
      May 2008
      Bellingham, WA
      Yeah actually I have a set of stock projectors with E46 clear lenses just sitting in a box. I started shield modding them and just never finished them. I know the clear lenses from retrofit source are a fudge too big but with slight modification fit.
    16. #189
      Jul 2009
      MD
      Yea? I'm thinking maybe the Mazda 3 lenses are a direct replacement. I sent them an email asking for more pictures/specs. Is the stock lens riveted in, and if so do you know what size rivets?
    17. #190
      Junior Member heico2.4i's Avatar
      Oct 2008
      Miami, FL
      Damn those look nice... my hid's are looking kinda greenish lately
    18. #191
      May 2008
      Bellingham, WA
      I've seen both ways, metal solder rivets and screwed. I have one of each. I planned to just use bolts to reinstall the lens holder to the projector.
    19. #192
      Jul 2009
      MD
      Picture of our stock projectors for anyone who's interested...
    20. #193
      May 2008
      Bellingham, WA
      Those stupid rivets are a biotch to drill out too. I got the holder removed but still need to finish drilling thru the projector side in order to apply some hardware instead. My E46's were removable which made adjustments super easy.
      Finishing those projectors is on my to do list now, trying to clear out some of my "stash" of parts. I always go all out and over order parts and then store the spares forever.
    21. #194
      Exclamation HID Retrofit
      Quote Originally Posted by -ForceFed- View Post
      Hey, I want to know how you did with the HID bulb and igniter? Did they fit allright? I'm doing a HID retrofit with E46 bosch bi-xenon projectors but I'm struggling with the space between the bulb and the rear cap! Could you help me please?
    22. #195
      Exclamation 2011 S40 HID Retrofit
      I'm struggling with the space in between the HID bulb and the headlight rear cap! Could someone help me?
    23. #196
      May 2008
      Bellingham, WA
      I had to modify the rear caps. I cut out a space for the igniter to protrude from the back and made an extended cover out of the square I chopped out using 5 minute epoxy to space it out.
      Should also be noted that the new Morimoto ballasts have a much smaller igniter which also helps.
    24. #197
      Oct 2015
      a
      Forcefed great write up. Am planning on doing the same on my bmw e46 compact. Can you please contact me on [email protected] thanks
    25. #198
      May 2008
      Bellingham, WA
      I'm on a number of the M3 forums. Find me
    26. #199
      Sep 2009
      DC, USA
      I fixed the images on photobucket with the intention of stealing some of them for the skbowe.com site - hopefully Kyle can around to updating the OP one of these days.
      Updated the initial post with all the pic progress I posted thruout this thread, for all the information regarding doing a retrofit I encourage you to read the thread, enjoy
      Beginning my HID retrofit today. Going to take more time than I thought as there is a lot more involved with tuning the HID output than expected. All parts ordered thru my friends at TheRetrofitSource.com
      Parts list:
      Matsu****a ballasts 35W setup
      Morimoto 5000K D2S bulbs
      E46 bi-xenon projector housings
      ZKW-R clear lenses
      H7 wiring harness converted to work with H11 setup
      The wiring harness only uses one of the low beam bulb inputs and then using a relay system attached to the battery runs an extension harness over to the passenger side ballast. An H11 harness kit wasnt available so a H11 female connector just needs to be swapped out for the H7 that comes with it.
      So far that ive seen today is due to only using one head light low beam connector connected to the harness theres a bulb out message. Have to figure out how to fake out the passenger side harness.
      With nothing installed into the head lights yet I took some comparison pics just to show the difference between a 55W DDM kit with 45000K bulbs and the 35W retrofit with E46 projectors and the factory lenses that came with them.
      DDM
      E46
      Will continue to update the thread as the project goes along. More than likely wont finish this weekend as I need some more supplies.
      By adjusting the cut off shield or the "shield mod" as they call it you can alter the cut off line color and clarity. Ill be using a roll of flashing to adjust and alter the output to my liking and then drill out the rivets that hold the RV shield on to mount it.
      I also have clear ZKW-R lenses to swap in which changes the clarity and output of the bulbs quite a bit. Did the one side but need to change how it mounts inside the projector a bit more. You can see the difference from the E46 lenses compared to the clears quite a bit just visibly.
      E46
      ZKW-R
      Stock projector to E46 projector comparison
      These are the shields that are required for the color modification. Used a roll of thin aluminum flashing and was cut with scissors.
      Final results with E46 projectors, ZKW-R lenses installed, Morimoto 5000K D2S bulbs, AMP adapters to DDM 55W ballasts.
      Here are the final results of the retrofit
      Modified by ForceFed Motorsports at 5:21 PM 12-1-2009
      Modified by ForceFed Motorsports at 5:23 PM 12-1-2009
      Writeups
    27. #200
      May 2008
      Bellingham, WA
      I'll get it fixed one of these days when I get some free time.
    28. #201
      Sep 2009
      DC, USA
      Lol just quote my post and paste the insides into the OP... 2 seconds.... I changed the URLs already.
      Writeups
    29. #202
      May 2008
      Bellingham, WA
      Oh right, fixed haha.
    30. #203
      Member LizardOfBodom's Avatar
      Aug 2016
      Rainy Island (aka Ireland)
      Just wondering, why the shield mod? seem to me that by doing it you are blocking a tiny bit more light and flattening out the cutoff line, why is that superior to leave standard shield shape? Is that because of US spec light cutoff requirements? in EU we must have -_-_ or \_\_ , flat line would not be conforming to any specs...
      Titanium Grey 2005 V50, T5AWD, M66, Stage 1 Hilton tune<-Click me
      E-Focus Torque mount, E-46 bi-xenon retrofit (see the PDF for pictures and full story) , de-nanny mod, Brembo discs+ATE ceramic pads
    31. #204
      May 2008
      Bellingham, WA
      I ended up stepping them afterwards. It took a couple tries to get the right step so it wasn't so extreme, but fine tuning the hot spot actually reduces some of the glare. These things were so bright that without shields they would have been a mess.
    32. #205
      Aug 2016
      ah ok, gotcha! I see you used 55W version, no wonder those were bright!
    33. #206
      May 2008
      Bellingham, WA
      Yep, and if I recall, I believe I eventually stepped down to a 35W ballast with the direct D2S connector. They were TRS latest design, not sure what gen they are on now. Last two vehicles I have owned since the Vo have had factory HID's, just required some minor upgrades
    34. Remove Advertisements
