What's the correct way, or does it matter?
    Results 1 to 6 of 6
      Member
      Aug 2008
      Scottsdale, AZ
      I'm thinking about my next steps in an attempt to get this engine installed this weekend.
      My question is related to mating the Auto tranny to the block. Does it make any difference if you mate the torque converter to the flexplate first bolting it in, or engage the torque converter to the transmission then mess with bolting it through the starter motor location?
      I've heard rumor that the pumps are touchy on how the torque converter mounts, I'd hate to screw up at this point.
      Thanks....
      '98 V70 T5 (Auto) Currently 427,000 miles on car, now my daughter's.
      '99 V70 T5 M Purchased from JRL: 207,000 miles. future mods coming
      2013 S60 T6 Rdesign Mine
      2016 XC60 T6 Rdesign Wife's
      Junior Member ewakefield's Avatar
      Oct 2009
      Arlington, VA/Ann Arbor, MI
      Re: What's the correct way, or does it matter? (Rsterns)
      I bolted the tranny to the block first. You don't have to bolt the converter up through the starter whole. There is an access whole on the tranny near where the passenger side axle goes in (I think there is a little rubber plug in it). WAY easier than through the starter.
      03 Maxima SE 6MT LSD Majestic Blue - whomp sauce!
      98 S70 GLT Classic Red - previous and missed
      Go Blue!
      Oct 2009
      Re: What's the correct way, or does it matter? (ewakefield)
      then again i could have done it wrong....
      Go Blue!
      SwedeSpeed.com
      Member LloydDobler's Avatar
      Aug 2007
      Littleton, CO
      I believe that because there's a snug fitting locating pin in the center of the torque converter, and locating pins on the bell housing, that it makes no difference which you bolt up first, it'll center itself either way.
      If you want to be sure, install with the TC on the tranny.
      2003 C70 T5M Convertible - Eibachs, Koni FSDs, Enkei RSF5s, OBX downpipe, Snabb intake, RIP kit, & drop-in intercooler, Quaife LSD, 19T, Green Giants, 22 psi Hilton tune.
      1966 122s - Collectible project, restoration and many mods on the way.
      2005 V50 T5 AWD - Daughter's first car. No mods unless she does 'em herself.
    7. #5
      Senior Member Chilled Man's Avatar
      Jan 2007
      Backyard of TMI
      Put TC inside tranny and make sure its sitting the whole way in .
      Then mount tranny to Engine .
      Then spin the enegine and or TC to mount that to the Flex plate.
      Doing this any other way will = busted TC and or Tranny
      /2006 S60 T5 /K24/R Calipers/17" pegs/OBX/Koni/Eibach/JVC/SNABB/IPDSway,
      /2004 V70 R/M66 /05+ Tails/ 05+ Console/Evolve Intake/IPD Sways/OZ/Kenwood/PHUZZ
      /2005 V70XC -Stock
      /2004 V70XC - Project Truk
      Unquestionable faith is the Epitome of Ignorance. - me
      That’s because you savagely dismember Volvos. That’s not ownership, that’s a serial killing kidnapper!
    8. #6
      Member
      Aug 2008
      Scottsdale, AZ
      Re: (Chilled Man)
      Quote, originally posted by Chilled Man »
      Thanks again Justin, that's precisely the way I intend to do it, hopefully over the next two days!
    9. Remove Advertisements
