Deflector v. no deflector
    Results 1 to 5 of 5
      Junior Member Duett's Avatar
      Dec 2001
      TX
      I have an S70 with the sunroof deflector accessory.
      Pros: blocks sun and wind, looks good
      Cons: blocks wind, squeaky, looks not so good
      1. Should I keep it or dump it?
      2. If i dump it, any suggestions for gently removing the weatherstripping adhered to the roof??? I'm concerned about using something too harsh.
      Senior Member JRL's Avatar
      Apr 2003
      Devon PA
      Re: Deflector v. no deflector (Duett)
      How long has it been on?
      I've found out with the used cars I buy that have had them on is that,
      1: the roof possibly has some minor dents where it was tightened down.
      2: paint is scratched under where it had been installed.
      If you have removed it and everything looks OK, you can use any medium strength solvent, carefully heat the glue (heat gun or a hair dryer) and roll it off with your fingers.
      After that, just use a LIGHT compound if necessary, polish and wax.
      JRL
      Email: jrl1194 ( at ) AOL (dot) com
      2007 V70 2.5T White/Oak/Tan/Arena, 116K miles. My DD with no plans to sell it anytime soon
      2000 V70R, Wife's, she won't sell. Now she hit 153,000 miles and still near perfect!
      Member S.R.'s Avatar
      Nov 2000
      Hampton Roads, VA
      I don't think that they look too bad, so if it was installed properly in the first place, I would just keep it on.
      My 2 cents...
      -Drew
      SwedeSpeed.com
      Junior Member R2 Rnot's Avatar
      May 2003
      I kinda like them but after a few years they tend to look scratched up after all the washes. Similar to the bug guards on suvs. You could either take it off or at least polish it up a bit with some plastic polish.
    7. #5
      Re: Deflector v. no deflector (R2 Rnot)
      Odds are good that the paint underneath the seal is damaged, especially on the front corners.
      I took mine off of the '99. Yes, the paint is damaged. I cleaned most of it up with Meguiar's cleaner and polish, but a good bit is still there. I prefer the way it looks without the deflector, even with the scuffs in the paint.
      [edit] Didn't answer your main question - the weatherstripping/seal just lifted off. It's held on by the brackets - the weatherstripping/seal shouldn't be adhered to the paint. If it is, peel very gently, possibly keeping it wet, and hope for the best. [/edit]
      Pat
      '16 V60 T5, '92 245DL, '15 Fit EX, '04 ML500
    8. Remove Advertisements
