What did you do with your s60 today? - Page 172
    Page 172 of 172 FirstFirst ... 72 122 162 168 169 170 171 172
    Results 5,986 to 6,010 of 6010
    1. #5986
      Junior Member Mario2hr's Avatar
      Apr 2015
      Zagreb/Croatia
      Today I finaly changed my steering wheel from leather to wooden.
      Attachment 62337
      VW Golf II - 1995-2000
      Audi 80 B4 - 2000-2003
      Suzuki Swift GTi - 2003-2008
      Audi A6 C4 - 2008-2014
      Volvo S60 D5 - 2014 and continue
      Oct 2016
      Guilford, CT
      For father's day the wife told me I could work on the S60 during the day instead of at night like usual after the kids are asleep. IPD adjustable toe arms going in!
      2013 XC60 T6: mom mobile
      2008 C30 T5 R-Design: dust collector
      2008 XC90 V8 Sport: the weekender
      2002 S60 T5M: the daily commuter slayer
      Past: 2007 XC70 Orca, 1999 V70 5sp, 2010 Mazda5, 2000 Audi A4 Avant 5sp, 1990 VW Fox 4sp
    4. #5988
      Member
      Apr 2015
      So Cal / Inland Empire
      Quote Originally Posted by LarryM View Post
      Super clean looking, especially with the iPD swaybar it looks like you have.
      Sent from my Huawei Mate 9 using Tapatalk
      2004 S60 2.5T - Stock for now...
      SwedeSpeed.com
      Oct 2016
      Guilford, CT
      Quote Originally Posted by Phixion View Post
      Yes, IPD bars front and back. This S60 was what I would describe as a sloppy drunk when I bought it a year and a half ago. After the sway bars, H&R springs, delrin subframe bushings, 18" sticky rubber and now the
      beefy toe arms this car is back on track.
    7. #5990
      Member
      Apr 2015
      That's quite a stable handling setup! How are the Delrin bushings? I need to at the least get my bushings replaced with some new OEMs... But debating on the XC heavy duty ones or just OEM and popping in the iPD poly bushing inserts for added beef which I already have a set of on hand...
    8. #5991
      Oct 2016
      Guilford, CT
      I had the Ipd poly ones in at first. Install was a total pia. Couldn't get 2 of them to seat all the way properly no matter how much grease I used.
      It was an improvement over stock though.
      Then I picked up some Yother's Bros 2 piece off of Scottish. Much much better. Just save yourself the time and go straight to delrin.
    9. #5992
      Member
      Jul 2015
      Charlotte, NC
      Just go delrin... you won't be sorry!
      2000 V70R Venetian Red/Charcoal M56 Swapped 200k
      2003 S60 2.4T Silver/Black 118k
      1991 944 Turbo B230FT/AW70 175k
      1992 245 crusty roller/driveway ornament/eventual V8 swap 249k
      2007 XC90 V8 AWD Sport Titanium Grey/Black 174k
      1999 BMW 528iT Alpine White/Sand Beige 246k
      2001 Mercury Mountaineer 5.0 junk hauler 211k
      2001 Miata with the wrong transmission 134k
      Sold-
      1998 V70 GLT Black/Beige 193k
      1998 S90- Silver/Gray 207k
      1995 850 GLT Tropic Green... crushed
      1993 944 B230F/AW71L 221k
      2000 S70 GLT Silver/Taupe 253k
      2001 S60 2.4T Black/Black 230k
      1988 744 Turbo M46 Beige Metallic/Beige 188k
      Need used parts? PM me!
    10. #5993
      Member
      Apr 2015
      How difficult or easy is removal of the factory bushings?
    11. #5994
      Member
      Jul 2015
      Charlotte, NC
      It's not the easiest thing, but it's not as bad as I thought it would be. If you take the subframe out completely, cut through the outer shell of the bushing with a sawzall (don't cut into the subframe itself) and hammer a screwdriver into the edge to help squeeze it out.
      Sold-
    12. #5995
      Senior Member ScottishBrick's Avatar
      Dec 2014
      Connecticut
      If the subframe is out you can wack them out with one good blow from a hammer.
      2003 V70 T5 - Mystic/Graphite - M56LK - 211k - K24/Greens/Do88/Quaife/SMF/P2R Clutch/DW300C/H&R/Bilstein TC/316mm & 308mm Brakes - SteveO Tuned
      1999 V70 T5 - Pewter/R Graphite & Alcantara - AW42 - 305k - Daily/Work Wagon
      1999 V70 T5 - Nautic/R Graphite & Alcantara - M56H - 177k - Rescued
      1999 V70 T5 - Emerald/Graphite - M56H - 119k - Garage Queen
      2000 V70 T5 - Mystic/Graphite - AW42 - 246k - Moms Unicorn
      2000 S70 GLT SE- Mystic/Graphite - AW42 - 218k - Sisters
    13. #5996
      Member Austin V70R's Avatar
      Jan 2012
      Santa Cruz, Ca
      It’s a good excuse to but a little floor press from Harbor Freight... the entire R&R process takes about 15 minutes with an extra set of hands to help balance the subframe. I’ve done three sets this way and it works great.
      06 VR GT - daily driver ~18" TSW Nurburgring wheels ~Contrast Stage 4 ~Shimmed block ~EFR7163 turbo ~1050cc Injectors ~TorqByte PM3 fuel pump and CM5-LT W/M controllers ~track spec IPD Bars ~Ultra Racing front strut bar & VST rear strut bar ~SS brake lines~Innovate Boost & AFR fail safe
    14. #5997
      Member
      Apr 2015
      Awesome, thanks everyone!
    15. #5998
      Oct 2016
      Guilford, CT
      Not necessary to remove the entire subframe. I found it easier to each one individually. Remove the bolt from the one you want to replace, loosen the other 3 so it drops down enough. I used a 1/2" spade bit and a cordless drill and cut through the old bushings very easily.
      https://www.homedepot.com/p/Bosch-Da...1005/203274550
      Once you cut through the old rubber in a few spots the things just pop out easily.
    16. #5999
      Member
      Apr 2015
      Fortunately I have those!
    17. #6000
      Aug 2019
      Ontario
      Gave the wife's S60 some much needed love. New tires, rear brakes, turbo return oil seal, turbo / intercooler coupler, and a full Mototec stainless exhaust system.
    18. #6001
      Dec 2018
      After 50.000km of neglect some things really needed my attention.
      Did spark plugs, air filter, upper engine mount, the short turbo hose, IPD endlinks front and back and the apparently missing cabin air filter last week.
      Tuesday replaced (by a specialist) vvt seal plus timing belt plus tensioner, auxiliary belt and water pump. They found some pretty bad sludge in the black end cap.
      Dropped the oil pan yesterday to clean it and change the oil pickup tube. Honestly not doing that again by myself. Hoping the old rubber seals will hold up because even though I asked them for all the needed seals to reinstall the pan and oil pickup tube they only sold me the one for the pickup tube.
      How long do you wait before putting new oil in, I had it standing for about 7-8hrs.
      Also did the auxiliary belt tensioner since its bearings were making noise.
      Not sure if it fixed the whine yet, only ran the car for about a minute to check for oil leaks.
      Wanted to do the power steering fluid and reservoir too but I ran out of hose clamps without realizing.
      On the to do list:
      LCA L+R
      MAF?
      Ignition coil "1"
      Oil cap seal
      Prepping for yearly inspection
      Verstuurd vanaf mijn SM-N975F met Tapatalk
    19. #6002
      Dec 2018
      Ps, while I was down there I took the time to clean the PCv hole. It was pretty gunked up
      The car did pass the glove test prior to this cleaning, I was afraid it would suck the glove in, so is the PCv good or bad
    20. #6003
      Member
      Jul 2015
      Charlotte, NC
      Quote Originally Posted by squintje View Post
      If it was trying to suck the glove in, I'd say the PCV is working very well!
      Sold-
    21. #6004
      Apr 2015
      Zagreb/Croatia
      Today I finaly put cruise control software. Until now car didn't have it. Had to go to Volvo dealer, pay 200 USD and that's all. Guy who was previous owner said that he doesn't care about that so I take time to activate it. Had to instal buttons on steering wheel and all other wiring was there.
      Attachment 63267
    22. #6005
      Member Shamak's Avatar
      Apr 2015
      Virginia
      I think I may have fixed my “reduced engine performance” issue. I took some Stabillant-22 and dropped a few drops of the formula into the wiring harness connector. So far, so good. Thanks to Chefricky as this idea has improved the car quite a bit.
      But.. I hit a bump yesterday and noticed my headlight washer cover is missing. Second time I have lost one. Next time I’m going to just glue it on.
      2007 S60 T5; M66, Titanium Grey/Graphite: Midir 18s/Orpheus 17s, H&R Sport lowering springs, Koni Yellows, Brembo calipers, EBC slotted rotors, StopTech Street Performance pads, ss brake lines, H&R spacers, 80mm extended stud conversion, OBX catless DP, custom 3" exhaust, 4" stainless tip
      1999 V70 XC; auto (5-spd conversion inbound), Sandstone Metallic: Borbet BS5 17s, H&R spacers, Koni Yellows, TME springs, Mishimoto FMIC, Custom 3" exhaust, cool air intake, ss brake lines. Coming soon: green injectors, K24, custom 3" DP, Brembo calipers, stage 3 tune
      1990 760; auto, Tokico HD Blues, Midir 18s, 25mm H&R spacers, cut springs
    23. #6006
      Senior Member ZZZZZZZ's Avatar
      Aug 2005
      Northern MD
      Quote Originally Posted by Shamak View Post
      Lol. What up, Shamak? I lost one on the s60 and replaced it from a part I got from Todd. It’s been good ever since!
      "The Real IPD" - ZZZZZZZ's thread
      2007 Passion Red/Gobi VRgt; 2005 Silver/Beige Leather S60 2.5T AWD; 2002 Silver/Off black leather V70XC
      Past: 1999 Tropic Blue/Green/Oak leather V70 (NAa); Mom traded 1975 Maroon/Maroon leather 164E
    24. #6007
      Apr 2015
      Virginia
      Things are good, ZZZZZZ. Been slammed on house projects so the cars have taken a back seat for a couple months. Does Todd have one in titanium grey? Ha
    25. #6008
      Member Exocet's Avatar
      Nov 2017
      Southern Tier NY
      Unfortunately, no. A silver 07 S60 just showed up in my local yard. But, someone has already grabbed the front bumper cover.
      Sent from my SM-G950U using Tapatalk
      2007 Volvo V70 2.5T - Mine
      2008 Nissan Titan SE 4x4, Crew Cab, Long Bed - Also Mine
      2012 Toyota Camry LE, 2.4 - Wife's
      2003 Mazda Protege5, 2.0 - Daughter #1
      2010 Mazda 6 Grand Touring, 2.5 - Daughter #2
    26. #6009
      Apr 2015
      Virginia
      Quote Originally Posted by Exocet View Post
      My other cover just fell off somewhere. Ugh! I’m gonna delete the washers by pulling the fuse and glue the covers once I get them.
    27. #6010
      Member
      Apr 2015
      Honeymooning up in Lake Tahoe CA... We're fortunate that shoes are clear here and little to no haze or smoke on the skies from all the surrounding fires. The photo below is after a 7 mile "off-road" drive on a dirt road up to Bodie ghost town...
      IMG_20200908_160434.jpgIMG_20200908_160533.jpgIMG_20200908_190158.jpgIMG_20200909_161033.jpg
    28. Remove Advertisements
