DIY Subwoofer Project - A Premium Journey to the Low End - Page 7
    Page 7 of 9 FirstFirst ... 3 4 5 6 7 8 9 LastLast
    Results 211 to 245 of 293
    1. #211
      Junior Member tunedxc60's Avatar
      Oct 2016
      USA
      It won't fit unfortunately.
      There are a few very detailed threads on how to do this. Mark-sf, bhom920, and I have done this. The dimensions are well noted. You've got about 35.5 " wide by 11.5" deep x 6 inches tall to work with. With that width it will require you to move some wires around.
      2018 XC90 T6 Inscription - Polestar tune + Racechip GTS, and Stealth Hitch
      2011 C30 (Ex K-Pax Racing)
      SOLD: 2016 XC60 T6 AWD Platinum/Inscription - Full bolt ons (Snabb air intake & turbo pipe, Do88 Intercooler, Viva Hybrid Turbo, Ferrita downpipe, IPD exhaust catback, H&R Springs), Stage 3 Hilton Tune: Dual JL Audio 10" stealth subs & 750Watt amp
      Jan 2017
      Ohio
      11.5" deep, are people fitting 12" subs in their XC60's?
    4. #213
      Member Ocean Racer's Avatar
      Oct 2009
      Melbourne / Australia
      Quote Originally Posted by AschMan View Post
      No.
      A properly tuned and ported 10" or 8" sub will outperform a lazy 12"
      02 XC70 R PROJECT TERRÄNGKÖRNING LANDVAGN
      04 V70R PROJECT LANDBARGE
      11 XC60 R-DESIGN PROJECT HEICO
      SwedeSpeed.com
      Oct 2016
      USA
      I have two 10's. it was hard to find the right setup but JL Audio makes a few options as does Alpine.
    7. #215
      Jan 2017
      Ohio
      Just took measurements and it looks like 32 inches is about the widest that would fit if you want to use the full 11 inch depth. There is a structural beam that would intrude towards the front that would force the box towards the spare tire. Bummer, really wanted the JL ported 8's to work.
    8. #216
      Oct 2016
      USA
      Yes, the structural beams on the sides cut the corners on an angle and prevent you from using the full 36" width. I have two 10" units ( model CS110LG-TW1-2) that measure 30" wide x 11.75" deep, and 5.6" high. That is about as big as you can fit without cutting those beams (probably not a good idea).
    9. #217
      Jan 2017
      Ohio
      Quote Originally Posted by tunedxc60 View Post
      . Haha, not going to cut that sheet metal. Looking for another box that could work.
    10. #218
      Junior Member ckracer76's Avatar
      Oct 2017
      United Kingdom
      This is an amazing in depth audio thread - I believe great audio is an important aspect of car ownership and enjoyment.
      Thank you
    11. #219
      Oct 2016
      USA
      You don’t have to cut sheet metal. The two boxes I have (had) fit fine.
    12. #220
      Jan 2017
      Ohio
      You don?t have to cut sheet metal. The two boxes I have (had) fit fine.
      That was back in Feb, I am all set now thanks to your help. Just wish I could have squeezed a 12 inch sub under the cargo floor in a custom fiberglass box taking up unused space.
    13. #221
      Jan 2017
      Ohio
    14. #222
      Jun 2017
      I know this thread is old as dirt but, when Mark-SF you say you ran the fuse line thru the rear distribution box, can you explain that a little further? Maybe a pic?
    15. #223
      Jan 2017
      Ohio
      I came out the front towards the engine but coming out the rear would be really stealth!
    16. #224
      Jun 2017
      So, amp installed sucessfully ising most of the same procedures in the original post. Only one noteworthy issue. When I turn my car off, I get what I think is the "ground loop" subwoofer hum. For about 5 seconds the sub will sound at max volume. I THOUGHT that maybe it was the amp because I did use an older amp. So, I replaced the amp. Still does it. Help me Audiophiles. You're my only hope.
    17. #225
      Jan 2017
      Ohio
      How are you turning on the amp? Some amps seem to have difficulty using the high level signal sensing to auto turn on the amp. My alpine amp worked fine but you may need an extra box to create low level leads and a remote amp turn on.
    18. #226
      Oct 2016
      USA
      Have you diagnosed whether it is when turning the car off or when locking the car? I would get a full blast hum when I locked the car and I diagnosed it to be since the rear locking sensor in the trunk was causing the interference and picked up via the speaker wire going from the speaker wire to the speakers themselves. With the low impedance speakers they kind of act like an antenna and any small signal will make them go crazy. See if you can shield the trunk mounted sensor in the middle of the trunk and/or use shielded speaker wire.i verified it wasn’t a ground loop because the amp turned off the vehicle so it has nothing to do with the amp itself - it’s all speakers. These were on my 2w jlaudio speakers.
    19. #227
      Mar 2011
      San Francisco, CA
      Quote Originally Posted by Lcwoods529 View Post
      Been away for a while and missed your post. I ran the power wire from the amp in the right rear corner under the lift gate trim and to the fuse block in the left ( Driver) corner.
      2011.5 XC60 3.2L Flamenco Red/Anthracite Black, Premium, Multimedia, Convenience, BLIS, Xenon + Custom Subwoofer
    20. #228
      Mar 2011
      San Francisco, CA
      AschMan is right. You need to provide details on how you are remote powering the amp. Some amps are looking for a DC voltage on the speaker outs which the VOLVO amp does not provide. Also it is very important that you have a close solid ground connection. Please include amp models as well as wiring details.
    21. #229
      Jun 2017
      I used the 12v remote line to an ignition controlled fuse point. I created a new ground point to the body so the ground line is not shared with any other grounds. The amp is an Alpine 500w mono channel amp. The amp wiring is all gauged/wired as per the tech specs suggested based on wattages, etc. I wired the speakers in the same fashion as the original post. I do have a 12v trigger and a line input jack I was going to try if necessary.
      This is the amp:
      https://www.amazon.com/Alpine-MRV-M5...70_&dpSrc=srch
    22. #230
      Jan 2017
      Ohio
      Hmm, that is the same amp that I used and the signal sensing is working just fine.
      Not sure if it made a difference but I ran the left and right channel inputs from the factory amp into both front and rear inputs on the amp. I only used the front channel output from the factory amp as the rear seems to filter out the bass.
      No turn off drama at all.
    23. #231
      Jun 2017
      Did you use the RCA inputs or the speaker level input connector?
    24. #232
      Jan 2017
      Ohio
      I used the speaker level inputs, but ran them parallel so that all rights and lefts were used.
    25. #233
      Mar 2011
      San Francisco, CA
      This is the amp:
      I hope you are not using the rear fuse block with this amp as its current capacity is way undersized. Note the amp has 60A fuse requirement and requires direct battery connection. You also stated that you connected the remote power-on to an ignition controlled fuse point. I don't know which year or model you have, but such a point does not exist in the rear of my XC60 and the later years until the new 2018s. Please explain in more detail. Finally you must use the speaker inputs from only the OEM amp front speaker outputs to get full range. Do not create parallel connections with other channels. It can cause feedback.
    26. #234
      Jan 2017
      Ohio
      Correct, only use the front channel outputs from the factory amp. However, I used all inputs on the alpine amp by splitting into multiple channels. Maybe this is the trick to get enough signal for proper turn on/off
    27. #235
      Junior Member BellevilleV70's Avatar
      Mar 2006
      Belleville,Ontario
      Thanks to everyone that has contributed to this ,esp, Mark SF......doing an install on my 15 polestar, does anyone know if wiring at amp is the same as listed here?
      2002 V70 2.4T - EST exhaust/Elbrus 18x8s/Conti DW/Eibach/Koni FSD/Polk Audio/Boston Acoustics/Infinity -beater duty now
      2013 XC60 T6R-design- IPD exhaust- Ice White
      2015.5 V60 Polestar- Black- do88/TDI/GFB/APATuned DownPipe/AirBox Mods/Elevate rear bar [email protected] mph
      Mopar Tech
    28. #236
      Jan 2017
      Ohio
      If your amp connector looks the same and wiring colors are the same then you should be good to go.
    29. #237
      Mar 2011
      San Francisco, CA
      Quote Originally Posted by BellevilleV70 View Post
      I’m glad you have found this useful. You should be fine with the wiring as I also have a 2015 V60 and the audio components are from those here.
      Report back on your results.
      Sent from my iPad using Tapatalk Pro
    30. #238
      Mar 2006
      Belleville,Ontario
      In and working great! This install was on my 15 P* Ran #4 wire to batt, this was super easy on LH side, and there is a big rubber grommet to left of brake pedal. You can look down behind batt and see it almost so super easy hookup. There are several unused ground spots in back, so ran #4 to one of them. The amp I used also has an optional bass control knob , so also bought that and ran wire up LH side, and mounted knob on lower side of column. Ran 12v trigger and speaker wires down right side. Trigger just picks up in larger of 2 front fuse boxes. There is an unused spot there in both this car and the xc60, that is ign controlled.
      Amp is a JL JX500/1D, Sub is an older 10in Infinity Kappa in a ported box. Yes it takes up space, but this is my second car, so that's not an issue,plus I already had it. I'll try it sitting a few different ways before I figure a way to secure it.
      So far with a bit of tweaking its sounds great! So nice to get some bass out of the doors and kill the rattles. I bought a decent mic, and have the audio tool app, now just have to figure how to use it! I'll post some pics below.
      Mopar Tech
    31. #239
      Mar 2006
      Belleville,Ontario
      Mopar Tech
    32. #240
      Mar 2006
      Belleville,Ontario
      Mopar Tech
    33. #241
      Mar 2006
      Belleville,Ontario
      Mopar Tech
    34. #242
      Mar 2006
      Belleville,Ontario
      Anyone have a good tutorial on how to use the audiotools app.? This doesn't sound quite right, seems to have a hole down in the midbass somewhere
      Mopar Tech
    35. #243
      Mar 2011
      San Francisco, CA
      I don’t have a tutorial reference, but would suggest that you take this approach.
      1. Since the equalizer is not a true one where there is isolation between the bands, I would first use AudioTools to evaluate its effects w/o the sub. You can use the RTA feature connecting via USB and selecting Pink Noise, Mono and .5sec Decay.
      2. Turn of all Dolby, Compensation, and perspective effects. Center the Bass and Treble Controls. Move each band control through its operation range and observe its impact on frequency. If your 2015 is like my 2011 you will see significant interaction. Not that you will need to get your levels up to +85dbA and do this in a quiet space without traffic or air/heating running.
      3. The goal is to adjust the lower bands in order to produce an consistent roll-off of 12-18db an octave from where you want your sub to kick in. For example, if you want your sub to reproduce below 80Hz, then you want your EQ set to be -6db down from your mid level at 80Hz and at least -18db down at 40Hz. If you are unable to cut the bass enough with just the EQ, add further cut with the Bass control. Always watch for interaction and compensate.
      4. Once you’ve set the EQ, then add your sub making sure its High Pass filter is no higher than 80Hz. You will not be able to reliably measure its bass using the RTA method due to the closed car pressurized environment, but you should be able to use your ears and well known music to bring up the bass level to where you like it.
      Hope this helps.
      Mark
    36. #244
      Mar 2006
      Belleville,Ontario
      Thanks Mark, spent some time tweaking tonight. Getting closer. I still think I will have to sound mat the front doors, still get a few rattles. Very impressed with the amp, it REALLY works that sub. Thanks again for the help
      Mopar Tech
    37. #245
      Junior Member Tall-person's Avatar
      Feb 2020
      Surrey, UK
      Hi mark-sf. I had saved this great article for a year since buying my 2018 xc60 and hoping it would work for this newer model.
      Now that I have looked into it, it appears that I don't have the depth to fit the enclosure under the cargo tray without cutting a hole in the cargo lid (even though there are no cross members in the lid to remove). Max depth seems to be 5". The alternative would be to thin the box, but even with those earthquake sws subs, there's probably not enough room to give. My only way would be cut the sub enclosure shape out of the tray and cover in the same material so you see the top of box flush with the cargo tray. Maybe make a replacement tray and keep the original for if i sell the car. Would you agree? I like the idea of keeping it out of the way and don't really want to have to go to a conventional sub box in the boot itself. Are those internal dimensions critical if I were to change the box size, so I keep to the same volumes?
      Thanks.
      Cheers,
      Raoul
    38. Remove Advertisements
