Full LED conversion thread (S60/V70)
    Page 1 of 5 1 2 3 4 5 LastLast
    Results 1 to 35 of 151
      Member theshadow27's Avatar
      Sep 2009
      DC, USA
      Full Volvo P2 S60 and V70 (2000-2009) LED conversion thread
      Have a P1 (S40/V50 2004.5+, C30, V70N)? Check out my P1 S40/V50 LED conversion thread!
      The following interior and exterior bulbs can be changed without modifying the car or tripping any warning lights/messages. All part numbers correspond to products sold by superbrightleds.com, who I highly recommend - though they might be a little more expensive, after ordering hundreds of bulbs from them I've never gotten a bad one. There is an interior kit available from Eurosport Tuning here, I can't vouch for the quality/brightness/consistency of their bulbs.
      On to the list! Format is:
      #x type (year) [superbrightleds.com part number] notes
      Interior
      Front Overhead Lights (aka "Map Lights" or "Reading Lights")
      4x 42mm festoon (all) [4210-xHP3 (3 LED) or 4210-xHP6 (6 LED)] *1*
      Rear Overhead Lights
      2x 42mm festoon (all) [4210-xHP3 (3 LED) or 4210-xHP6] reference
      Glovebox
      1x ba9s 2w (all) [BA9s-xHP9 (8 LED)] *2*
      Front Foot Well Lights
      2x 37mm festoon (all) [3710-xWHP3 (3 LED)]
      Trunk Light
      2x 37mm festoon (all) [3710-xHP3 or 4210-xHP3 (3 LED)? ]*3*
      Vanity Mirror Lights (aka "Sun Visor" lights)
      4x 6x31mm festoon-SV5.5 (all) [F30-WHP-12V]
      *1* Note: 42mm festoon is AKA 6411. Do NOT order "578 LED CAN Bus Bulb" as the heatsink will short out the festoon contacts.
      *2* Note: ba9s is AKA 17053
      *3* Note: may require bending the tabs a little for proper fit. 37mm is per reference
      Exterior
      License plate
      2x 194 (all) [WLED-xHP (1 LED) or WLED-xHP5 (5 LED) or WLED-xHP9-T (9 LED)] reference1 reference2
      Running lights - headlamp (AKA "Front Side Markers")
      2x 194 AMBER (all) [WLED-xHP (1 LED) or WLED-xHP5 (5 LED) ]
      Mirror turn signals
      2x 194 AMBER (all) [WLED-xHP5 (5 LED)]
      Puddle Lights
      2x 194 WHITE (all) [WLED-xHP9-T (9 LED)] reference
      Bulb Guide
      NOTE: Most products from superbrightleds.com can be either "cool" or "warm", you probably want "cool". Warm looks more like the incandescent bulbs we are trying to replace.
      NOTE: All bulbs listed above can be changed without triggering warning lights and do not require modification to the vehicle. Lights not recommended for LED conversion include:
      • Brake lights - These will trigger "bulb failure" warning if used without a resistor (and harness modification). IMO they generally look bad because high-power LEDs don't fill the reflector properly, and large clusters of "standard" LEDs produce so little light they are a safety hazard. True brake light conversion requires modification of the taillight housing, see juve021's thread for the right way to do it.
      • Running lights - Also trigger "bulb failure" warning if used without a resistor (and harness modification). Same reflector issues as brake lights.
      • Turn signals - Will trigger fast flashing (to indicate burnt out bulb) and bulb failure warning if used without a resistor (and harness modification). Turn signal functionality is built into the CEM (central electronic module) which communicates over a computer bus to the turn signal stalk switch so there is no way to add an "electronic flasher" to overcome this problem. Similar reflector issues to the brake lights, turn signals also look bad with LEDs.
      • Reverse lights - I have not seen a drop-in LED bulb that is capable of producing more light than an upgraded halogen bulb reverse bulb which output around 600 lumen each. LEDs this powerful do exist and are available with matched reflectors in high powered LED flashlights but that would be $100+ per bulb and still require modification of the housing. Off all the bulbs in the car, I look at this as the least critical since it's on for maybe 30 seconds - of which light output is significantly more important that aesthetic considerations.
      • Rear fog - If you think about driving around with the rear fog on makes you look cool you're an idiot. If you actually use the rear fog in low-visibility conditions, and want to increase it's light output for safety reasons, then look at the upgraded halogen bulb reverse bulb which fits in the fog socket as well.
      Here's some pictures of the bulbs for reference, thanks to superbrightleds.com:
      194 (L2R: 1 LED, 5LED, 9LED, 15LED):
      NOTE: 194 = 168 = 5W5. Most LEDs are sold as 194.
      NOTE: Some cheaper 194 bulbs have poor socket contacts - many times just a small piece of wire. Over dozens of cars and hundreds of bulbs that I have installed, around 50% of 194 bulbs don't work the first time they are installed in the socket. If you are sure that the polarity is correct and the socket has power, try bending the leads to make better contact with the holder. Occasionally I've used a bit of a paper clip or a copper wire (18 or 16 AWG, solid not stranded) to shim the bulb into making contact. If all else fails (and you're sure the bulb isn't defective, you can try adding a blob of solder to the wire lead and flatting it with a pair of pliers.
      3710-xWHP3 and 4210-xHP3 (3 LED) SV8.5 Festoon:
      3710-xWHP6 and 4210-xHP6 (6 LED) SV8.5 Festoon:
      F30-WHP-12V (1 LED) 6x31 SV5.5 Festoon:
      NOTE: The SV5.5 has a smaller contact barrel diameter (6mm) than "standard" SV8.5 festoons (8.65mm, 10mm or 11mm body) used in the other lights
      If you order everything from superbrightleds.com it comes out to around $150. This is the best option if you just want it to work the first time. Many have saved money on fleeBay but most of the stuff ships directly from Hong Kong or China and can take weeks or months to arrive. I have also found that the cheaper bulbs use smaller resistors to achieve higher output, at the expense of LED life, and can burn out as quickly as a few months (especially in the headlight housing, which reaches high temperatures). The cheap ones also usually have poor color consistency between bulbs. You get what you pay for!
      LED Retrofit Troubleshooting
      Before you post with a problem run down these checklists.
      Just installed new LED bulb and it won't light up:
      1. Check power - it sounds obvious do it anyway. Plug the incandescent bulb back in to make sure the socket is energized. Try to have the car leave the bulb on, for example using the running light switch rather than pushing the city light button on the remote.
      2. Check polarity - Most "economy" and some expensive LED bulbs are polarized, meaning that they will only work if the positive and negative terminals are connected the right way. Some LED bulbs are not marked. Flip bulb around 180 degrees in socket so the contacts are reversed.
      3. Check bulb functionality - Using alligator clips or similar, apply 12V directly (from the battery terminals, or whatever) to the bulb contacts. If you can't get the bulb to light up, it is probably defective.
      4. Check the bulb contacts. As noted above, some cheaper 194 bulbs have crummy contacts that need some love to make a decent connection. If you do figure out a way to make it work, make sure that it won't fall out with vibration, heat, etc.
      5. Make sure the circuit is not monitored. Monitored circuits in the S40 include brake, front/rear running, turn, and low beam.
      6. Festoon Bulbs: Check to make sure the contacts are not being shorted by part of the bulb (e.g. a large metal heat sink).
      LED bulb has been running for a while, but now won't light up
      1. Check connection - bulb and socket are subject to vibration and may become loose
      2. Check power - Plug an incandescent bulb back in to make sure the socket is energized. If it does not, make sure the switch is on and the fuse has not blown, etc.
      3. Check bulb functionality - Using alligator clips or similar, apply 12V directly (from the battery terminals, or whatever) to the bulb contacts. If you can't get the bulb to light up, it is probably defective. This happens pretty often with cheap bulbs in the city lights, since they live next to the high-beams which dump a lot of heat out. Either buy better bulbs or buy a lot of cheaper ones. Also, twice I've gone to the dealer and left with a burnt out city light. Don't know if it's something they hook the car to or what. Very annoying since they offer to replace it with an incandescent..
      LED has dim glow when off
      1. This is an issue with the P2, it will not drain the battery since the lights go out after the main relay disengages
      2. Fix is to install a resistor in parallel with the bulb, see https://forums.swedespeed.com/showthr...all-and-Photos
      Installation Tips
      *The front overheads can be tricky to get at the first time. There is a flip-down cover by the rear-view mirror that hides the screw:
      * The puddle lights can be tricky as well. Slide a screwdriver in under the mirror to disengage the clip:
      Gallery
      suberbright leds by maxenar:
      ^Rear license plate. LED makes it look classy.
      ^Interior with map lights all on.
      ^Interior with only footwell lights on.
      NOTE: These photos are taken with no special effects or 'shopping whatsoever.
      Last edited by theshadow27; 10-16-2015 at 02:37 PM. Reason: updated P2 to 2000-2009. Somebody please verify that there is no facelift that messes with that
      '05 S40 T5 AWD M66 sport/winter/ew. Michelin PS A/S+. 6000k 50w HID low/HIR1 high/full LED conversions. RiCA SW. Evoelate intake. IPD rear sway, skidplate, TCV.
      Writeups
      Full P1 (S40/V50/C30/C70) & P2 (S60/V70+R) LED conversion | P1 HID conversion & details | FM Modulators & interference | stalk cleaning | CEM Teardown
      Member Ocean Racer's Avatar
      Oct 2009
      Melbourne / Australia
      Just get some of these from ebay. They're better than all those individual ones IMHO.
      $5 a pack and they are VERY bright
      02 XC70 R PROJECT TERRÄNGKÖRNING LANDVAGN
      04 V70R PROJECT LANDBARGE
      11 XC60 R-DESIGN PROJECT HEICO
      Member o2k's Avatar
      Feb 2008
      Jacksonville Florida
      Just a note.. Be careful with the big 194 tower leds, like the 15 leds ones... If they are too tall they will not fit.
      Front footwell lights are festoon.
      side turn signals for a 2004 are 194
      rear overheads were festoons for my 2004 not 194
      Gone: 2004 s60r FG/Atacama
      2004.5 S40 2.4
      2000 Pontiac Trans Am (The Beast)
      2003 Chevrolet Suburban
      2004 Saturn Ion Redline (gas sipper)
      Oct 2009
      I am currently trying to get into the side mirrors to replace the underside lights ..
      Not as easy as I had thought.
      guide:
      Junior Member maxenar's Avatar
      May 2011
      Dallas, TX
      I was putting one together myself lol! Thanks for starting it up buddy!
      2006 Volvo S60 R | GT | Passion Red | ///S2R
      { COMFORT | SPORT | ADVANCED }
      "PRACTICE SAFE SEX, MAKE LOVE IN A VOLVO."
      Sep 2009
      DC, USA
      Quote Originally Posted by Ocean Racer View Post
      side mirror guide
      Got it, thanks!
      Quote Originally Posted by o2k View Post
      Thanks for the info. Do know what size the footwell festoons are? OLRG says 6418 which should be the shorter (36mm) length.
      I have seen the same rear overhead lamp assembly (2 buttons, two reflectors and two 194 bulbs, see this pic) in a 2003 S60 (not R), 2006 S60R, 2001 S40 (1.9t), and 2005 S40 (T5) so I assumed that it was pretty much the standard Volvo part. Do you have any more information on the festoon version?
      Writeups
      Senior Member Chilled Man's Avatar
      Jan 2007
      Backyard of TMI
      They should all be 36mm Festoons. All the P2s I have had and parted were all them.
      Just ordered Blue 36mm for the XC yesterday.
      /2006 S60 T5 /K24/R Calipers/17" pegs/OBX/Koni/Eibach/JVC/SNABB/IPDSway,
      /2004 V70 R/M66 /05+ Tails/ 05+ Console/Evolve Intake/IPD Sways/OZ/Kenwood/PHUZZ
      /2005 V70XC -Stock
      /2004 V70XC - Project Truk
      Unquestionable faith is the Epitome of Ignorance. - me
      That’s because you savagely dismember Volvos. That’s not ownership, that’s a serial killing kidnapper!
      Moderator DevolvR's Avatar
      Jan 2010
      Toronto, ON
      guide:
      Took me 5mins for both sides. Even easier if you take the glass off first.
      04 S60 R MT Titanium Grey/Nordcap thread Copper Work VX-XX 19" Staggered | DP & Custom Quad Tip Exhaust | 05+ Conversion Exterior & Interior | Sport Kit
      12 XC60 Ice White Wifey's Family Hauler | 3.2 AWD | Heico Kit | Fast 19" FC04A | Running Boards
      12 S60 R-Design Ice White | Bone stock for now
      IG: @devolvR
      Member o2k's Avatar
      Feb 2008
      Quote Originally Posted by theshadow27 View Post
      Got it, thanks!
      Hmm.. It's been a while but I Do believe I put in 39mm festoon bulbs in the rear. I can't remember if that was a perfect fit or if they were smaller. If my brain isnt makig it up i think 42mm will fit better. Footwells are smaller indeed because the 39mm ones were only a tad bigger.. I had to modify the holder a little to get the 39mm in there. So 37mm sounds accurate. If it
      Comes to it and no one can confirm, I'll take it apart in a day or so and take a pic.
      2004.5 S40 2.4
      Member o2k's Avatar
      Feb 2008
      Also.. The trunk bulb size is the same as the footwell. And the running lights... If you are referring to the turn signals in the headlight they are 1157 iirc not 194 The drls are hb4a or 9006xs. You can fit a regular 9006 in there too.. Just a little harder to put in.
      2004.5 S40 2.4
      Jan 2007
      Backyard of TMI
      Hmm.. It's been a while but I Do believe I put in 39mm festoon bulbs in the rear. I can't remember if that was a perfect fit or if they were smaller. If my brain isnt makig it up i think 42mm will fit better. Footwells are smaller indeed because the 39mm ones were only a tad bigger.. I had to modify the holder a little to get the 39mm in there. So 36mm sounds accurate. If it
      Not sure I just order all of one size and go ...
      /2005 V70XC -Stock
      I'm interested!, but once all the bulbs are verified.
      Jan 2008
      Riga, Latvia
      I can confirm that up front, all four bulbs have to be 42mm long. Changed that already. Looks way much better now.
      XC90 2.5T
      Moderator aldebaran's Avatar
      Jul 2005
      Greensboro NC
      All one has to do is take the original bulbs out and one will know definitively what bulbs they are.
      Junior Member Fjord's Avatar
      Dec 2010
      Wasington D.C.
      Do the interior lights dim up/down pretty good? Flickering issues?
      Past: '99 S70 T5m, '99 V70R, '04 S60R
      Current: '96 960, '00 V70, '05 V70
      Member dave_n_ruth's Avatar
      Nov 2003
      Roy, Wa
      So who will be the first to offer an all included conversion kit for a reasonable price? I think someone could make a few bucks off each kit. Once you have done the install, buying bulk bulbs and sorting would be easy.
      2004 S60R Titanium/Atacama-Spec SM Flywheel, Phuz DP & FMIC, IPD HD TCV, UR F/R Strut Tower Brace, IPD UEM Bushing, IPD LTM. On-the-shelf-UR pulley, UR Lower F&R Braces, IPD HD Front Endlinks, Takspeed Titanium shims, Takspeed SS Brake lines, Takspeed R Pen
      2009 XC90 V8 RDesign Titanium- SS Brake lines, Rear R Calipers (On-Shelf wont fit with rims)
      Jan 2010
      Toronto, ON
      Quote Originally Posted by dave_n_ruth View Post
      Doesn't EST already have a full LED conversion kit?
      IG: @devolvR
      Nov 2003
      Roy, Wa
      Yes, I guess your correct.
      Sep 2009
      DC, USA
      Quote Originally Posted by chubais View Post
      Cool, got it, thanks.
      Quote Originally Posted by DevolvR View Post
      Yep - I added a link to that as well. That kit is interior only though. Also not quite sure of the quality of that particular kit, I love EST but electronics aren't their thing. SBLEDs has made consistently good stuff for almost 10 years.
      Writeups
      Jan 2008
      Riga, Latvia
      Trunk Light
      1x 37mm festoon (all) [3710-xWHP3 (3 LED)] ((NEED VERIFICATION))
      Confirmed as well
      XC90 2.5T
      Sep 2009
      DC, USA
      Trunk Light
      Confirmed as well
      Cool, got it.
      Writeups
      Jan 2008
      Riga, Latvia
      Quote Originally Posted by Fjord View Post
      Dimming is just the same as with the original bulbs. No issues at all.
      XC90 2.5T
      Jan 2008
      Riga, Latvia
      License plate
      2x 194 (all) [WLED-xHP (1 LED) or WLED-xHP5 (5 LED)] reference ((NEED VERIFICATION))
      4x 6x31mm festoon-SV5.5 (all) [F30-WHP-12V] ((NEED VERIFICATION))
      both of this also confirmed, so can be edited.
      XC90 2.5T
      Sep 2009
      DC, USA
      License plate
      Updated. Thanks!
      Has anyone gotten a chance to look at the rear-overheads? Maybe even take a picture?
      Writeups
      Senior Member AthruC's Avatar
      Dec 2006
      Long Island
      Rear overhead use the same festoon bulbs. I'll snap a picture in a little bit.
      Jan 2008
      Riga, Latvia
      2x 42mm festoon (2004?) [4210-xHP3 (3 LED) or 4210-xHP6 (6 LED)]((NEED VERIFICATION)
      Those are also confirmed
      Installation very simple, just take out the whole module with the screw driver (or something similar), and replace bulbs. 42mm are the one you need. So basically I have finished the interior, and everything works just perfect, dimming is good as well.
      XC90 2.5T
      Sep 2009
      DC, USA
      Quote Originally Posted by AthruC View Post
      Thanks, updated!
      Writeups
      Junior Member harleyvh's Avatar
      Oct 2006
      Montreal
      Basically did all the interior lights and attempted the instrument panel.
      Could not find a good DIY guide to replace the HU803 lighting so I revert back to OEM except for the main cluster.
      (there is one in mathew's volvo site: http://www.matthewsvolvosite.com/200...b-replacement/ however, it's for the older generation)
      If one you can come up with a DIY guide to replace the OEM radio lighthing,... that would be great.
      2001 V70 2.4T.. RIP
      2011 S60 T6 AWD.. just beginning....
      * IPD rear sway bar + links / IPD DEM cover / IPD skid plate
      * 336mm RD Disk/caliper upgrade
      * Hybrid Audio Imagine I61-2 / sound deadening
      Jan 2008
      Riga, Latvia
      Quote Originally Posted by harleyvh View Post
      The Radio unit (with cel phone) is the only thing that is left for me, I have changed lights in cluster, lights switch and A/C unit. I will not bother with the windows switches and steering wheel controls, but indeed, if someone would point on how to change (if possible at all) the HU-803 lights, that would be excelent.
      XC90 2.5T
      Jan 2008
      Riga, Latvia
      Glovebox
      1x ba9s 2w (all) [BA9s-xHP9 (8 LED)] ((NEED VERIFICATION) - should be a 17053)
      Also done, and ckecked, way much better than the stock ones.
      XC90 2.5T
      Sep 2009
      DC, USA
      Glovebox... ckecked, way much better than the stock ones.
      Cool, I think that's everything!
      So there you have it, a P2 LED conversion guide. Thanks for the help chubais, AthruC, o2k, Ocean Racer, and Chilled Man! I will continue monitoring this so anyone runs into problems be sure to post em up.
      Enjoy!
      Writeups
      Dec 2006
      Long Island
      I just ordered some LED's from autolumination to handle the city lights in my halogen headlamps (non-R, I know ...for now).
      However, I also picked up four bulbs to replace the taillights and rear fog (which I will try to wire as dual). The dual-filament bulbs supposedly have the "bulb-out" cancellation chip built in, so I'll update with that project.
      Member Denis's Avatar
      Jul 2008
      CANADA, Ottawa
      Don't think you can just replace the bulbs on hu, the only way i guess is to take it apart and solder the new ones on the board. pita.
      another reason why i went with aftermarket hu
      Trunk Light
      Don't you need two? one for each light?
    37. #35
      Dec 2006
      Long Island
      I think you may need a longer bulb (x2) for the trunk, as I just tired to fit some 36mm bulbs and they are a few mm too short.
