i think i broke my car..? - Page 2
    Page 2 of 2 FirstFirst 1 2
    Results 36 to 43 of 43
    1. #36
      Junior Member vplay84's Avatar
      Jul 2010
      Baltimore, MD, USA
      Viva sells a quick kit. It's the collar sleeve, a snap ring, and two seals. $120, should get you taken care of.
      '04 S60R. 6MT. Black. Snow Stg. 2 WMI, PhMIC, 3" DP, AMS, HD TCV, Track Spec sways, R boost gauge, F/R strut & subframe braces, silicone coolant hoses, poly tranny and top engine mount bushings, Powerslot rotors, SNABB intake, Forge CBV, kevlar timing belt, TMW short shifter, JRL mod, Powerslot rotors, SS brake lines, Ti brake shims, 3K HID fogs.
      '68 Plymouth Fury III. 318/727 Work in progress.
      Junior Member ari951's Avatar
      Nov 2010
      Florence Kentucky
      Here you go.
      Service kit: 31256246 (comes with 3 seals, lube, and sleeve)
      Transmission oil: 31280771 CAPACITY 2.1L, API GL-4, SAE-75W
      Bevel gear oil: 31259380 API GL-5, SAE 75W-90, CAPACITY 0.8L
      These are the newest part numbers from Volvo.
      2004 S60R MT | Black Sapphire/ Gobi | factory aero body kit | painted grill | painted headlight bezels | custom R badge front grill | 18" two tone metallic grey/black pegs | smoked tail light lenses | 20% tint | USA spec ipod interface | integrated subwoofer system | EBD delete | DEM heatsheild |http://picasaweb.google.com/10580646...NevjZSB6N72mgE
    4. #38
      SwedeSpeed.com
      Junior Member VOLVO S60 R's Avatar
      Oct 2009
      New Zealand
      have you thought about checking the fuse for 4 wheel drive? i know some people pull it out for a bit of fun, maybe just maybe it can all be fixed for a couple of cents with a new fuse in the fuse box. no point getting a $4k invoice if you don't need one...
      2004 Volvo S60R, about 100kms, blue inside and out, JRL mod, curb rashed pegs.
    7. #40
      Sep 2010
      jasper canada
      Wouldn't a fuse give me a message or code of some sort?
    8. #41
      I have same problem now with same codes, did you figure it out?
    9. #42
      Member HunterBD's Avatar
      Jun 2011
      Bryn Mawr
      What are your codes?
      05 VR GT Titanium Grey/Nordakp, sunroof, Winter Package, Premium sound with Volvo Sub. VST rear brace, Ultra Racing front strut brace.
    10. #43
      Member
      Jul 2007
      GTA, ON, Canada
      I'm here too - was getting front wheel spin a little while back so got the collar/sleeve and seals (already replaced the original collar/sleeve a few years back), indy shop got it apart and found the angle gear worn so now I'm looking for an angle gear.
      2006 S60R GT - SNABB Turbo Intake Pipe, Eurosport Mototec Cold Air, IPD R Boost Gage with ViVA vent pod, Rear upper brace, JL Audio Amp and 10" Sub
    11. Remove Advertisements
