Window regulator and blue clips
    Results 1 to 11 of 11
      May 2010
      Denver, CO, USA
      My search is not allowing me to look at multiple pages...
      My driver's window is goofy. Looked in the door and the blue clip on the back side is broken. New clips en route, but I have no idea how the parts go together. Can anyone provide pictured instructions?
      Thanks...
      Member BlazinBob's Avatar
      Oct 2009
      SoCal
      '05 Ti-Kap GT SR; Lost 8/21/17
      Oct 2007
      Long Beach, CA
      Prescient. My window went down and not back up today. No time to futz with it myself. $164.29 to replace both at the indy.
      05 SR Black Sapphire Nordkap Stock [email protected]
      SwedeSpeed.com
      May 2010
      Denver, CO, USA
      Quote Originally Posted by BlazinBob View Post
      Yeah, I just saw that.
      Sorry for the premature threaderbation.
    7. #5
      Sep 2010
      so ill
      My car loves to spit these little guys off their proper attachments. This is no problem to replace, as it only takes 5 minutes or so. My problem is getting the window to be adjusted correctly. I have tried all the fuse things (taking it out at desired height, etc) but have had no luck. Any better ideas for this? It is annoying as my passenger window likes to go up a bit too high.
      04 SR, MT, Ti
    8. #6
      Oct 2009
      SoCal
    9. #7
      Oct 2007
      Long Beach, CA
      5 minutes?! You mean, after the door panel is removed, right?
    10. #8
      Sep 2010
      so ill
      Quote Originally Posted by dancho View Post
      Hah, no not really, 5 min for the whole deal. I have gotten better at the whole deal. I have taken my door panel off quite a few times now. And yeah, that window regulation is still giving me trouble..
      04 SR, MT, Ti
    11. #9
      May 2010
      Denver, CO, USA
      Well, blue clips arrived yesterday. Replaced both today, although only one was broken.
      The directions here helped except i had to go through the wiring harness box on the door to get the front clip, and for some reason the directions for resetting the window were not correct either.
      Thanks!
    12. #10
      Sep 2010
      so ill
      So anyone know the actual way to reset the window levels?
      04 SR, MT, Ti
    13. #11
      May 2010
      Denver, CO, USA
      I hit the auto down and then pulled the fuse for power to the door. It was not fuse #5 in the driver's side panel in the side of the dash. I think it was 35?
      Anyway, auto-down, pulled the fuse, put the fuse back in and all worked.
    14. Remove Advertisements
