TPM Problem
    Results 1 to 5 of 5
    Thread: TPM Problem
      Jan 2004
      TPM Problem
      Low tire pressure message but all tires have good pressure. For the heck of it, increased all 4 tire pressures and still get the warning (And yes I drove around after adding air.)
      So I assume one of the TPM's went south. Is there an error code to tell which one is a problem?
      Junior Member dachshund2's Avatar
      May 2003
      May need to check the spare.
      Sep 2011
      Wisconsin
      It's the little batteries inside the senders in the winter weather. The guy responsible for the design of this worthless system clearly was raised in the tropics. Talk about "Crying wolf!"...
      You can thank the dummass Explorer owners for all of this- if they had simply maintained their vehicles and drove at a reasonable speed, we wouldn't be forced to have such a stupid system on all of our cars...
      SwedeSpeed.com
      Jan 2004
      The spare doesn't have* TPMS and I think tires need to rotate to send a signal. After my third 10+ mile trip, the message disappeared. I have regular service scheduled in 10 days. I'll ask them to use an analyzer
      (Bartec?) on each tire. Maybe the analyzer tells battery strength. The TPMS's are about $50 each!
      *If the valve stem is stiff it has a TPMS.
    7. #5
      Member TheCastro's Avatar
      Apr 2011
      Maryland
      Quote Originally Posted by 79powerwagon View Post
      I don't have TPMS on mine, it was an option.
      Quote Originally Posted by Lunasea View Post
      Your tires also heat up and expand when driving, your pressure could still be off, or it could be reading it as off when it's cool.
      My YouTube Channel & My Twitter @TheCastro
      I miss my R, but I don't miss the constant repairs
    8. Remove Advertisements
