What did you do to your R today!?!? - Page 456
    Page 456 of 456 FirstFirst ... 356 406 446 452 453 454 455 456
    Results 15,926 to 15,933 of 15933
    1. #15926
      Apr 2013
      San Diego
      Quote Originally Posted by rnkelly View Post
      Mine died recently too! Terrible design.
      I removed the siren but the battery fried the circuit board so couldnít fix it. Brought the car to volvo and they disabled the alarm via a software fix so no more message. Only charged me 50$ so Iím happy that I donít have to deal with it in the future. Obviously no alarm functionality anymore but it doesnít bother me.
      Do you know what that fix was so I can tell my dealer? The (intermittent for me) message doesnít bother me much but I would love my sunroof to not get stuck popped up for two years, again.
      (Yes I know I can manually crank it, that wasnít the point haha.)
      2004 S60 R TiGrey Nordkap 6MT - IPD Stage 2.5 Software - RaceS60r DP W/ iPd Oval (no)catback (heat wrapped) - R-Kelly Intake - VIVA Steel Brake Lines - Autometer Gauges - iPd TCV - iPd motor/trans mounts - iPd Rigid Strut Braces - 156k
      Mar 2019
      Quebec
      They just called it an alarm disable/removal. It seemed common for them, they quoted 400$ to replace with a new module or 200$ to remove the module and disable the alarm. Since I already removed the siren module myself they only charged 50$. Since Iím in the belle province this was in French so the terms were all different. Canadian dollars btw.
      Just checked the receipt, looks like thereís actually a 12$ part for the alarm removal.
      Part number- 9438408
      My sunroof worked when I was getting the alarm message so not sure if my issue is identical to yours.
    4. #15928
      Mar 2019
      Quebec
      New headlight wiper blades and Plastic wheel bolt covers because they were rusty and ugly.
      Small and cheap but an incremental improvement nonetheless.
      SwedeSpeed.com
      Junior Member bigern79's Avatar
      Oct 2019
      Bothell, WA
      Wow, didnít even know the bolt covers were a thing! I need to pick some up. I just did the wipers too, very satisfying replacement.
      Instagram: @miata_at_midlife
      2006 Sonic Blue Volvo V70R | 1998 Estoril Blue BMW M3 Sedan | 2000 Avus Blue BMW M5
      ***My V70R build thread, most of which was not built by me ***
    7. #15930
      Moderator The Driver's Avatar
      Sep 2009
      Huntington, NY
      The Bolt covers only work with aftermarket and/or extended lug bolts. They do not fit around the oem chrome ones (Too Big).
      06R Custom Electric Blue Silver
      07R Magic Blue - Sold
      04 Bonatti Gray Rover Disco HSE
      09 Iridium Silver SLK55 AMG P30 Edition
    8. #15931
      Member Exocet's Avatar
      Nov 2017
      Southern Tier NY
      You need the 17mm lug bolts for the covers to work. The OEM chrome bolts are 19mm.
      Sent from my SM-G950U using Tapatalk
      2007 Volvo V70 2.5T - Mine
      2008 Nissan Titan SE 4x4, Crew Cab, Long Bed - Also Mine
      2012 Toyota Camry LE, 2.4 - Wife's
      2003 Mazda Protege5, 2.0 - Daughter #1
      2010 Mazda 6 Grand Touring, 2.5 - Daughter #2
    9. #15932
      Mar 2019
      Quebec
      I purchased Volvo part number 31660916 from ipd, 19mm and worked great. Different colors are available too. Itís a Mickey Mouse fix but does the job.
      https://www.ipdusa.com/products/1854...volvo-31660916
    10. #15933
      Junior Member lolvos60R's Avatar
      Jun 2015
      Plainfield, CT
      Just need the vents
      Sent from my iPhone XR using Tapatalk
      05 sr sapphire/nordkap, three pedal arrangement -Contrast Works stg1 18psi w/ 4c map switching -Custom 3" intake pipe w/ swedesource drop-in filter -stock air box -dw 300c fuel pump welded A.G. Bob villa mod PPS: Poly front control arm bushings -poly torque mount-poly subframe inserts Powerflex: race #12/street #5,8,13 Ipd toe bars BC coil overs EST D.P. catted w/ Viva performance exhaust w/o resonator Goodyear eagle f1 asymmetric 2 235/40-18 and of course PEGS!!!
    11. Remove Advertisements
