What did you do with your s60/V60 (2011+) today? - Page 176
    Page 176 of 197 FirstFirst ... 76 126 166 172 173 174 175 176 177 178 179 180 186 ... LastLast
    Results 6,126 to 6,160 of 6878
    1. #6126
      Feb 2015
      Quote Originally Posted by p.rico View Post
      Going from what you have (R-Design) to H&R would be only 0.6" beyond current.
      I still have my H&R's sitting in the basement. I need to get them on stat! My issue is that with my 235/45's, I'm probably going to have to take the 15 mm H&R spacers off.
      Oh yeah, definitely. At near full compression in the rear with the *15mm spacers ( previously said 20) clearance to the actually metal fender is very minimal (I would estimate 2-3mm). Would likely need to roll fenders.
      2015 V60 R-Design - Onyx Black Metallic / Off Black
      2004 Mazda 6s Touring - 3.0 V6 / Manual
      2008 Suzuki SV650 - Pearl Novelty Black
      2002 SVT Focus Turbo - Dead and gone
      Junior Member EdVQ37's Avatar
      Feb 2017
      Edmonton, AB, Canada
      245/35/19 19x8.5 +40. No rubbing. H&R Sport springs.
    4. #6128
      Feb 2015
      Quote Originally Posted by EdVQ37 View Post
      Did you remove your rear plastic inner fenders?
      SwedeSpeed.com
      Feb 2017
      Quote Originally Posted by emgrock1 View Post
      No Sir. Rear liner is still in place.
    7. #6130
      Sep 2015
      I run the same setup and no rubbing too
    8. #6131
      Feb 2015
      Quote Originally Posted by limey View Post
      Have you looked at them though?
    9. #6132
      Sep 2015
      Yeah all still intact
    10. #6133
      Feb 2017
      I promise you, there’s no rubbing lol. I just looked today and they are fine. The tire had a lot to do with it. Some tires can be “chunky” vs another in the same exact sizes.
    11. #6134
      So glad you mentioned this. Some sidewalls are a little rounded, others are more squared off. Some have lip protecter chonk, some don’t. Even the raised lettering of company logos and any other decorations on the sides of the tires can use up valuable room when clearance is super tight. That’s why it’s vital to include what tire brand and model, specifically, you’re talking about when discussing whether a tire size rubs or doesn’t rub with a given wheel size and suspension setup. Even an older versus newer revision of the “same” tire might fit differently.
      2011 S60 T6 with Polestar tune+TDI-Tuning : KW V3 coilovers : DO88 fmic : Ferrita downpipe : Powerflex "race" torque mount insert
      12.99 at 109mph
    12. #6135
      Junior Member meade18's Avatar
      Mar 2018
      Just installed a set of Yokohama Avid Ascend GTs (235/45R17) on my stock Sadia wheels. I was debating about what to get and decided that since I don't drive like I did when I was younger, Grand Touring tires make more sense than High Performance tires. Also, since I have a set of 18" Midir wheels, if I really get the itch to put some more aggressive tires on, I'll put High Performance Summer rubber on those wheels and keep the Yokohama's as my cool/cold weather tire. I decided against the Vredestein Quatrac because we really don't get enough snow around here and I can remote in and work from home if the roads are bad enough that I can't get to work. No point in paying for the 3 peak mountain snowflake rating if I'll never use it.
      Another factor is that the tires were way cheaper on Walmart.com than Tire Rack, so I saved a bunch of money and got a very highly rated touring tire for the price of a budget high-performance tire. The price today isn't as low as what I paid, but it's still quite a bit cheaper than Tire Rack if anyone else is interested. https://www.walmart.com/ip/Yokohama-...Tire/913042146 $103.26 vs. $134.99
      2015.5 Volvo V60 Premier T5 (2.0T Drive-E) FWD (with a new engine)
    13. #6136
      Senior Member Wayne T5's Avatar
      Nov 2002
      Russell Twp, OH
      They're not any louder than the blizzaks but I think the sidewalls deflect under load.
      Honestly, still not worth the extra $400 to get the blizzaks imo.
      I've had two sets of these and for the money they are great tires.
      Past: '94 854, '99 S70 T5 SE, '99 S70 GLT, '04 S60R M, '12 S60 T5, '13 S60 T5, '15 S60 RD, '05 V70R GT
      Present: '95 854 T-5R, '06 XC70, '15 XC70 T6, '15.5 XC60 T6, '16 V60 P*
    14. #6137
      Feb 2015
      Looking beyond tire sizes, just looking at your tires they don't appear to stick out beyond the wheel at all. Probably a function of the smaller sidewall.
      I'm running a 235/40/19 so I guess I was just assuming 0.5" of extra width would cause more rub... But really, that's extra contact patch rather than overall tire width.
      EDIT: so just out of curiosity I looked up the offset of the polestar winter wheel. It's a +53mm offset. So, with my 15mm spacer I'm at +38mm. That would explain it.
    15. #6138
      Feb 2017
      It has a lot to do with the combination of width of the wheel and the width of the tire. The width I’m using on the wheels are 8.5” wide so it actually stretches the sidewall back on the spec of tire I’m using. That allows just enough space to clear the rear wheel liners.
    16. #6139
      Jul 2019
      FRANCE
      Wheel change for winter ... Black Polestar!
      2012 V60 D5 AWD 230HP Cosmic White
      upgrade Polestar
      Bodykit + accessories Polestar
      Exhaust Polestar Performance Parts
      20" genuine Polestar / 19" genuine Polestar for winter
      2010 FOCUS RS MK2 White
      Kit Mountune Performance RS500 by Ford UK (Intercooler, airbox, fuel pump, exhaust, ECU remapping)
      Big brakes AP Racing
    17. #6140
      Nov 2002
      Russell Twp, OH
      Cool color. I don't think we got Cosmic White in the US.
    18. #6141
      Quote Originally Posted by Wayne T5 View Post
      I’ve seen a couple of white P* Engineered cars in the U.S., including a wagon in Boston, MA.
      12.99 at 109mph
    19. #6142
      Member Veefifty T5AWD's Avatar
      Feb 2009
      Lakes Region NH
      Quote Originally Posted by Bunnspeed View Post
      Yes, but not Cosmic white. The last time the US saw Cosmic was with the C30.
      Logan
      2015 S60 T6 AWD R-Design Polestar
      2008 S40 2.4i - hers
      Former:
      2013 C30 Polestar Limited Edition #87/250 | 2005 V50 T5 AWD | 1995 Yellow 850 T5-R
    20. #6143
      Quote Originally Posted by Veefifty T5AWD View Post
      Ah. I did not realize there were other whites available on this car. I do like the white on the US Polestar cars.
      Incidentally, this afternoon I saw a wrecked white Polestar V60 turn up on eBay, being parted out by a salvage yard in MA. I wonder if it's that same car I've seen in Boston.
      12.99 at 109mph
    21. #6144
      Feb 2009
      Lakes Region NH
      Oh yeah, those jokers have been trying to part that car out for almost a year. They are asking stupid prices for the parts, so it continues to sit. I inquired about some pieces when it first came up on FB an they wanted nearly new retail prices for them.
      Logan
      Former:
    22. #6145
      May 2019
      Chicagoland
      Ah, it's a non-US stock color. I thought it was custom. I really like it.
      I cringe every time I find a V60/S60 being parted out by a salvage yard. Prices are definitely very high.
      2018 V60 T5 Dynamic AWD, Osmium Grey Metallic
      Previous cars: 2003 Infiniti I35, 2003 VW Passat GLX Variant, 1993 Toyota MR2 Turbo, 1991 Honda Accord LX
    23. #6146
      Sep 2015
      Yes, I have noticed that car for a while on Ebay. I sent them a note once about the catback and the only reply I got was: "The catback is not for sale". I'm still wondering if they sold it already or just don't want to sell it.
    24. #6147
      Feb 2009
      Lakes Region NH
      Quote Originally Posted by FAUGrad View Post
      Yeah, they didn't want to truly part it out. I wanted the lower rear diffuser and they were only interested in selling the entire bumper.
      Logan
      Former:
    25. #6148
      Jul 2016
      Stockholm
      Missing the snow, the AWD is so fun in the corners.
      2014 XC60 D4 AWD R Design Momentum BE PRO II 707 crystal white pearl - The daily diesel.
      1995 855 T-5R automatic 421 dark olive pearl - The long time project.
      https://www.instagram.com/t6blacksapphire/
    26. #6149
      Junior Member AndrewsV60's Avatar
      Jul 2019
      San Diego, CA
      Got my kw coilovers in the mail. Installing Tuesday.
      Attached Images Attached Images
    27. #6150
      Aug 2015
      Ohio
      After having owned the car for more than 4 years, I just now found out that locking the glove-box puts the car into valet mode and also keeps the trunk from opening.....I guess I should have read the owner's manual more closely, lol
      2012 Volvo S60 T6 - IPD Rear Stabilizer Bar and IPD Rear End-Links
      2005 Pontiac GTO - Corsa Sport Exhaust, GMM Ripshift Shifter, Pedders Stage II Suspension
    28. #6151
      May 2015
      It's raining - must be near Seattle
      Quote Originally Posted by MightyVoice View Post
      Only if you turn the glovebox lock the full 180 degrees.
      If you turn the lock 90 degrees it locks only the glovebox and not the trunk.
      I'm not good, I'm not nice, I'm just right.
      2012 S60 T6 R-Design | 1998 S70 T5 SE | 1986 944 Turbo
    29. #6152
      Aug 2015
      Ohio
      Quote Originally Posted by zenmervolt View Post
      Wow, okay, had no clue, that's actually pretty cool, thanks for the info! Learn something new everyday about these Volvos, lol
    30. #6153
      Jul 2019
      San Diego, CA
      Kw coilovers installed. Rides better than stock.
    31. #6154
      Junior Member WagonMafia's Avatar
      Apr 2015
      Illinois, USA
      Wow, tucking in the rear but looks very nice! Are you rubbing in back at all at that height? I have considered getting KW's too for ride height and ride quality improvements over the stock R-Design suspension.
      Quote Originally Posted by AndrewsV60 View Post
      Nick
      2015.5 V60 T6 RD, Crystal White Pearl
      19x8.5 +45 O.Z. Ultraleggera HLT on 235/40R-19 Pirelli Cinturato P7 Plus
    32. #6155
      Feb 2015
      Better than stock?!
    33. #6156
      Better than stock?!
      My KWs definitely do *not* ride better than stock, lol. They certainly handle better and have higher quality damping but the overall effect is stiffer by quite a bit.
      12.99 at 109mph
    34. #6157
      Jul 2019
      San Diego, CA
      Quote Originally Posted by WagonMafia View Post
      I have my front and rear fenders rolled. The coilovers are actually in the highest height setting. There are 20 clicks for each of the coilovers. I had them at 10 clicks and the ride was smoother than with my current 19” OZ wheels with the stock dynamic suspension. But it’s not as smooth as when it was stock with stock 18” wheels, of course. I changed all 4 shocks to 6 clicks down from 20 (if that makes sense) at lunch break and it’s a little rougher but the firmness is worth it so you can almost go normal speed over speed bumps without hitting the liner.
    35. #6158
      Jul 2019
      San Diego, CA
      Better than stock?!
      They don’t feel stiff and when I had the dynamic suspension I could feel all the ripples on the San Diego highways. But when you have the coilover set to neutral then it absorbs the bumps better than the dynamic suspension did. I’m sure if I had the touring suspension that would have been the best ride quality.
    36. #6159
      Apr 2015
      NH
      Finally put my new stickers on, +5 hp ftw!
      Still have to put my swedespeed.com stickers on, but have to wait till it's not -8* outside.
      holy hell, dont mind the dirt everywhere!
      2018 S60 Cross Country - CPO
      2016 S60 Cross Country (totaled)
      2010 s40 AWD R-design (sold)
      2005 s40 T5 (sold)
    37. #6160
      I see that you played around with some damper settings. I have yet to deviate from the recommended damper settings which do seem to be a pretty decent ride/ handling compromise and are comfortable enough that I want to let well enough alone. A little stiff but not uncomfortable by any means. You’re at the highest ride height which also makes a big difference in ride quality. When I first had my KWs installed I was pretty much slammed (by Volvo standards anyway, lol), riding about 3” lower than stock T6 height. It looked cool but big bumps were truly jarring and would try to launch me out of my seat, I scraped with any kind of meaningful entryway approach angle or road crowning, and cornering was worse than stock as I would rub if I took corners at more than 7/10ths.
      I eventually had my indie shop raise my suspension about an inch to get back a modicum of functionality, what with needing to haul me and my wife and infant around like a normal human f’n being. I believe the height settings ended up being as high as they could go in the rear, and raised a similar amount in the front (with more adjustment available) to keep it level with the rear. It still looks lowered but the slight increase in ride height made a night and day difference in ride quality and the ability to use my car with fewer compromises to basic functionality.
      TL;DR these KW V3s can be brutal if you want to get low, but ride quality improves tremendously when you run them at a more conservative ride height. I’m not sure if their effective spring rate increases when they are low, or if the harsh ride was more a factor of inadequate suspension travel at that height, but they do ride much more comfortably and handle far better when they have some additional travel.
      12.99 at 109mph
    38. Remove Advertisements
