Custom S60R Hood Scoop to cool turbochager - Page 7
    Page 7 of 13 FirstFirst ... 3 4 5 6 7 8 9 10 11 ... LastLast
    Results 211 to 245 of 439
    1. #211
      Member Saleen9090's Avatar
      Mar 2011
      St. Louis, MO
      Quote Originally Posted by crazyace1104 View Post
      Scoopy it is now for life! Forum trended nickname
      If we rename dougy "scoopy" then we all need a nickname. It's only fair.
      2006 Volvo S60R GT - World Rally Blue w/ Black Wheels - Nordkap
      Performance Snabb: Intake pipe | IPD: AMS | VIVA: Upgraded CBV | CNT: Downpipe
      Cosmetic Custom : Headlights Part 2 | Taillights | Plasti dip | Front grill
      1995 Volvo 850 Turbo - White w/ Peg Reps - Beige
      Junior Member Paratrooper's Avatar
      Nov 2011
      Fountain, Colorado
      ooooohhhh how about Scoup Doug?
      2005 S60R MT IPD: Oval Exhaust, HD Upper Spring Seats, End Links, R-Kelly Intake, Coil Packs Snabb: Precision TCV, Turbo Intake Pipe H&R: 10/20mm Spacers Elevate: CBV Phuz: FMIC UR: Braces (All of them) CNT: DP ARD Custom Carbon Tune NGK: Iridium IX plugs
      Awaiting install: Greddy: Turbo Relief Valve
    4. #213
      Member Adrenaline406's Avatar
      Mar 2012
      SF Bay Area, Ca
      Why did you put it in the middle again? They said to bring it forward. It will fit the profile of the XC90 hood so much better. The colors are close too. You probably wouldn't need to paint it.
      '05 S40 T5 AWD 6 Spd - Custom Intake, FMIC & Spray, SMF, S60R Clutch, Muffler
      Delete, Eibach Springs, Corksport RSB, Front LCA Polys, 5mm Front, 20mm Rear, EFocusMnt
      '97 Isuzu Trooper 3.2L 5 Spd - PIAA Headlights, Lowered, Extended Shifter, 4Pt Harness, Plastidip
      '95 Go Kart 1 Spd - Kohler Engine, Mikuni Carb, Big Cam & Stiff Springs, R1 Exhaust
    7. #215
      Jun 2011
      Congo
      Maaaan I am still drooooooling over this pic...aaoaaoooohhhhhh so beautiful...I just have to put it on the R....
      1997 Toyota Avalon
      2000 Mercedes ML320
      2005 XCR90
      2006 C70
    8. #216
      Junior Member GrandpasD5's Avatar
      Dec 2012
      Quote Originally Posted by Saleen9090 View Post
      Well in that case...they call me...Tater Salad.
      Actually they call me the Wacky Iraqi.
      But back to Scoop Dougy Doug..I think his antics have earned him the title of Count Dougula for all the life he sucked out of me when I read this thread...Ill never be the same..
    9. #217
      Mar 2011
      St. Louis, MO
      Quote Originally Posted by GrandpasD5 View Post
      Actually they call me the Wacky Iraqi. It's hard to be a Mandaean Iraqi American! Too many nicknames, one peaceful identity. If you want to read more about my mysterious heritage, I have a great story:
      http://globalatlas.blogspot.com/2012...ry-of.html?m=1
      Damn no one asked for a life story
    10. #218
      Global Moderator CMOD_R's Avatar
      Nov 2011
      Franklin Ma
      ok queen sounds good to me
      2000 Laser Blue V70R
    11. #219
      Mar 2011
      St. Louis, MO
      Not sure where that one came from
    12. #220
      Member Our R's Avatar
      Jul 2003
      Minnesota
      Quote Originally Posted by dougy View Post
      I think there should be a gauge pod out on the hood also. You know you want to do it Dougy.
      Life's journey is not to arrive at the grave safely in a well preserved body, but rather to slide in sideways, totally worn out, shouting "Holy ****, what a ride!"
      Presently taking a ride thru the Black Forest.
    13. #221
      Member evilspoons's Avatar
      Jul 2008
      Edmonton, AB, Canada
      Oh my, that's fugly... and I've switched from Volvo to this now (so I'm not totally opposed to scoops):
      Anyway, if you're serious, it ought to be wider and lower in order for it to look good - ignoring functionality completely, of course.
      Currently driving: 2012 Subaru Impreza WRX STi 5-door, 1991 940 Turbo sedan.
      Written off: 2005 S60R. Magic Blue/Nordkap Sold: 2004 S60 2.4i, 1987 740 Turbo
    14. #222
      Jun 2011
      Congo
      Quote Originally Posted by evilspoons View Post
      what are you still doing here, go get your R back....
      i would love to see your WRX in a wind tunnel...lolol
      1997 Toyota Avalon
      2000 Mercedes ML320
      2005 XCR90
      2006 C70
    15. #223
      Dec 2012
      Are the stock scoops not functional on the wrx?
    16. #224
      Jun 2011
      Congo
      do you think the scooper like you have on your WRX would help that BRZ....
      1997 Toyota Avalon
      2000 Mercedes ML320
      2005 XCR90
      2006 C70
    17. #225
      Member LOGBOMB's Avatar
      Jul 2009
      Old Saybrook, CT
      Are you saying you want to be called queen? Lol that's precious!
      2004 S60R, black sapphire, nordikap, M66, Autotech Stage2, K&N, 3" DP, EST catback w/ EST res delete, viva HD CBV,viva FMIC, TWM short shift, snabb intake pipe, TME springs, IPD track spec sways.
    18. #226
      Member tuscani66's Avatar
      Oct 2007
      Pittsburgh, PA // Ft. Bragg, NC // Woodstock, GA
      They are, they feed cooler air to the top mount (above engine) intercooler. As most convert to a FMIC, the hood scoop no longer is needed, in theory.
      Keoni - 2004 SR Saphakap MT||VolvoTista: BOV Kit // IPD: Strut Bar Conv, Upper Polly Mount, Trans Polly Mount // Elevate: Track Sways, SS Brake Lines, AMS // Phuzzy: FMIC, HD TCV // WothRline: Custom Tune // Custom 3" DP w/Magnaflow Cat w/ 3" Cut-Out // Custom 3" Exhaust w/Borla XR-1 muffler to dual exit 2.5" (quad tips) & Magnaflow resonator // Custom 3" CAI // SNAAB: Intake // UR: Pulley
    19. #227
      Feb 2013
      Snoqualmie WA
      only until you install a FMIC.
    20. #228
      Dec 2012
      Quote Originally Posted by BryanO'Blivion View Post
      Right brighter. Tmic's look great on those boxers.
    21. #229
      Member MN-TURBOR's Avatar
      Jun 2011
      Twin Cities, MN
      found another hood scoop but on a R wannabe
      https://sphotos-a.xx.fbcdn.net/hphot...66417930_n.jpg
      2007 S60R - Ti Grey/Atacama M66 - Stage II Shark Tune - 8EightFab downpipe - Custom Magnaflow Exhaust - SNABB FMIC/Intake Pipe - TWM Short Shifter - Forge CBV - UR Front Brace/Rear Brace - IPD 28mm Rear Sway Bar - BC Racing Coilovers
      2007 XC90 V8 Sport - Electric Silver - Muffler/Resonator Delete
      2007 XC70 - Ice White - Stage I Shark Tune - Muffler Delete
    22. #230
      Jun 2011
      Twin Cities, MN
    23. #231
      Junior Member Stuntman315's Avatar
      Dec 2010
      AZ
      Quote Originally Posted by MN-TURBOR View Post
      Oh my... I hope that's not real?.
      here is what I do http://www.youtube.com User name Othatguy315
      "You're either part of the solution, the problem or the landscape"
    24. #232
      Nov 2011
      Franklin Ma
      Quote Originally Posted by Stuntman315 View Post
      posted on IPDs facebook -___-
    25. #233
      Dec 2012
      Pretty horrifying. I know electric green is in...for econobox cars. But at the other end of the color spectrum for high performance..most popular new color goes toooo....Rebel blue.
    26. #234
      Jun 2011
      Congo
      well, owner whom ever he or she is ....is definitely not a follower and does what he or she desires or likes and not whats in...I give him thumbs up...
      1997 Toyota Avalon
      2000 Mercedes ML320
      2005 XCR90
      2006 C70
    27. #235
      Member Red_Devil's Avatar
      Jun 2010
      Mass
      Holy windshield stickers.
      2018 Leadfoot Ford Raptor.
      05 S60R MT, Stock block 578AWHP, 12.2 1/4 mile at 124 mph. Built 804 AWHP. Built engine, Cnc ported head, Front & Rear LSD, Ported Gen 2 T4 GTX3584RS hybrid, Turbosmart 45mm WG, Tial QR Bov, Enem Y21 Cams, Radium Surge tank, 1700cc Id's, Triple Walbro 485's, PM3, Devils Own meth injection, speed density converted mafless setup, Bell FMIC, Snabb air box, Poly, Milletech intake manifold, IP plasma coils, IP Plasma lift. Snabb shifter. TTV Twin Clutch. GB Forgestar F-14's, Enkei RSF5, KW V2'S, Ur Braces, Vr sways, IPD toe bars. Built to the hill.
    28. #236
      Moderator tomedkaz's Avatar
      Nov 2007
      Woodbridge, NJ
      believe it or not this was a factory ... or rather dealer option. I remember noticing it when I looked at a C30 a few years back... one of the options was a HOOD SCOOP! a fake one too!
      here are some reference links
      https://forums.swedespeed.com/showthr...0-hood-scoop!-!
      http://www.volvopartswebstore.com/sh...ey_model=11970
      2004 S60R 6MT HILTON 2.5 Tuned
      CLICK HERE for Build Thread
      My wife's car: 2015.5 XC60 CLICK HERE
    29. #237
      Junior Member napkinn's Avatar
      Jan 2012
      Quote Originally Posted by ojs View Post
      Dougy, I think your scoop should vent out the back like this:
      But for mine, this is what I'm am doing:
      OK, just so we're clear, there are vents and there are scoops.
      What the OP posted is a scoop. It will take the care in. What is shown on that Vette is a vent. The air is exhausted through the vent, taken in from the lower grills. This is much better for cooling, as it doesn't ruin the aerodynamics of the car and it provides better flow for the air. The air will go out the vent and meet the air going over the car in a much more amicable way that if it's taken into the scoop and bounces around under the hood until it finally finds a path out. There's no channel running out, so a scoop on our cars will just result in the air pressure under the hood increasing a bit and eventually pushing out the seems, or possibly even the front, where that super heated air will now be sucked right back into your engine.
      A SCOOP is only ever good if the air is being injected into something, like an air intake or intercooler setup. For cooling, use the vents already on the car and maybe provide a path for it to get out. The best way to air cool is to allow the air in and out. It's not the air going in that cools the engine/turbo, it's the hot air leaving and being replaced with the new cold air.
      2011 BMW M3 - Mine
      2017 BMW X3 M-Sport - Hers
    30. #238
      Jun 2011
      Congo
      Quote Originally Posted by napkinn View Post
      ohhh gawdddd ,so what you are Saying napkinn that at 40 mph if I tape thin strips of napkins in front of my scoop the air will blow out instead of being sucked in? Cause I might have to scrap this idea.
      1997 Toyota Avalon
      2000 Mercedes ML320
      2005 XCR90
      2006 C70
    31. #239
      Jan 2012
      Oh, it will go in there. It's just not going to do crap to cool your turbo.
      And it won't be sucking it in. It will be forced in.
      2011 BMW M3 - Mine
    32. #240
      Member TexasV60P's Avatar
      Jul 2004
      Dallas, TX
      Hood Scooooop
      Go For It!
      2015.5 #39 BSM V60 Polestar arrived 11-24-2014
      2004 V70R GT: SOLD Silver+Nordkap, Premium Sound+Subwoofer, Motorola BT, iMIV, IPD Stage II - DP - HDTCV, Kelly CAI, BMC, 10MM Spacers, Volvo DEM heat shield, '06 V70R console
    33. #241
      Jan 2012
      Quote Originally Posted by TexasV70R View Post
      Go For It!
      One of the worst photoshop jobs ever.
      2011 BMW M3 - Mine
    34. #242
    35. #243
      Jan 2012
      Quote Originally Posted by R.Photo View Post
      Guess again.
      No, I said one of the worst. Not the worst.
      2011 BMW M3 - Mine
    36. #244
      Jun 2011
      Congo
      ok, I will reveal what the scoop is going to be for.
      1997 Toyota Avalon
      2000 Mercedes ML320
      2005 XCR90
      2006 C70
    37. #245
      Feb 2013
      Snoqualmie WA
      oh, now i get it.
