DIY #1: Aftermarket In-Dash GPS/DVD on XC90 Solved - Page 7
    Page 7 of 8 FirstFirst ... 3 4 5 6 7 8 LastLast
    Results 211 to 245 of 270
    1. #211
      Apr 2014
      Alabama
      Quote Originally Posted by robtr8 View Post
      If you remove the factory HU, it will throw an SRS light. Is it the open link in the MOST loop or is it the missing CAN bus module?
      All I know for sure is if you remove ALL of the MOST stuff (HU and amp) AND install the InCarTec CAN bus link lead and CAN bus/steering wheel control interface, you get no SRS light.
      Great, thanks. So Ill order the link lead, amp bypass and steering wheel adapter. That comes to around $200 U.S. shipped. Not too bad!
      Apr 2014
      Alabama
      I found another place in the States that has several install kits for the xc90. they are cheaper than incartec too! Here's the one I'm ordering today: https://www.spiralaudio.com/index.ph...d=1058&search=
      The antenna adapter they sell for 2007 and up is the AA-0012
    4. #213
      Apr 2014
      Alabama
      I got my kit delivered from spiral audio and I'm installing this weekend. Adding a Pioneer AVH-NEX4201, satellite radio and backup camera. A few questions for the board: first, does disconnecting the orange cable from the cd changer cause any warning lights to go off. I don't think so but want to confirm. Second, where are most people mounting the usb connection. I'm connecting my iPhone so I don't want to put it in the glove box. Thanks for answers to the above and any other helpful hints! I'll post my progress for anyone interested in the Spiral Audio kit.
      SwedeSpeed.com
      Member RedGeminiPA's Avatar
      Nov 2013
      Altoona, PA
      The orange "cables" on the CD changer are fiberoptic. As always, when disconnecting the head unit, you must disconnect the battery first, after the car has been turned off for at least 5 minutes. When reconnecting the battery, the key needs to be in position II.
      2006 XC90 V8 w/ Climate, Touring, Convenience and RSE. Silver w/ Graphite
      2014 Lincoln MKT EcoBoost Elite, Tech, Pano, 20”, Rear Captains. Pearl/Black
      Past: 2008 XC90 V8 w/ Climate, BLIS, Dynaudio, Bi-Xenon. Ember black w/ Sandstone
      2004 XC90 2.5T AWD 7-Passenger w/ Climate, Premium and Versatility packages and Xenon headlights.
    7. #215
      Apr 2014
      Alabama
      Quote Originally Posted by RedGeminiPA View Post
      Thank you!
    8. #216
      Junior Member robtr8's Avatar
      Jan 2009
      Nellyville
      When working on the center stack, you’ll want to disconnect the climate control module. DO NOT do it without following the battery disconnect procedure or you’ll get the SRS code.
      I extended the USB and mounted it inside the arm rest storage. https://www.crutchfield.com/p_541USB...iABEgJzXPD_BwE
      2006 XC90 V8, DMH-WT7600NEX, PDX-F4(X2), M12, GB10, GB25, GB60, GB12D4(X2), custom exhaust, Verde A/S Plus 107V/Ronal RT, IPD bars.
      2008 328xi, AVH-X7800BT, GM-D8604 & D9605, MT-230, GB40, XE 200, 12" Primo, Musicar NW box, P-Zero/Ventoso's, Sottozero 3/185's.
      2011 XC60 T6 RD, DWS/20" Cratus, IPD rear. 1980 TR8​, MBT-RX, Overdrive Plus, GM-D9605, GS62, 8" L7T(X2), NT05 on Revolution Wheels.
    9. #217
      Apr 2014
      Alabama
      Thank you. So is there an opening through the bottom of the console through which to run the usb cable? I already have the cable you linked. Also, the battery off procedure is turn vehicle off and then disconnect after five minutes?
    10. #218
      Nov 2013
      Altoona, PA
      Quote Originally Posted by jtrippe77 View Post
      Correct, and you only have to disconnect the negative terminal. When reconnecting, turn ignition key to position II before connecting the terminal.
    11. #219
      Apr 2014
      Alabama
      Thank you! I’m looking forward to the install
    12. #220
      Apr 2014
      Alabama
      Install done! The spiral audio kit works great. No warning lights or issues. The steering wheel controls automatically worked. The fit of the fascia isn't the greatest and I'm still working on it. I had a hard time getting everything to fit behind the radio. I have the usb cable coming out between the cupholder and the center console. The mic is above the steering column. The only issue with the spiral kit was the antenna adapter. I found the antenna lead in the car easy but the Spiral adapter had to be cut. The prongs were too close together. The only major problem is that I haven't gotten the backup camera working yet. I just get a black screen when I go into reverse. I think we may have grounded in the wrong place. We grounded in the top of the hatch. I think we should've grounded at the reverse light. I don't know what the else the problem would be. We'll tinker with it some more. Overall, I'm very pleased. Adding the sub next weekend but already run the RCA and turn on cable to the rear. The camera install is not easy. The stereo install was pretty straight forward.
    13. #221
      Jan 2009
      Nellyville
      The hatch is fiberglass. Might need to go back in and test your ground.
    14. #222
      Apr 2014
      Alabama
      Re-wired camera power and ground to reverse light area and all works well. Added a sub as well. Loving my xc90 with aftermarket upgrade!
    15. #223
      Junior Member MattyXXL's Avatar
      Jun 2011
      Miami, FL
      Could someone tell me which wire on an 08 factory harness gives the illumination/dim function?
      1995 Yellow 854 T5-R
      2010 Burgundy XC90 3.2 FWD
    16. #224
      Nov 2013
      Altoona, PA
      Quote Originally Posted by MattyXXL View Post
      Please tell me you're not splicing wires to install a head unit...
    17. #225
      Jun 2011
      Miami, FL
      Negative LMAO.. I installed an R cluster im my xc90 and need to find the illumination lead to hook up the LEDs.
      Seen the illumination wire mentioned but nobody has said what wire exactly it is.
    18. #226
      Administrator chris@swedespeed's Avatar
      Dec 2000
      DC Metro
      2016 V60CC Platinum | Beechwood Brown interior swap |
      2016 S60CC Platinum with lowered sport chassis | Polestar Performance Springs |
      20-inch Cratus wheels | Elevate GT5 Exhaust, rear sway bar, brake lines, rear spoiler
      2017 XC90 Momentum Plus (family)
      Previous:
      2017 S90 Inscription T6 AWD, 2019 XC40 R-Design T5 AWD, 2017 V90 Cross Country T6 AWD , 2018 V60 Polestar #103/1500, 2016 XC90 R-Design, 2013 C30 Polestar #141/250,2015.5 V60 R-Design,1998 V70 T5M, 1999 S70 GLT, 2000 V70R, 2004 V70R, 2006 V70R Sonic Blue, 2006 V70R Electric Silver, 2007 V70R Passion Red, 2003 XC90 2.5T, 2007 XC90 V8 Sport Electric Silver, 2007 XC90 Sport V8, Passion Red
    19. #227
      Junior Member jdizzle1788's Avatar
      Jan 2011
      Kenosha Wisconsin
      Ill touch base and let you guys know how the Axxess one works.
      Info on my Xc90
      2009 R-Design
      Base 8 speakers
      3rd row with rear A/C
      Factory Navi without back up "Camera"
      Factory Back up sensors
      09 S60 2.5T SE | Garage Queen
      09 XC90 3.2 R-Design | Daily
    20. #228
      Jan 2011
      Kenosha Wisconsin
    21. #229
      Jan 2011
      Kenosha Wisconsin
      factory navi is working, no sound through speakers which isnt a problem. Lots of trial an error.
      Once you do the installation, you loose factory navi and back up sensors, the kit i used supplied a external speaker for backup which is weak but works.
      Running
      Axxess Volvo XC90 Data Interface with SWC 04-14
      Connects2 CT27AA35 - Antenna Fakra
      Eonon GA2170 running with hotspot
      Skar Audio
      SK-M9005D 5 channel amp fits under passanger seat on top of factory amp
      Tx65 component speakers for front
      Tx65c 2 way for rear
      Txt for rear pilllar tweeters
      VD-8 D4 subwoofer
    22. #230
      Oct 2017
      New Hampshire
      Just noticed... In the photo your "Auto" light and fan speed light both appear to be on. I can't do that with mine; as soon as I touch the fan speed the auto goes out, and when I press auto the fan speed goes out...
      John C
      2011 XC90 3.2 176,000 miles and counting...
    23. #231
      Jan 2011
      Kenosha Wisconsin
      Quote Originally Posted by John C View Post
      thats how mine is
    24. #232
      Jun 2019
      Denver, CO
      Semi-related question: I'm going to be replacing the lights within my accessory switches below the climate control, and in order to gain access I need to unplug and remove the stock radio unit. Question is, do I need to disconnect my battery?
      Nothing is changing other than taking out burnt out bulbs and replacing with new, and radio will be out for 10 minutes tops.
      2012 XC90 R-Design 3.2 AWD
    25. #233
      Oct 2018
      San Diego, CA.
      I don't have personal experience with this, other than always disconnecting the battery when pulling the console apart. From what I've read in other posts, though, others have had to reset the SRS with their VIDA as if it's a common issue. But then, disconnecting the battery and resetting the clock just isn't that big a deal, to me. Certainly less trouble than dragging out the laptop and struggling through the menus to figure out how to reset the SRS. Besides, one caution I've come across is some concern that the airbags could fire from messing around in there with the power on, but I don't know how real that is.
      2009 XC90 FWD 3.2, 2013 S60 T5
      In the past: '89 745, '91 940, '82 242, '67 122S, '67 123GT, '71 142E, '62 PV544.
    26. #234
      May 2019
      Is there anyone in the Los Angeles are that can help me with replacing the factory unit? I will buy the parts, etc and pay for your service. Thanks.
    27. #235
      Junior Member skifreak85353's Avatar
      Jul 2004
      Arlington, VA
      Mentally gearing up for this...is this an either/or regarding Axxess and Incartec?
      2014 Audi Allroad Prem+
      2009 XC90 V8 R-Design
      2013 WRX Limited Hatch - Satin White Pearl (Gone)
      2005 WRX Sedan (Gone)
      1998 V70R (Gone)
    28. #236
      Aug 2019
      Just finished my installation yesterday with Axxess AX-VL90042 (as I have parking assists) with AVIC-W8400NEX. Everything is working fine beside the controls on the steering wheel. I have the ASWC-1 interface but only volume up works. Wanted to update and thank you all for all helpful posts.
      Cheers!
    29. #237
      Aug 2019
      Texas
      https://www.scosche.com/vo4155srb
      I can vouch for this kit. At $110 it has everything.
      Things to note.
      I do not have factory navigation.
      The website says it keeps the factory amp, it does not.
      The steering wheel buttons work and no SRS light, but the main display stays connected and hidden behind the double din.
      I went to the junkyard and grabbed a speaker pigtail for the amp, plugged it into the amp after install and wired two tweeters to the rear speaker wires and stashed them under the passenger seat, which allowed me to keep the backup warning sensors.
    30. #238
      Aug 2015
      I would love to hear how you put this together. How did you wire in the factory speakers if you didn’t use the amp .
    31. #239
      Aug 2019
      Texas
      When you install the scoshe kit it has plugs that you use to plug the factory amp plugs into. So, the amp power plug becomes the double din power source and the amp speaker plug becomes the double din speaker plug. This leaves the amp there with only the fiberoptic plug connected. The factory radio display also gets plugged into the new harness and stashed behind the double din.
      So, i went to the junkyard and bought both amp pigtails. I plugged them into the amp. I ran power for one pigtail, and for the speaker pigtail i plugged it in and connected two small tweeters to the rear speaker leads and stashed them under the passenger seat. All the MOST fiberoptics stay plugged in except for the cd changer. Now, i have a double din running independent of the amp and the amp is used solely for the backup sensor beeps.
    32. #240
      Junior Member SteveP's Avatar
      Dec 2001
      Auburn, NY
      Quote Originally Posted by Noonespecial View Post
      Things to note.
      I've just bought an 06 XC90. The angle of the face of the stock stereo has me concerned. Does the schosche kit fit on the same angle?
      His: 2018 S90 Momentum Osium Gray/Black Hers: 2015.5 V60 Premiere E-Drive Silver/Black
      Gone But Not Forgotten: 2006 XC90 V8 Silver/Black, 2010 C30 T5 R Design Passion Red, 2004 V70R Ti/Gobi, 2004 S80, 2001 V70, 740GLE and too many 240s to count!
      To R is Still Human!
    33. #241
      Aug 2019
      Texas
      Yes. It fits nicely
    34. #242
      Jul 2019
      Bump old topic
      Where did you placed your GPS antenna?
      Mine is under the dash at the place of the center speaker (wich is removed) but GPS is a bit off... To often thinks I'm driving another road next to me.
    35. #243
      Apr 2020
      So a reply from incartec guy saying not to remove the amp completely. With this kit I can do that safely right?
      https://incartec.co.uk/product/Volvo...ace-FK-860-PDC
    36. #244
      Apr 2020
      Why position 2?
    37. #245
      Jan 2009
      Nellyville
      Installed a new DMH-WT7600NEX.
      Attachment 62639
    38. Remove Advertisements
    Similar Threads
    1. DVD GPS Aftermarket for XC90...anyone have this?
      By GabXC in forum Car Audio, Video & Mobile Electronics Forum
      Last Post: 03-26-2014, 09:10 PM
    2. Will our NAV system DVD players read DVD-R or DVD+R? Dual layer?
      By S60inToronto in forum R Forum (2004-2007)
      Last Post: 02-06-2009, 08:54 PM
    3. 2002 S80 T6 - GPS / Navigation DVD Error, Nav System Says it Cannot Read DVD
      By 02_S80_T6 in forum Car Audio, Video & Mobile Electronics Forum
      Last Post: 10-11-2008, 03:59 PM
    4. completed, DVD in the HU and aftermarket GPS and reverse camera
      By avishay32 in forum Car Audio, Video & Mobile Electronics Forum
      Last Post: 04-29-2008, 10:21 AM
