2010 18" XC60 wheels on a 2014 XC60?
    Results 1 to 3 of 3
      Dec 2013
      Appleton, WI
      Smile 2010 18" XC60 wheels on a 2014 XC60?
      I'd like to get a second set of wheels (18") and winter tires for my 2014 XC60 with TPMS. I have three questions: Will 2010 XC60 wheels fit on the 2014? Will 2010 TPMS sensors work with the 2014? Do I have to take the vehicle to the Volvo dealer to program the sensors, or will they "self" program by merely installing them and driving for a short period? Thank you in advance for any advice, it is much appreciated
      Member Penguin's Avatar
      May 2006
      Reno, NV
      Any wheel displayed in a XC60 Brochure will fit any XC60 model, regardless of year. From what I have read, it sounds like the sensors are the same across model years. If the recommended tire pressure of the 18" tires you are going to install on your 2014 XC60 is different than the recommended tire pressure of the OEM tires that came on your XC60, the Owner's Manual says the TPMS has to be recalibrated by a Volvo service technician. It is interesting to note that recalibrating the TPMS on Canadian XC60 models can be done using the My Car system.
      2015.5 XC70 T6 Platinum Caspian Blue Metallic/Off Black, Heico Sport Suspension, IPD swaybar, Ferrita/TME Exhaust, Polestar #1640
      2014 XC60 R-Design Passion Red/Off Black, OSD, Savini BM7, Eibach Lowering Springs, IPD swaybar, Koni FSD, Polestar #1563
      2006 V70R 6M ElecSilver/Nordkap, 18" Pegs, Bell FMIC
      2004 S60R 6M TiGrey/Nordkap, 18" Ti Pegs, Bell FMIC, IPD Stage II, TME Exhaust, Eibachs, Quaife LSD
      Dec 2013
      Appleton, WI
      Thank you for the reply! I've purchased the 2010 wheels (based on your comments). My vehicle recognized the sensors instantly.
