Antherzoll's 05XC70 Build Thread
    Page 1 of 29 1 2 3 4 5 11 ... LastLast
    Results 1 to 35 of 986
      Member Antherzoll's Avatar
      Dec 2013
      Toronto
      Hey Guys,
      Not much of an introduction, but I'm Anthony and this is my XC70. Purchased in December 2012 with only 61k mi, now at October 2019 it's just over 145k mi and still going strong. Just pretty much doing my own thing and having fun with it as I go along. I've recently updated this thread with links, trips, and repairs, but feel free to message me with any questions.
      Enjoy!
      Engine/Transmission:
      - Hilton Tuning
      - TD04HL-16T (Modified): 11 blade GTX compressor wheel, 11 blade turbine, 7cm^2 turbine housing, 0.3 BAR Wastegate Actuator.
      - RaceS60R 3" down pipe w/catalysts
      - Eurosport Tuning Touring Exhaust
      - Do88 Intercooler
      - AEM Progressive WMI System
      - Volvo R model airbox w/MAF
      - IPD Turbo Inlet Hose
      - IPD Charge Air Pipe
      - IPD Throttle Inlet Tube
      - GFB Diverter Valve
      - Snabb Throttle Body and Manifold Spacer
      - Hayden Transmission Cooler w/ thermostat and inline filter
      - Oil catch can
      - Custom dual gauge mount w/ IPD Boost & Innovate AFR.
      Suspension/Drivetrain:
      - Bad Swede 2" lift systems
      - Custom 19mm rear strut mount spacers
      - Custom 16mm front/rear subframe spacers
      - XC90 336mm front & 308mm rear brakes
      - XC90 Lower Front End Conversion:
      XC90 control arms
      XC90 spindle/w hub & ball joints
      XC90 2.5t front left/right axles
      - XC90 17" Neptune Wheels.
      - XC90 235/65R17 wheel well modification
      - Toyo Open Country AT2
      - H&R XC90 25mm wheel spacers (rear axle)
      - XC90 V8 Gen3 (2008) Haldex DEM
      - IPD XC70 Sway Bars
      - IPD Subframe Inserts
      - IPD Skid plate
      Utility:
      - Yakima Load Warrior w/double extension, 4x cross bars, custom flush mount, tire carrier, load stops, quick fists.
      - Volvo 2" tow bar
      - LED Conversion resistor banks
      - H8 Battery Upgrade
      - Auxiliary Third Row Seats
      Trips/Adventures:
      - May/June 2015 Crosscountry Road Trip 10,500km Yellowstone/Cascades/British Columbia
      - August 2015 Haliburton Highlands
      - May 2016 Catskills Camping
      - May 2017 Bald Eagle State Forest/Volvos At Carlisle
      - June 2017 Kawartha Highlands
      - July 2017 Crosscountry Road Trip 8,800km Minnesota/Saskatchewan/Alberta/British Columbia/Lake Superior
      - August 2017 Haliburton Highlands
      - August 2017 Kawartha Highlands
      - January 2018 Oompah Winter Cabin
      - May 2018 Volvos at Carlisle
      - June 2018 Rockwood Conservation Area
      - June 2018 Halliburton Highlands
      - July 2018 Pinery Provincial Park
      - July 2018 Crotch Lake
      - August 2018 East Coast Road Trip 4,400km Quebec/New Brunswick/Nova Scotia
      - October 2018 Guelph Lake Reservoir
      - May 2019 Longpoint Provincial Park
      - May 2019 Haliburton Highlands
      - June 2019 Rockwood Conservation Area
      - August 2019 Crosscountry Road Trip 9600km South Dakota/Wyoming/Montana/British Columbia/Alberta/Lake Superior/Lake Huron
      Major Repairs:
      01-28-2015 - Steering Rack/Bushings/Spring Seats/IPD Swaybar Install
      12-13-2015 - Haldex pump replaced/fluid service
      01-20-2016 - Valvebody replaced
      04-24-2016 - Angle gear seals/collar sleeve
      03-26-2017 - Exhaust manifold gasket/Turbo turbine housing replacement
      08-15-2018 - Throttle body failure
      01-26-2019 - Bent rear toe arm and wheel
      Other Forum Threads:
      @antherzoll Instagram
      volvoxc.com thread
      Overland Bound Thread
      Member n00bkiller944's Avatar
      May 2008
      Newport News VA
      I think this is next on my list with an ARD tune!
      2005 XC70
      -Pioneer Avic F700 - 12 inch Alpine Type R Sub - IPD Blue Silcone Hoses - OBX Catback - Custom Window Tint - Custom Mesh Grille
      Aug 2009
      On a Great Lake
      Quote Originally Posted by Antherzoll View Post
      - ARD Green Stickers (adds 10hp )
      +1
      04 V70 2.5T AWD - AUTOTECH | SNABB | OBX | MAGNAFLOW | SNABB | BILSTEIN | EIBACH
      Dec 2013
      Toronto
      Update: http://www.volvoxc.com/forums/...T&p...d=1#post172664
      Finally had a chance to get around to installing all the part...well most of the parts. The catback exhaust is back ordered and will have to wait for later, but no biggie. Overall the install wasn't too hard, just took a lot of time and labour as this was my first time getting this deep into my XC.
      Here is my process:
      - Disconnected the battery.
      - Strut Brace: 4x 13mm bolt on the strut towers and one 18mm nut and bolt for the motor mount. There is one clip on the passenger side for a wire harness
      - Air Box: Removed all the part being supported to the air box. Disconnected the MAF and the intake pipe. Slide to the left and pull up.
      - Intake Air Pipe: Previously installed IPD intake pipe. Disconnect the pipe for the turbo housing. Pull back and turn CW to gain access to the 2 vacuum hoses and the PTC. Disconnect the the electrical connector for the PTC by pushing down on the metal wire on the connector. Disconnect the hose from the PTC and the 2 other hoses on the pipe
      - Charge Air Pipe: Previously installed IPD Charge Air Pipe. Disconnect the pipe clamp and fold out of the way
      - Turbo Heat Shield: 3x 10mm Bolts. Push the heat shield down into the space beside the downpipe then work it out.
      - Front O2 Sensor: Connector is located right under the intake pipe close to the turbo intake. The connector sits on a brace which is mounted with nylon retainers that can be pulled out. The connector has a white tab lock that lifts up to disconnect. Route the wire back to space where the O2 is located.
      Turbo/ Downpipe From Top of Car:
      - 3x 10mm Downpipe bolt. *Could also work the 2 lower bolts from underneath if access is too tight.
      - 2x 13mm Turbo to manifold nuts
      - 2x Vacuum lines from the turbo. one on the housing and one on the wastegate *MARK THESE
      - 1x 17mm Oil Supply Banjo Bolt from the top of the turbo
      - Loosen the coolant reservoir cap and the engine oil cap then lift the car.
      - Drain the coolant: Through the lower rad hose, block drain, or the radiator petcock
      - Drain the Oil: Not a must, but I was due for a change anyway
      - Downpipe Turbo Bottom of Car:
      Disconnect the downpipe from the exhaust, two bolts at flange.
      Remove the retaining bracket: 4x 13mm Bolts. Bracket retains the heat shield and some wiring.
      Disconnect the rear O2 sensor: the connector is located by the retaining bracket. It has a red lock tab the you can wedge a flat head under to disconnect.
      Remove the rubber hangers and the pipe will come free.
      Now for the fun part. You will become real familiar with your angle gear as it will get in the way of everything you do here.
      - Disconnect the Oil/Coolant pipe retaining bracket: Don't remember what size, but it was a tork head, and sits right behind the angle gear. It only hold the two pipes together and nothing else.
      - Remove the 2x 17mm coolant Banjo bolts: Fairly east as they are facing straight back.
      - Disconnect the oil return line: This one is a bit tricky. Used a 3/8" swivel ratchet connection with T30 tork on the end of a 18" extension. Used one hand to guide the bit, the other to work the wrench. Once the bolts are out, wiggle the other end out of the block and retrieve the O-ring from the block.
      - Disconnect the oil supply line: Not sure if you have to, but for the sake of not damaging it I removed it. Near the passenger side of the block facing back there is a 19mm banjo.
      - Remove the 2 lower manifold/turbo nuts: 2x 13mm nuts. the one on the passenger side was easier as there was good access. the other is kind of wedged between the angle gear and the transmission. Took me a bit of fussing but I got it out eventually. A 13mm stubby box-end wrench was key to my success.
      By now everything is loose and apart. I was able to remove the turbo from the space between the block and the passenger side drive-shaft from under the car. The new turbo fit into this space as well without a hassle. You can also fish it up and through the engine bay, but it's a bit tight.
      Pretty much install is the reverse of removal. I didn't use any torque specs, just my gut feeling to reassemble everything. The turbo came with a CBV block-off, the diverter valve I had ordered was a snap to put in with the bosses on the IPD pipes. After the oil and coolant was topped off, I pulled Fuse #11 from the engine compartment fuse box to disable the ignition coils, cranked the engine over a few time, put the fuse back, started it up and let it run for 15min before driving. Nothing has leaked so far and I have had it hot and cold several time. I haven't gone into boost territory yet, but i will post up some data later on once the break-in is done, but what I can say is that I already hear a major difference in the sound of the turbo spooling compared to stock.
      Although the hardware kit I received had gaskets and hardware to piece everything back together, it did not include new washers for the 19mm banjo bolt and new manifold to turbo nuts and studs. I had to go to my local dealer to pick up those extra parts and it came out to $40 for 2 manifold studs, 2 manifold nuts and 2 19mm copper washers. You need the manifold bolts as you will most likely not be able to retrieve the ones from your old exhaust housing,
      The tough parts of the job for me were:
      - Removing the Oil Return line from the turbo
      - Removing the lower diver side turbo to manifold nut
      - Removing the rear O2 sensor from the old cat
      - Reinstalling the Intake pipe to the compressor housing. A little vaseline would help here. I didn't realize it, but the inlet on the new turbo is just a little larger then the old turbo.... Had a good time with that.
      During the install I also replaced my front O2 sensor with a new bosch, a new MAF, and new plugs with the HD coils, and replaced my K&N for a OE filter for good measure. The car actually idles a ton better, nice and smooth with very little vibration. Not sure what did it, either it's because my engine is breathing easier, or my sensors were shot, or a combination of both, everything on my engine checked out before the install, and i don't think it's the tune as i was running the stage 2 tune with my previous setup for a week before this install with the same vibration. I'm very happy with this result as I became accustomed to the XC vibrating a bit at idle.
      Dec 2013
      Toronto
      Haven't had much time to play around with my upgrades because of work and family life, until this past weekend, just fell like I should update. I took the XC for a drive up to Barrie (approx. 100km from Toronto) and was able to get a feel of what this vehicle can do. It feels like a completly different car, both low end and top end are greatly improved. I'll take some logs and get some numbers on a bit later when I get the catback on, but I just want to say this upgrade gets my
      May 2008
      Newport News VA
      Such a sweet post/ thanks for the pics. I'm getting excited to do this on my car!
      2005 XC70
      Dec 2013
      Toronto
      Hello all
      So I've been having some fun with Torque Pro and I've been able to get some rough numbers of what gains were made with these upgrades.
      I've logged an average of:
      Power: 224.3WHP @ 4357‎ rpm
      Torque: 254.6Wft/lb @4357 rpm
      MAF: 235.3g/s.
      If I can work the math backwards.
      Power from MAF using: MAF(g/s) / 0.8 =
      BHP = 294.1BHP
      Using 25% drivetrain loss
      224.2WHP @.25 loss = 298.9BHP
      254.6Wft/lb @.25 loss = 339.4ft/lb
      These are not solid numbers, they can vary, but i feel it's a good enough ballpark to state for now and people like to hear numbers. I'd would like to take the information and graph the HP and Torque, but due to the low update rate of my GPS of 1Hz, the information is a bit scattered so it doesn't make for a good graph, I'll try to get out to the dyno one day for that.
      Also, the log files are missing, but i did do a comparison between a K&N panel filter and a Volvo filter and my numbers had shown no difference in MAF reading throughout the RPM range. So wanting my car to be a bit more obnoxious I installed one of these...
      http://www.aemintakes.com/search/pro...Prod=21-2038BF
      http://autohifidiszkont.hu/bmw-tunin...szuroteszt.pdf
      Didn't have time to DIY a heat shield, so I bought the one from EST then purchased a 8" AEM Brute Force dry flow filter. As for sound, it isn't obnoxious at all if you like hearing your turbo. Also i can hear my diverter valve on throttle lift, not too loud, just enough to hear a slight pssst.
      Dec 2013
      Toronto
      So It's been a while since Ive updated this thread so I thought maybe would now would be a good time to give one.
      The car was put on a dyno back in September and the numbers were a bit short of my predictions, mostly due to me running in a high ambient quite stupid of me, but when i had booked the appointment the average temps were ~15*C, didn't know a heat wave was coming. Been meaning to do another run, but I've never got around to doing so.
      I've also been troubleshooting a intermittent over boost issue ever since getting the upgrades and tune from ARD. Initially found out that the turbo supplied from ARD had a wastegate actuator that is to strong for my setup, was in contact with another owner of a ARD tuned LPT and he stated the same issue. Contacted ARD multiple times, submitted logs, and tried all of the suggested fixes including software to no avail. I'm currently running a weaker wastegate actuator at base setting and it has reduced the occurrence of tripping over boost, but it is not allowing the turbo to create max target boost and spool is slower. Through my e-mails with ARD I found the the customer service was quite the opposite from what I was led to expect from ARD, most of my questions were unanswered, took over 48h to receive responses, and responses were often vague leading me to search for answers elsewhere, maybe I'm not a big fish in ARD's eyes. Even if ARD can solve my issue, which I'm almost confident that they cannot, I've lost interest in dealing with them. The tune does runs great when the overboost issue isn't being tripped so I'm still enjoying my ride, but I'm currently searching for another tuner that will be more engaged and will offer better support, currently looking at JZW or Hilton Tuning.
      Anyways
      I've posted this here, but will repost.
      Upgraded my front rotors from 11" to 12" slotted and they feel great. Rotors are from Stop Tech and the pad are Hawk HPS semi-metallic.
      Changed around the back of my XC
      Yep a Fake-R
      And currently waiting to install a set of IPD sway bars :cool
      Alright
      so i picked up, bushings 11,12(square),13,14, and 15 today and had them installed in a hour and a half( thanks to the XC's high ground clearance, I seriously thought that this would have taken me more time.
      In the picture boxes for Part#611 and #613 are over the wrong bushing. In order of bushing they are 12,11,13,14, and 15
      The install was quite easy the hardest part was removing the old bushing for #13 and #11, a little fire took care of that.
      Ahhhh....roasty
      Had to cut out the metal sleeve from the bushing on the strut bar with a file after it was burned out, the small transmission torque mount has no sleeve. The upper engine and the larger transmission torque mount were removed by using a hammer and flat head screw driver.
      Once removed, all of the bushings went in quite easily with just hand pressure, no real forcing. I'm not a fan of the yellow brick that now resides on my upper engine mount, but i wasn't going to spend the time or money on a new round poly mount or used old and knock out the old bushing, maybe i can find a paint that would work on it. I haven't taken it for a ride yet, but I did let it idle in D while tightening all the bolts and there is more vibration for sure, sweet sweet vibrations. What i also noticed is that if I rock my car in P then engine has less of a tendency to rock as well, I'd like to see how this extra rigidity feels on the road.
      Anyways More pics, cause people like pics
      I took it out for a drive around town and I'm quite impressed with how the bushings feels. The only added vibration is from idle 650rpm to 800rpm on throttle, this vibration quickly dissipates after 800rpm and feels normal throughout the rest of the rpm range. It's not a major difference, but it's a pleasant one. Shifting between P-R-N-D has better engagement, shifting with the GT feels more solid both with upshifts and downshifts, and when applying throttle it feels more responsive. Can't wait to poly the rest of the bushings.
      Update on my experiences with polyurethane engine mounts.
      https://forums.swedespeed.com/showthr...=1#post2712009
      Aug 2009
      On a Great Lake
      +1 for poly. E a specially those control arm ones.
      Dec 2013
      Toronto
      Quote Originally Posted by Beck View Post
      I'm considering those next, kind of on the fence.
      Not sure if it's applicable to our vehicles, but does bring up some good points.
      http://www.iwsti.com/forums/gd-suspe...yurethane.html
      Aug 2009
      On a Great Lake
      The control arm ones take that dead spot on the steering wheel away. Such crisp steering response.
      Interesting article but a bit too theoretical. Real world experience with my bushings have been 95% positive (sway bar bushing gave out last year).
      Dec 2013
      Toronto
      Thanks, looks like a spring time project.
      Dec 2013
      Toronto
      Here's a sound clip of the exhaust setup. Taken with my Sony DSC TX-20, hope the sound came out good enough.
      EST Touring
      RaceS60R Catted DP
      Dec 2013
      Toronto
      My XC Before I Bought It
      Dec 2013
      Toronto
      Hilton Tune Loaded
      So I've recently flashed the ECU with a Stage 3 Hilton Tune and all I can say for now is the engine starts , haven't had any time to take it out for a run yet and might be some time until I can...
      Oct 2014
      Seneca SC USA
      ...when i had booked the appointment the average temps were ~15*C, didn't know a heat wave was coming.
      Nice car.
      But, on what planet is 15C a heat wave? I don't even like to get out of bed when it's only 15C, and I'm not even really happy if it's under 30C
      Engineer, Cyclist, Pilot, Geek
      eric(dot)hidle(at)gmail
      2001 V70 X/C, 2005 XC90 T6, 2002 V70
      Dec 2013
      Toronto
      Quote Originally Posted by ehidle View Post
      Nice car.
      I booked the appointment a few days in advance, the temps were averaging 15*C, but on the day of the run it was 34*C
      Oct 2014
      Seneca SC USA
      Now that is what I call nice weather!
      Junior Member A4Avant's Avatar
      Sep 2010
      NY 10925
      What does the Hilton Stg3 tune involve?
      2002 V70 T5 .....looking for Gobi R seats (F), H&R Lowering Springs
      2003 BTA4Avant
      ..... Built Motor, Comp Turbo CT5147
      IG: avantneil
      Dec 2013
      Toronto
      Requirements:
      Down Pipe, Cat-Back Exhaust, Front Mount Intercooler (FMIC), Larger Than Stock (Typically Hybrid) Turbo, Upgraded Injectors, Upgraded MAF
      Additional Requirements:
      Stock TCV or upgraded Pierburg valve. (Note: A MAC control valve or equivalent is not compatible with this product. If you are using one of these valves, ensure it is replaced with a Pierburg unit prior to tuning.)
      Recommended:
      Methanol Injection
      http://hiltontuning.com/product/stage-3-tune/
      My current setup consists of:
      TD04HL-16t w/7cm^2 ex. housing‎, 11 blade compressor & turbine wheels
      3" Downpipe w/high flow race cat.
      EST Catback
      Upgraded stock mount intercooler
      Blue Injectors
      IPD full line of intake and charge air piping
      Manifold & Throttle body spacers
      6"x8" Dry flow cone filter.
      I haven't started data logging yet, so I may need more parts, but my current set up has most of the requirements except for the FMIC, mine is a upgraded stock mount intercooler. If I have problems with IATs (which I haven't so far), then I may sell this unit and go for the FMIC.
      Also my "larger then stock" turbo isn't that much larger, it is a TD04HL-16T, there are other who have larger turbos on similar builds. If I want more some day I'll go for the 19T, or even 20T conversion. Gotta leave some room for upgrades
      Sep 2010
      NY 10925
      EST Catback
      Blue Injectors
      NICE! I'm still trying to learn these Volvo Turbos and what is what and what is equal to what power ratio.
      16t? No clue. I don't even know what turbo is on my car 2002 V70T5. But its Autoi so I don't see me going nuts with Power adders. Possible a one up - upgraded turbo. TD04HL is a MHI turbo. I do have a MHI TD05H-20g siting in a box. I don't think my Auto V70 would handle that too well if I was to find a way to make it fit/work on the Volvo platform. I had it on my BTA4Avant.
      I'm going to look into the stg2 tune by Hilton.
      2003 BTA4Avant
      IG: avantneil
      Dec 2013
      Toronto
      Quote Originally Posted by A4Avant View Post
      This may help
      http://www.wothrline.com/Cars_engine...rbocharger.htm
      I think your model came stock with the 16t, but I'm not sure.
      IIRC dougy has a 20G on his S60R, could look up his build thread for more information on how he made it work. A 20G should be ok, it all boils down to the tuning.
      Sep 2010
      NY 10925
      This may help
      that helped a lot. I don't see a turbo upgrade soon but def consider it. I will be doing mostly hwy driving so with ^that book marked and read, seems an 18t might be a good fit on the Auto with all supporting mods.
      I will be turning over the Audi to the wife she will be driving a big turbo'd monster to work for now. My car is too hard to driving in NYC traffic with a stg4 OFE SS clutch.
      2003 BTA4Avant
      IG: avantneil
      Jun 2011
      Congo
      This may help
      just an FYI Antheroll...20g is a nice upgrade, just know that the WG flapper and the hole is waaay too small and it is impossible to bore out so you don't have a boost creep, now on the one that i have "Super Hahns 20g" it just happened to creep to 20psi at redline which is about what I need to boost so it works out...but it is not right...only way to fix this creep issue is put on a nice external 38mm Waste-gate by drilling a hole on top through the exhaust housing...Rob at Hilton tuning discovered it and was able to tune nicely to the boost creep and the only reason why it worked out is my target boost of 22 psi is not lower than my 20 psi boost creep...
      http://volvospeed.com/vs_forum/topic...porting/page-3
      1997 Toyota Avalon
      2000 Mercedes ML320
      2005 XCR90
      2006 C70
      Dec 2013
      Toronto
      Quote Originally Posted by dougy View Post
      Missed out on that thread... So I guess my original statement is true, it all boils down to the tuning .
      Is the next dougy mod a external WG, or keeping it the way it is being that the creep is acceptable? I always find your threads/posts a great read!
      Jun 2011
      Congo
      thanks brotha....to me it is and initially I was , but since the creep is not more than the target boost I just said F-it since in the end power still would be the same , but really you should have control of your boost...for what it is, a simple cheap 600$ 20g turbo my R is a monster with it on considering it's running on stock motor and trans.
      and yes Hilton did a phenomenal job tuning it!
      1997 Toyota Avalon
      2000 Mercedes ML320
      2005 XCR90
      2006 C70
      Dec 2013
      Toronto
      So I thought I'd post up some early experiences with the current Hilton Tune. I've not gone for any power runs as I'm waiting on a fresh fill with 94, but it does run well so far. Also with the tune the idle limit has been bumped up to 750-800rpm which feels more stable and less vibration with the poly mounts.
      Sep 2010
      NY 10925
      so this 20g I have sitting in a box should work? Just would need to find the right exhaust housing for the Volvo manifold. It was set up for the t25 flanged audi manifold.
      2003 BTA4Avant
      IG: avantneil
      Dec 2013
      Toronto
      Anything is possible, but first I'd contact a tuner to see if they can tune that turbo with your setup, but I don't see the 20G posing a problem other then the one dougy has stated.
      Also I've posted some information on you question thread pertaining to you motor and possible other sites you can mine for information. Good luck with modifying your Volvo and keep us posted on your progress.
      Sep 2010
      NY 10925
      thanks I was just posting on my thread! LOL
      his 20g setup is NICE! More work than I'm willing to do right now. But was a good read, and he did some awesome work.
      Looking for bolt and go type mods for now. The Audi is PLENTY fast with its built motor and the big Comp Tubo on it.
      2003 BTA4Avant
      IG: avantneil
      Dec 2013
      Toronto
      Yay...
      So I've got my car at my trusty Volvo indie to get:
      - The steering rack replaced along with the lower steering U-joint (the U-joint is more of a why not)
      - Front and rear control arm bushing replaced
      - Spring seats replaced
      - IPD Sway bars installed along with IPD end links
      It's unfortunate that my steering rack needs to be replaced, it's the last thing I thought would go on this vehicle so soon. I wasn't leaking, the bushing on the PS side of the rack had worn and was causing a vibration.
      Normally I'd like to take a job like this on myself, but I cannot do this on jack stands at this time of year, and my mechanic friend with a hoist is swamped so I can't book the time with him.
      Angle gear is fine, oil had migrated from another location from the previous oil change.
      Oh well, at least while the subframe is down it's a great time to get the swaybars installed. Everything else looks in great shape, and the shocks are still working properly, so hopefully this is the last service I need to do that is suspension/steering related for some time.
      Junior Member Badger's Avatar
      May 2014
      Wisconsin
      Yay...
      It's unfortunate that my steering rack needs to be replaced, it's the last thing I thought would go on this vehicle so soon. I wasn't leaking, the bushing on the PS side of the rack had worn due to a tear in the boot that was letting in dirt and water. It started off as a slight knocking, then turned into a vibration. Can't believe I missed that...
      Seems like the steering rack is one of the first things to fail on high mileage XC70s. I had to replace mine on the 2001 when I had it. My dad's 04 needed a new one at 105K as well. Half the XC70s I looked at when I was car shopping last year had steering issues (although it's possible it was other things causing it too).
      Sep 2010
      NY 10925
      2003 BTA4Avant
      IG: avantneil
      Dec 2013
      Toronto
      Yes I do!!!
    37. #35
      Dec 2013
      Toronto
      Got the car back tonight and drove it around a bit. Wasn't able to get a real feel for the sway bars due to the slick roads (which was a lot of fun getting the tail out ), but it there is definitely less body roll and tighter steering, love to see how these handle on dry pavement.
      The steering rack was it!!! The knocking and vibrating i've been chasing around for some time has been eliminated, WOW! The new steering rack feels great, nice and tight, and with the addition of the sway bars very responsive.
      I've got to say thanks to Wayne at KWL automotive for doing an awesome job getting the job done right and on time! He said that this is the first time he has installed IPD swaybars and commented on the fact that the rear was a real pain, the front was made easy because the rack was being replace st the same time but looked to be easier then the rear regardless. He said it took him a bit more time then what was quoted on the IPD paper work and didn't charge me for it, but if he had to do it agian he knows his way around and can do it faster.
      Anyways, I still haven't had the time to get my Hilton Tune dialed-in, work/life thing. Will update on more on the tune and on the swaybars once I get more time...
