Hey Guys,
Not much of an introduction, but I'm Anthony and this is my XC70 build thread. Purchased in December 2012 with only 61k mi, now at October 2019 it's just over 145k mi and still going strong. Just pretty much doing my own thing and having fun with it as I go along. I've recently updated this thread with links to modification, trips, and repairs, but feel free to message me with any questions.
Enjoy!
Engine/Transmission Performance Upgrades:
Suspension/Drivetrain:
XC90 spindle/w hub & ball joints
XC90 2.5t front left/right axles
Utility:
Trips/Adventures:
Major Repairs:
01-28-2015 - Steering Rack/Bushings/Spring Seats/IPD Swaybar Install
12-13-2015 - Haldex pump replaced/fluid service
01-20-2016 - Valvebody replaced
04-24-2016 - Angle gear seals/collar sleeve
03-26-2017 - Exhaust manifold gasket/Turbo turbine housing replacement
08-15-2018 - Throttle body failure
01-26-2019 - Bent rear toe arm and wheel
04-02-2020 - Upper Engine Wiring Harness
Enjoy!
- Hilton Tuning Stage 3
- TD04HL-16T (Modified): 11 blade GTX compressor wheel, 11 blade turbine, 7cm^2 turbine housing, 0.3 BAR Wastegate Actuator.
- RaceS60R 3" down pipe w/catalysts
- Eurosport Tuning Touring Exhaust
- Do88 Intercooler
- AEM Progressive WMI System
- Volvo R model airbox w/MAF
- IPD Turbo Inlet Hose
- IPD Charge Air Pipe
- IPD Throttle Inlet Tube
- GFB Diverter Valve
- Snabb Throttle Body and Manifold Spacer
- Hayden Transmission Cooler w/ thermostat and inline filter
- Oil catch can
- Custom dual gauge mount w/ IPD Boost & Innovate AFR.
- Nivomat Rear Suspension
- XC90 V8 Front Springs
- Custom 19mm rear strut mount spacers
- Custom 16mm front/rear subframe spacers
- XC90 336mm front & 308mm rear brakes
- XC90 Lower Front End Conversion:
- XC90 17" Neptune Wheels.
- XC90 235/65R17 wheel well modification
- Toyo Open Country AT2
- H&R XC90 25mm wheel spacers (rear axle)
- XC90 V8 Gen3 (2008) Haldex DEM
- IPD XC70 Sway Bars
- IPD Subframe Inserts
- IPD Skid plate
Utility:
- Yakima Load Warrior w/double extension, 4x cross bars, custom flush mount, tire carrier, load stops, quick fists.
- Volvo 2" tow bar
- LED Conversion resistor banks
- H8 Battery Upgrade
- Auxiliary Third Row Seats
Trips/Adventures:
- May/June 2015 Crosscountry Road Trip 10,500km Yellowstone/Cascades/British Columbia
- August 2015 Haliburton Highlands
- May 2016 Catskills Camping
- May 2017 Bald Eagle State Forest/Volvos At Carlisle
- June 2017 Kawartha Highlands
- July 2017 Crosscountry Road Trip 8,800km Minnesota/Saskatchewan/Alberta/British Columbia/Lake Superior
- August 2017 Haliburton Highlands
- August 2017 Kawartha Highlands
- January 2018 Oompah Winter Cabin
- May 2018 Volvos at Carlisle
- June 2018 Rockwood Conservation Area
- June 2018 Halliburton Highlands
- July 2018 Pinery Provincial Park
- July 2018 Crotch Lake
- August 2018 East Coast Road Trip 4,400km Quebec/New Brunswick/Nova Scotia
- October 2018 Guelph Lake Reservoir
- May 2019 Longpoint Provincial Park
- May 2019 Haliburton Highlands
- June 2019 Rockwood Conservation Area
- August 2019 Crosscountry Road Trip 9600km South Dakota/Wyoming/Montana/British Columbia/Alberta/Lake Superior/Lake Huron
Major Repairs:
