Antherzoll's 05XC70 Build Thread - Page 28
    Page 28 of 29 FirstFirst ... 18 24 25 26 27 28 29 LastLast
    Results 946 to 980 of 986
    1. #946
      Member Exocet's Avatar
      Southern Tier NY
      Stick with the Neptunes, man. SO much better, IMO.
      I concur.
      2007 Volvo V70 2.5T - Mine
      2008 Nissan Titan SE 4x4, Crew Cab, Long Bed - Also Mine
      2012 Toyota Camry LE, 2.4 - Wife's
      2003 Mazda Protege5, 2.0 - Daughter #1
      2010 Mazda 6 Grand Touring, 2.5 - Daughter #2
      Neptune’s all the way.
      2003 V70 T5 - Mystic/Graphite - M56LK - 202k - K24/Greens/Do88 IC/SMF & P2R Clutch/DW300C/H&R/Bilstein TC/Delrin/316mm & 308mm Brakes - SteveO Tuned
      1999 V70 T5 - Pewter/R Graphite & Alcantara - AW42 - 295k - Daily/Work Wagon
      2000 V70 T5 - Mystic/Graphite - AW42 - 240k - Moms Unicorn
      2000 S70 GLT SE- Mystic/Graphite - AW42 - 215k - Sisters
    4. #948
      Oct 2014
      Boston
      Erinys FTW, 'cause tire's wall is higher
      Member Antherzoll's Avatar
      Dec 2013
      Toronto
      Yeah, Neptunes are pretty awesome, it's just that there's a decent set of Aquarius for $250cad that was taunting me.
    7. #950
      Dec 2013
      Toronto
      Quote Originally Posted by vtl View Post
      Ha, but my brakes are too big and the centre bore doesn't match it anymore... if I were to go to 16s I would need to reduce the 316mm rotors and 16 in XC90 like these.
      And yes, more sidewall is better, and going to a 16 in wheel with a 29 inch tire has a lot more exciting options.
    8. #951
      Apr 2013
      Toronto, Canada
      My vote is Aquarius.
      2002 V70XC, 2003 V40, 2004 S60, 2010 V70
      2010 V70 3.2 125,000miles
      2002 V70XC, 175,000 miles
      2004 S60 2.5T, 160,000 miles
    9. #952
      Dec 2013
      Toronto
      Quote Originally Posted by bigtimemcalpine View Post
      Maybe painted bronze?
    10. #953
      Apr 2013
      Toronto, Canada
      Quote Originally Posted by Antherzoll View Post
      Well they would certainly be unique.
      Was that you headed down Ellis Drive this morning? You don’t have a Thule wind fairing, do you?
    11. #954
      Dec 2013
      Toronto
      No, car has been parked for nearly two weeks. I should take it out for a run tomorrow.
    12. #955
      Dec 2013
      Toronto
      Killing some time. Updated the introduction post of this build thread with links to modifications, trips, and major repairs. Check it out if interested.
      https://forums.swedespeed.com/showth...96#post2285396
      Cheers
    13. #956
      Dec 2013
      Toronto
      Mounted!
      235/65R17
      Toyo Open Country ATII
      Just drove it back from the shop. They look and feel great. Getting a bit more rubbing upfront due to the fresh treads, but should be a simple fix.
    14. #957
      Member MN-TURBOR's Avatar
      Jun 2011
      Twin Cities, MN
      Mounted!
      235/65R17
      Just drove it back from the shop. The look and feel great. Getting a but more rubbing upfront due to the fresh treads, but should be a simple fix.
      beefy!
      2007 S60R - Ti Grey/Atacama M66 - Stage II Shark Tune - 8EightFab downpipe - Custom Magnaflow Exhaust - SNABB FMIC/Intake Pipe - TWM Short Shifter - Forge CBV - UR Front Brace/Rear Brace - IPD 28mm Rear Sway Bar - BC Racing Coilovers
      2007 XC90 V8 Sport - Electric Silver - Muffler/Resonator Delete
      2007 XC70 - Ice White - Stage I Shark Tune - Muffler Delete
    15. #958
      Dec 2013
      Toronto
      We have contact.
      The new tires are a real head-turner... . rrrrrrRRRRRRRrrrrrrrrRRRRRRR.
      In a straight line they clear, but any turning past 3/4 to lock will rub like mad, so I got to work. With a bit of heat gun treatment, some trimming, and strategic placement of rivets was able to get it to clear.
      Still a bit of rubbing at full lock, but that was there with the previous set and is easily avoided. Even though these tires are the same 235/65R17 the previous set, they are slightly larger. They look bigger in the wheel wells too. The rears still clear, though I've not tested the full range yet.
      Kumhos
      Toyos
      Should be getting some snow and freezing conditions over the next few days, interested to see how they handle.
    16. #959
      Dec 2013
      Toronto
    17. #960
      Well there's you're problem.
      Split the sleeve on the bushing. Will just ignore that.
      Bent this washer. Hammered it back flat.
      Twisted metal
      Back on the road.
      Sent from my ZTE B2017G using Tapatalk
      Is removing that arm and replacing it as easy as jacking it up and unbolting it and screwing the new one in?
    18. #961
      Dec 2013
      Toronto
      Yes, but rusted fasteners can be an issue, and I'd recommend an alignment afterwards, but if you place the bolt in the same orientation as it was removed it should be the same.
    19. #962
      Apr 2013
      Toronto, Canada
      Quote Originally Posted by TheHoovedPilot View Post
      I believe that member has a camber bolt on the inside end for alignment. Do your best to mark position of offset bolt but you will likely need an alignment after you have replaced.
    20. #963
      Dec 2013
      Toronto
      These tires are fat! Comparing them to both the old set and a goodyear I'm using as full size spare these are very large for the same size. Getting some rubbing with the rear end this low. I could fix it, but got no time for that now. Reducing the wheel spacers from 25mm to 20mm would help, but that would involve a new set of though bolt spacers and longer bolts which I'm not excited about...
    21. #964
      Oct 2014
      Boston
      Btw, why did you add spacers? Just for appearance?
    22. #965
      Dec 2013
      Toronto
      Appearance and balance. The XC90 front suspension spaced out the front axle by 72mm, adding 50mm to the rear maintains a less extreme track stagger and wider is better.
    23. #966
      Dec 2013
      Toronto
      Snow Fun!
      The Toyo Open Country ATII feel very passable for winter driving. Was able to get a feel for them in a wintery mix ranging from freezing rain to fresh powder, snow covered back roads and unmaintained access road. They feel very confident and maintain predictable handling on road and are able to push through and climb hills easily off road. Temperatures were keeping between 0C to -4C, will be interesting to see how the rubber harden at colder temp and how they perform on ice. For now I'm very impressed by them.
    24. #967
      God I just love your XC... As much as I really wanted to get my 2002 XC modified like yours, I've decided to sell mine. I'm in a bad living situation and plan to use the money from it to get out of it. I'm going to miss her.
      2002 Volvo V70XC * Stage 2 Hilton Racing Tune * Custom Exhaust * Custom bi-xenon projector headlights (pampered)
      1997 Acura SLX 4wd - 2" lift - Locker - bi-xenon HID headlights - Cerwin Vega speakers (daily driver)
    25. #968
      Dec 2013
      Toronto
      Damn, sorry to hear that. Hopefully the money will be useful in bettering your situation.
    26. #969
      Mar 2019
      How’s the tune these days? Did you ever change the injectors or is it still stock injectors? And do you know what your boost pressure is with the tune?
    27. #970
      Dec 2013
      Toronto
      Still runs great. Going it perform a compression test in the spring along with new plugs to see how things are wearing. Currently running blue injectors, boosts to 16psi and I get it up there as often as I can.
    28. #971
      Dec 2013
      Toronto
      So, how worthwhile is a R head swap? Thinking I may get one to rebuild and swap as a project to stave off boredom...
    29. #972
      Dec 2013
      Toronto
      No one? Cool. If I find one cheap I may dig into it.
    30. #973
      Member LloydDobler's Avatar
      Aug 2007
      Littleton, CO
      Technically I think the R head flows better but the reality is a good tune and turbo with supporting intake and exhaust is all you need. I easily outrun a stock R in my 2.3 C70 and keep up just fine with modded ones.
      2003 C70 T5M Convertible - Eibachs, Koni FSDs, Enkei RSF5s, OBX downpipe, Snabb intake, RIP kit, & drop-in intercooler, Quaife LSD, 19T, Green Giants, 22 psi Hilton tune.
      2006 V70 2.5T - Ice White - Oak Arena, (almost) bone stock daily driver.
      1966 122s - Collectible project, restoration and many mods on the way.
      2005 V50 T5 AWD - Daughter's first car. No mods unless she does 'em herself.
    31. #974
      Senior Member JaredR's Avatar
      Jan 2014
      Boston, MA
      Quote Originally Posted by LloydDobler View Post
      Being FWD helps you a lot there.
      1995 850 T-5R Estate. AW50-42LE. Cream Yellow/Graphite. 296k.
      1997 850R Estate. RN/M66D. Bright Red/Graphite. 270k.
      2007 S60 T5. M66W. Black Sapphire/Arena. 138k.
      Dad: 1997 V70 T5 SE. AW50-42LE. Frost Green/Oak. 212k.Mom: NEW! 1999 S70 GLT Pewter/Oak. 100k. Past: 2004 V70 NA. AW55-50SN Ruby Red/Tan 269k. Sold to markj
    32. #975
      Very. Thats an easy 25 HP. Except its not added to the top its added to the whole curve. Free flowing head makes the turbo work less, creates less heat ect. I actually drove hounddoggers lava xc when it had an R head on it and it scooted good.
    33. #976
      Aug 2005
      Northern MD
      Get out.
      We’ll help find you another cool one.
      Quote Originally Posted by roxanaschram View Post
    34. #977
      Apr 2015
      Pittsburgh, PA
      Get out.
      Yeah, seriously, we're finding them all the time. We can find another when the time comes.
      roxanaschram - Have you been able to improve your living situation?
      2006 & 2007 XC70
      Previous: 2006 S60R, 1999 F250 Powerstroke, 2005 TSX, 1997 Bonneville, 1998 Concorde
    35. #978
      Aug 2007
      Littleton, CO
      Being a C70 vert is a massive hindrance. It's a solid 3750 lb on the scale.
    36. #979
      Yea you don’t get the fwd diet on those.
    37. #980
      Dec 2013
      Toronto
      Noticed some paint chips on the XC that I'd like to touch up. Not too concerned with a 10/10 job, mostly want to protect the body, but of course I'll try to get the best results possible. Anyone have experience with the Genuine kit? Is this the kit to get? Experiences?
      Thanks.
      https://www.volvooftorontoparts.ca/p.../31266536.html
