Antherzoll's 05XC70 Build Thread - Page 21
    Page 21 of 30 FirstFirst ... 11 17 18 19 20 21 22 23 24 25 ... LastLast
    Results 701 to 735 of 1024
    1. #701
      Member Antherzoll's Avatar
      Dec 2013
      Toronto
      Not so concerned about a fire. While they get hot, they'd need to be somewhere in the 400*C-500*C range before they could ignite anything, noticing surface temperatures of 90*C-100*C so far on the 6ohm resistors, but I'll continue to keep an eye on them. I'm more concerned with melting anything plastic near by. Of course, this is a bandaid solution. I would like to modify the CEM/REM in a way to eliminate the warnings, but I'm unsure of a solution for a 2005 and I haven't had the time to look into it myself
      Sent from my ZTE B2017G using Tapatalk
      Dec 2013
      Toronto
      Some resistor temperatures. Temperatures taken with hood/panel closed with enough time to reach max values, 4ways on, brakes held, and the engine running to maintain 13.8V. Readings taken with a Fluke 325 Type K probe.
      Outside Temperature - 2C
      Front -
      6ohm (outter) low beam - 136C
      8ohm (inner) signal - 131C
      Plate - 110C
      Ambient - 31C
      Rear
      8ohm signal - 85C
      8ohm brake - 100C
      Plate - 75C
      Ambient - 39C
      They are running hot, but are still what I consider safe and acceptable, just as long at you don't touch the . Outside temps are low so I'll measure them again once it warms up.
      BTW.
      Happy New Year
    4. #703
      Junior Member Deva's Avatar
      Nov 2016
      San Bernardino, CA
      You can put a heatsink on it... Something something welder.
      Sent from my LG-H918 using Tapatalk
      Dec 2013
      Toronto
      The resistors are mounted inside an aluminum heat sink and I mounted them to the plates with thermal paste to aid with heat dissipation, which seems to be working well. A larger heat sink would make for a bulkier install, it would be much easier to split the load by wiring two lower value resistors in series, or two higher value resistors in parallel.
    7. #705
      that's well within the normal operating temp for a resistor that size.
      as long as it's not melting anything nearby I'd run it. They're wire wound yes? mostly you can run a wirewound resistor to 250 before issues.
    8. #706
      Dec 2013
      Toronto
      Score!
      Kids should be happy
    9. #707
      Dec 2013
      Toronto
      How to remove a steering wheel at the junkyard in three steps.
      Dang, the column is locked. Can't access the screws, and it's freezing...
      Step 1
      Step 2
      Step 3
    10. #708
      Member skywolf's Avatar
      Sep 2012
      Marietta, GA
      Man - ain't nobody got time for screws and freezing temperatures!
      2006 XC70 75k - Ruby Red/Graphite - "Wichita" | 2011 Tacoma 14k - Green/Sand - "Timber"
      2007 XC70 64k - Black Stone/Graphite - "Springfield" | 2017 Miata RF GT 5k - Grey/Black
      2020 V90CC 50 - Osmium Gray/Maroon Brown
      Previous: 1997 Dodge Intrepid | 2002 Saturn | 2009 Jetta | 2011 Mazda3 | 2011 Outback | 1993 Miata | 2013 XC70 | 2005 XC70 | 2005 V70 | 2007 XC70 | 2010 Odyssey | 2006 V70R | 1990 740 | 2019 XC90 | 2019 BMW 440i | 2018 V90CC
    11. #709
      Quote Originally Posted by Antherzoll View Post
      Step 1
      Step 2
      Step 3
      Dang. I want that center console!
    12. #710
      Member Exocet's Avatar
      Southern Tier NY
      That's frustrating. Or, one of the airbag clips will pop, but the other one doesn't.
      2007 Volvo V70 2.5T - Mine
      2008 Nissan Titan SE 4x4, Crew Cab, Long Bed - Also Mine
      2012 Toyota Camry LE, 2.4 - Wife's
      2003 Mazda Protege5, 2.0 - Daughter #1
      2010 Mazda 6 Grand Touring, 2.5 - Daughter #2
    13. #711
      Dec 2013
      Toronto
      Quote Originally Posted by Exocet View Post
      Yes, but much quicker
    14. #712
      Southern Tier NY
      If you come across any black mesh shifter trim in your JY travels, let me know.
      Sent from my SM-G950U using Tapatalk
    15. #713
      Dec 2013
      Toronto
      Will do.
    16. #714
      Dec 2009
      Rustburg VA
      Sent from my SM-G955U using Tapatalk
      Questions about rear differentials repairs? Email me here - [email protected]
      Owner of the only P3 V70 T6 in North America
    17. #715
      Dec 2013
      Toronto
      Quote Originally Posted by ProlixArgon View Post
      _Claim The Status_
    18. #716
      Jul 2013
      Dover, NH
      He shoots, he scores!
      2007 V70R GT Electric Silver/Nordkap
      2005 XC70 It's got HIDs yo.
      2006 S60R Black Sapphire M66 - Resurrected from the dead and sold
    19. #717
      Nov 2016
      San Bernardino, CA
      So i wanted to get your input on the subframe lift.
      Adding an inch, would you think C70/P80 120mm bolts would do?
      M14X120?
      And what size bolts are you using for your strut spacer?
    20. #718
      Dec 2013
      Toronto
      Quote Originally Posted by Deva View Post
      M14X120?
      They are class 8.8 bolts that are blackened. If Volvo supplies the size you need from another application then go ahead and use it, otherwise a bolt supplier should have what you need.
      Unsure what sizes I'll need for the spacers, but whatever I chose will equal the original length + spacer height.
    21. #719
      Dec 2012
      E. ON
      Respect. Git'er done! Especially in an ON JY in January...
      Any chance the donor was a black or silver 05 or 06?
      2001 V70 T5M
      2010 XC70 T6
    22. #720
      Dec 2013
      Toronto
      Pick-n-Save Welland. I think it was a dark blue, not black.
    23. #721
      Dec 2013
      Toronto
      Booooo
    24. #722
      Senior Member JaredR's Avatar
      Jan 2014
      Boston, MA
      Did you crash?
      1995 850 T-5R Estate. AW50-42LE. Cream Yellow/Graphite. 297k.
      1997 850R Estate. B5234T9/M66D. Bright Red/Graphite. 270k.
      2007 S60 T5. M66W. Black Sapphire/Arena. 140k.
      Instagram: Jared's Volvo Page
      Dad: 1997 V70 T5 SE. AW50-42LE. Frost Green/Oak. 212k.Mom: NEW! 1999 S70 GLT Pewter/Oak. 101k. Past: 2004 V70 NA. AW55-50SN Ruby Red/Tan 269k. Sold to markj
    25. #723
      Dec 2013
      Toronto
      Nah, just stupidity. Went a little hard parallel parking. Hit a high curb that I couldn't see under the snow and that I thought was a bit further back. Hoping is just the wheel and toe arm as I can find both quite easily.
    26. #724
      Dec 2013
      Toronto
      AWS System
    27. #725
      Jan 2014
      Boston, MA
      Handbrake turn into the parking spot? Lol
    28. #726
      Aug 2005
      Northern MD
      Doesn’t LOOK like a prelude....
      AWS System
    29. #727
      Dec 2013
      Toronto
      $70CAD. Hopefully getting it in this afternoon. Hopefully it's the only thing damaged beside the wheel.
    30. #728
      Member 95WanderWagen's Avatar
      Aug 2016
      Berks Co., PA
      Do I forsee more poly in your future?
      Help fund a trip across the country for a volunteer position working with rescued wolves and wolfdogs!
      https://www.gofundme.com/Ptsd-therap..._co_campmgmt_m
      Want brighter, whiter interior lights in your Volvo? PM me for details or email me at [email protected]. Full kits in stock for p80 platform cars
      Ghosts of the past
      3x AMC XJ (84 Cherokee 2.5l, 86 wagoneer 2.8l, 87 Cherokee sport 2.8l 5 sp) || 4x Subaru (96 legacy outback, 97 legacy gt wagon, 92 svx 4.44 auto swap, 88 DL coupe) || 2x Pontiac (88 Fiero 2.5l notchie, 96 grand Prix GT 2.4L) || 3x DSM (92 eclipse GS 4g63 n/a, 99 eclipse gs 420a n/a, 3000gt vr4 sport roof) || 2x Hyunda (96 Elantra 4g63 coupe, 2000 Elantra 4g63 wagon) || 1x Geo storm || 1x VW [93 Fox) || 1x Ford(93 Escort LX 1.9l) || 1x Chevy(2000 venture extended) || 3x Volvo (96 855 2.4l, 95 855 2.3t, 04 xc70 2.5t) || 1x Mazda (2003 Protege5 5sp)
    31. #729
      Dec 2013
      Toronto
      Quote Originally Posted by 95WanderWagen View Post
      Nope. Must have the wrong number
    32. #730
      Dec 2013
      Toronto
      Well there's you're problem.
      Split the sleeve on the bushing. Will just ignore that.
      Bent this washer. Hammered it back flat.
      Twisted metal
      Back on the road.
    33. #731
      Junior Member Amneme1's Avatar
      Aug 2013
      Grosse Pointe Farms Mi
      Guess what I saw today? FB page devoted to lifted XCs. Grafting an XC90 subframes to an XC70
    34. #732
      Nov 2016
      San Bernardino, CA
      Quote Originally Posted by Amneme1 View Post
      Really? What page or FB group? European Volvo group?
    35. #733
      Dec 2013
      Toronto
      That's pretty cool. I'd love to have the space/time to play with mods like that. From what I know, the XC90 subframe mounts are higher relative to the subframe vs the XC70, this will drop subframe lower when mounted similar what subframe spacers are trying to accomplish. Hopefully it all works out. If I went through the trouble of this I'd try to swap in a V8 .
    36. #734
      Aug 2013
      It’s called lifted Volvo’s. I like the subframe idea but if I was to get one from a pick n pull, how would I pull this without the engine and trans? An overall great solution. I would get the rear with haldex and all the trimmings too.
    37. #735
      Jan 2014
      Boston, MA
      You use an engine support bar. Then just drop the engine and trans on the ground when you are done lol. Preferably you would attempt this at a yard that already has the cars up off the ground.
