Antherzoll's 05XC70 Build Thread - Page 9
    Page 9 of 30 FirstFirst ... 5 6 7 8 9 10 11 12 13 19 ... LastLast
    Results 281 to 315 of 1024
    1. #281
      Member Antherzoll's Avatar
      Dec 2013
      Toronto
      MOOG K80501 (front)
      MOOG K80425 (rear)
      Dec 2013
      Toronto
      Replaced the fronts tonight, here's the comparison
      12.7mm vs 10.1mm
      Only replaced the fronts tonight. Upon removal of the old endlinks I noticed the swaybar bushings had a bit of slop, they were tight when I lubed them a week ago. I was able to tighten them up by inserting a shim between the subframe and the bushing and now they grasp the bar firmly. No more clunks, she's all quiet. I'll be ordering a set of replacement bushing, front and rear, to have on hand, but for now I feel this is ok.
      Spent the rest of the time working on the rear wheel wells to provide clearance for my winter/trail tires. I've placed an order for Kumho Road Venture AT51 in 235/65R17 (stock XC90 size) which should be arriving tomorrow. I've been using a used set of XC90 tires to check clearance and I feel like I will have enough. More information here:
      https://forums.swedespeed.com/showthr...t-Tire-Options
    4. #283
      Jul 2013
      Dover, NH
      Quote Originally Posted by Antherzoll View Post
      MOOG K80501 (front)
      MOOG K80425 (rear)
      Thanks! I looked them up on Rock Auto and some of the pics were different than the one's you got. The zerks were also not installed on the part in the pics. After searching the part numbers elsewhere they all had those same pics. Weird. I'll probably get these when my IPDs eventually crap out.
      2007 V70R GT Electric Silver/Nordkap
      2005 XC70 It's got HIDs yo.
      2006 S60R Black Sapphire M66 - Resurrected from the dead and sold
      Dec 2013
      Toronto
      Trying out my hiking boots!
    7. #285
      Just discovered this build. Looking forward to reading through it and also seeing any new updates. Thumbs up so far!
      2011 S60 T6 with Polestar tune+TDI-Tuning : KW V3 coilovers : DO88 fmic : Ferrita downpipe : Powerflex "race" torque mount insert
      12.99 at 109mph
    8. #286
      Aug 2015
      Hudson Valley, NY
      Quote Originally Posted by Bunnspeed View Post
      You picked a good one. Easily one of the best things going in P2 wagon world.
      2004 XC70 2.5T AWD | 149K | Bad Swede 52mm Lift Kit | Sparco Terras BFG KO2s in 225/70r16 | IPD Strut Brace Conversion | IPD Skid Plate | IPD DEM Cover | AEM Dryflow Air Intake 2015 V60 R-Design | Sapphire Black Metallic | 44K | KPAX GT Performance Exhaust | IPD Rear Sway Bar | Powerflex Race Torque Mount Inserts
    9. #287
      Dec 2013
      Toronto
      Progress! 😀
      Reused the IPD TCV as a failsafe.
      If active, it will bypass the primary TCV straight to wastegate which will only allow the turbo to build base pressure of 4.5psi.
      I messed up with tap and sensor locations on the reservoir and now it's swiss cheese. Instead of patching it I have ordered a new one which will arrive next week. I'll be able to complete the install then.
      Sent from my LG-H815 using Tapatalk
    10. #288
      Member Hounddogger's Avatar
      Oct 2014
      Northern Hemisphere
      I hope the methanol doesn't penetrate the firewall... It's just not smart. As for the end links-- A= (pi*d^4)/4 so increasing d to 12.7mm vs 10.1mm is a 40% increase in area pretty decent.
      Exponents kill
      Elsa: 2004 V70R Silver Metallic&Nordkap Back from Valhalla @ 357,098 miles
    11. #289
      Dec 2013
      Toronto
      Are you saying that I'm not smart 😉
      All methanol plumbing is confined to the engine bay, the hose on the controller is for boost signal. I'm only running 50/50 or less so it won't be a fire hazard.
    12. #290
      Dec 2013
      Toronto
      And complete!
      https://youtu.be/BNOq7ZWhRxY
      For now I'll be operating the system passively.
    13. #291
      Dec 2013
      Toronto
      Got one for cheap so why not.
      Sent from my Nexus 5 using Tapatalk
    14. #292
      Aug 2015
      Hudson Valley, NY
      Awesome. Breathing that raRified air now.
    15. #293
      Dec 2013
      Toronto
      Hahaha, Yes.
      I honestly don't expect much of a difference between the R box and the AEM Cone filter, but the larger R MAF may increase air flow at the top end. I do like how the R box looks stock compared to the cone filter which screams "modified".
      👍 To Hilton Tuning for provided a new tune for the R MAF.
      After a quick flash she's running beautifully.
      (yes my car is filthy)
    16. #294
      Aug 2005
      Northern MD
      Cool progression, antherzoll. Need more videos of the top end now. 60-90?
    17. #295
      Aug 2005
      Northern MD
      With bigger teeth or just xc90 wheels? They look great on there. Any rings needed? The green looks so silver like!
    18. #296
      Dec 2013
      Toronto
      Stock XC90 size, 235/65R17 AT winter rated tires. The bigger tires lift the XC by 1".
      Yes, hub rings are required as the XC90 wheels are 67.1mm compared to 65.1mm
      Crystal Green only looks green in winter scenes or when parked next to a true silver car. I like how subtle it is.
    19. #297
      Aug 2015
      Hudson Valley, NY
      Feel bad for that poor sucker getting your old intake.
    20. #298
      Dec 2013
      Toronto
    21. #299
      Dec 2013
      Toronto
      Here's a sneak peek.
      Flat BBQ Paint
    22. #300
      Junior Member A4Avant's Avatar
      Sep 2010
      NY 10925
      I love catching up reading thru your thread!
      Sent from my SM-G900V using Tapatalk
      2002 V70 T5 .....looking for Gobi R seats (F), H&R Lowering Springs
      2003 BTA4Avant
      ..... Built Motor, Comp Turbo CT5147
      IG: avantneil
    23. #301
      Flat BBQ Paint
      +25KW
    24. #302
      Dec 2013
      Toronto
    25. #303
      Aug 2015
      Hudson Valley, NY
      Yeaaaaaaahhhhh boi. Wagon looks mean!
    26. #304
      Dec 2013
      Toronto
      IPD HD Control Arms and swaybar bushing replacement
      That should help tighten things up a little bit.
    27. #305
      Aug 2015
      Hudson Valley, NY
      HDDDDDDDDDD!!!!!!!
      Wishing you many many miles of Heavy Duty, High Definition travels
    28. #306
      Jan 2017
      Love seeing the progress over time. I have a quick question for you. I am in the process of upgrading my V70, and I would like to upgrade to 12" front rotors. I have searched without much success, so I was hoping you could fill me in on exactly what is needed. I think it's just rotors and caliper mounts, right? Do you happen to know the part number of the brackets? Thanks!
    29. #307
      Dec 2013
      Toronto
      Quote Originally Posted by hootie6828 View Post
      Here you go!
      http://www.volvoxc.com/forums/showth...t-front-rotors
      Check Rockauto, they tend to carry the caliper carriers for cheap. Let me know if you need more information.
    30. #308
      Dec 2013
      Toronto
      Quote Originally Posted by Young Satchel View Post
      Ha, thanks. Apparently the rubber is made from virgins for better adhesion.
    31. #309
      Jan 2017
      Awesome, thanks a bunch. One more question for you. Was the stage 3 tune from Hilton your choice, or did Hilton require you to purchase a 3 based on your mods? Seems to me that your car is very similar to a stock T5 now, tune shouldn't really be that far off a T5 tune. Just curious, as I am considering going with Hilton, and I am wondering what my initial investment is going to be. I probably just need to reach out to Hilton myself, but I haven't gotten there yet. Thanks again.
    32. #310
      Dec 2013
      Toronto
      "Stage 3" was required due to the larger than stock upgraded 16T turbo with a heavier wastegate.
      Best to contact Hilton directly.
    33. #311
      Dec 2013
      Toronto
      I had myself a productive day.
      That's right kids. XC90 front and rear brakes.
      Rotors are Wagner Premium E-Coated, Pads are Pagid.
      The calipers were a generous donation from a friend and fellow SS member , they were well used and were in need of a spa treatment. Once fully disassembled and the pistons ejected they went for a nice vinegar/brine soak to melt the rust away.
      ... much better.
      Now some people at this point would decide on some radical colour to paint their fresh caliper for that ultimate effect behind the wheel. Me being me, I went with the best... Tremclad High Heat Enamel in Flat Black
      Also rebuilt the calipers with new boots, seals, pin guides, and hoses.
      Install was straight forward like any brake job with the exception of the larger caliper mounting bolts for the fronts, and the dust shield for the rears. To mount the front calipers to the spindle the bolt holes had to be enlarged enough for the M14 bolt. I used a 13.5mm or 17/32" drill bit then reamed out the hole to 14mm finish with an adjustable reamer.
      Bleed it.
      Slap the wheels on.
      ...and take it for a spin.
      Initial thoughts, they are not as grabby as the other brakes but there is a noticeable difference in brake force. I can also feel the additional weight of the calipers/rotors in the steering wheel.
      Cheers
    34. #312
      Dec 2009
      Rustburg VA
      Questions about rear differentials repairs? Email me here - [email protected]
      Owner of the only P3 V70 T6 in North America
    35. #313
      Jul 2013
      Dover, NH
      Fantastic!
    36. #314
      Aug 2005
      Northern MD
      Well done! Ale is deserved (with 'ass kicking' logo).
    37. #315
      Aug 2015
      Hudson Valley, NY
      Damn that looks so good! The payoff for months of hard work! Enjoy the increased stopping power; perhaps it will keep you out of trouble
