Khalil's build thread - Page 14
    Page 14 of 14 FirstFirst ... 4 10 11 12 13 14
    Results 456 to 485 of 485
    1. #456
      Member Austin V70R's Avatar
      Jan 2012
      Santa Cruz, Ca
      Surge tank is an awesome solution and perfect for the Red Devil, but itís an overkill for anything under 750 wheel HP. Itís nice because it includes the return regulator assembly, but its complicated and expensive.
      06 VR GT - daily driver ~18" TSW Nurburgring wheels ~Contrast Stage 4 ~Shimmed block ~EFR7163 turbo ~1050cc Injectors ~TorqByte PM3 fuel pump and CM5-LT W/M controllers ~track spec IPD Bars ~Ultra Racing front strut bar & VST rear strut bar ~SS brake lines~Innovate Boost & AFR fail safe
      Member khalil_y's Avatar
      Nov 2014
      Dearborn Heights, MI
      Quote Originally Posted by Red_Devil View Post
      Dude didn't you just have this all apart to fix a pressure issue? Sucks man I would say look at future power goal plans and make a decision on what way to go. I thought you could fit the big 450 or whatever they sell now without return but just have to mod the pump housing and upgrade wiring but Neal would know more than me.
      Nah, that was when I first went Stage 3 back in Summer 2017. Its been fine since, but I really beat down the car whenever I get the chance, its just so much fun to drive haha! My average PEM duty cycle was about 78% on E85. Not sure if thats bad or not, so thats why Im wondering if I should go with a bigger pump.
      Stage 3 Electric Silver 06 S60R 6SPD #TeamTF80, 12.6 1/4 @114mph. Build thread here
      Follow my obsession on Instagram: @kale_Salad_rz https://www.instagram.com/kale_salad_rz/
      Quote Originally Posted by rmorse View Post
      Quote Originally Posted by AthruC View Post
      It is flaccid in nature, and makes me uncomfortable to talk about.
      Ugh. Story of my life.
    4. #458
      Jan 2012
      Santa Cruz, Ca
      Quote Originally Posted by khalil_y View Post
      Throw a DW300 in it for now and budget $1K for a fuel system when you do the big turbo swap. No need to tune it twice.
      SwedeSpeed.com
      Nov 2014
      Quote Originally Posted by Austin V70R View Post
      Yeah that's the plan. Thanks for the help guys! I'll revisit this once I'm ready to go bigger.
      Sent from my HTC U12+ using Tapatalk
    7. #460
      Oct 2018
      Minsk, Belarus
      Did someone say surge tank? lol love mine not the wiring so much but she feeds the beast without issue.
      It is natural to redo the wiring for a new fuel system. With sharp starts and on the track, it will save the life of the motor.
      Volvo s60 2,5 AWD 2004, 1/4 mile 12,18 187 km / h
    8. #461
      Jan 2012
      Santa Cruz, Ca
      Quote Originally Posted by Laguna1 View Post
      True for a system consuming higher current. The DW300 consumes less current than Hua current syatem and heís already running Cu 10AWG from the battery to the PM3 and PM3 to the pump. The PM3 will power multiple pumps up to a 30A draw.
    9. #462
      Junior Member black944 turbo's Avatar
      Apr 2018
      Charlotte
      Has the metal on the oil plug ever come back? Did you come to the conclusion it was your turbo failing?
      2005 V70R M66, Titanium-Gobi
      1986 944 Turbo, Black-Tan
      Past; 940t wagon, 940, 960 wagon, 240 wagon and several others in the family.
    10. #463
      Nov 2014
      Quote Originally Posted by black944 turbo View Post
      Sorry for the late reply. But yes, it was most likely from the turbo as you mightve seen in my previous update regarding the turbo, the CHRA and shaft were completely melted away. Havent seen any metal powder at all since I replaced the turbo. The car still runs very strong, but im loosing coolant and having fueling issues and worried I mightve lifted the head on all the extra power im pushing. I'll be doing some tests on the engine and fuel system this weekend.
      If I did in fact lift the head, im hoping I didnt damage anything like the cyl walls or warped the head. Crossing my fingers it would just be an easy fix with some ARP studs and a new gasket after sending the head to a machine shop.
    11. #464
      Jan 2012
      Santa Cruz, Ca
      Quite possible with stock head bolts khalil, I wouldnít be surprised at all. TTY head bolts will give up and wonít come back by design.
    12. #465
      Nov 2014
      I'm not surprised. I even used new genuine ones on the rebuild. Guess we'll find out soon.
    13. #466
      Nov 2014
      Welp, here it is guys. 100% lifted the head. Going to start planning my next move once I take the head off and inspect everything. Hopefully the block and head arent trashed.
    14. #467
      Nov 2014
      I just want to mention some great people here that have helped me along this journey. Thanks to ElementR for advice and tools, AustinV70R for advice and staying up with me so late into the AM figuring out the fuel system and fixing issues, and Justin Tocsh (dont know your username on here) for giving me live advice on everything. I might've missed someone so I apologize.
      I love you all!
    15. #468
      Jan 2012
      Santa Cruz, Ca
      I love you all!
      My pleasure buddy. Remind me what youíre tuning for boost...
    16. #469
      Nov 2014
      It's only hitting about 23psi at about 3200rpm and tapers off to 20 after 6800.
    17. #470
      Member Red_Devil's Avatar
      Jun 2010
      Mass
      That sucks man build it stronger and better.
      2018 Leadfoot Ford Raptor semi built 600hp, 2020 Audi RS3.
      05 S60R MT, Stock block 578AWHP, 12.2 1/4 mile at 124 mph. Built 804 AWHP. Built engine, Cnc ported head, Front & Rear LSD, Ported Gen 2 T4 GTX3584RS hybrid, Turbosmart 45mm WG, Tial QR Bov, Enem Y21 Cams, Radium Surge tank, 1700cc Id's, Triple Walbro 485's, PM3, Devils Own meth injection, speed density converted mafless setup, Bell FMIC, Snabb air box, Poly, Milletech intake manifold, IP plasma coils, IP Plasma lift. Snabb shifter. TTV Twin Clutch. GB Forgestar F-14's, Enkei RSF5, KW V2'S, Ur Braces, Vr sways, IPD toe bars. Built to the hill.
    18. #471
      Member MN-TURBOR's Avatar
      Jun 2011
      Twin Cities, MN
      I love you all!
      Justin = DrBrutal
      2007 S60R - Ti Grey/Atacama M66 - Stage II Shark Tune - 8EightFab downpipe - Custom Magnaflow Exhaust - SNABB FMIC/Intake Pipe - TWM Short Shifter - Forge CBV - UR Front Brace/Rear Brace - IPD 28mm Rear Sway Bar - BC Racing Coilovers
      2007 XC90 V8 Sport - Electric Silver - Muffler/Resonator Delete
      2007 XC70 - Ice White - Stage I Shark Tune - Muffler Delete
    19. #472
      Jan 2012
      Santa Cruz, Ca
      It's only hitting about 23psi at about 3200rpm.
      All the discussion of bolts vs studs aside.... I donít think youíre lifting the head at 23psi. Youíve got something else going on.
    20. #473
      Nov 2011
      How was the head Machined? I recently saw something similar on a facebook post
    21. #474
      Nov 2014
      Quote Originally Posted by ImportService View Post
      I used the glass lathing method. Used 1/4 inch thick glass panel with multiple grits of sandpaper to ensure flatness. I put lines on the mating surface with a sharpie to see where it's being sanded down and stopped once the lines disappeared.
    22. #475
      Aug 2018
      Idaho
      Yeah, I am repeatedly hitting 23-24 with my hybrid on stock head bolts, I agree, something besides lifting the head from boost....
    23. #476
      Jan 2012
      Santa Cruz, Ca
      khalil - Iím afraid your going to find what will be characterized as a ďblown head gasketĒ but In reality is head flatness that has now compromised deck flatness due to forcing coolant between cylinders. I hope Iím wrong.
      I recall you had a tough time finding a machine shop when you had it apart, but thatís the only way to ensure flatness.
      If that is the case find a new head, find a good shop to surface it and go from there. Of course use a Volvo MLS gasket also.
      Old school methods worked fine for naturally aspirated engines, but any boosted or high compression engine requires two flat and parallel (where the glass method doesnít work) surfaces to seal a gasket.
    24. #477
      Nov 2014
      You bring up good points. Never thought about it that way with the glass surface method. We'll find out soon. I took most of the cables and connections off today and will do more tomorrow. I'll have the head off by next weekend or the following weekend. Really hoping the block isn't trashed. If it is, I'll be in the market for a 4T5 block.
      BTW, I bought a 118K mile TF80 for $50 from a friend's R part out. Going to take it apart and clean it up and have the valve body rebuilt. Any suggestions for upgrades I can do with this trans? You did almost everything possible on a TF80.
    25. #478
      Jan 2012
      Santa Cruz, Ca
      Just do a new filter and transgo VB Kit. Thatís all they need. Volvo steels and plates are better than aftermarket and I found them all to be in thickness spec on the two I rebuilt. They donít die from wear, they die from VB issue.
    26. #479
      Nov 2014
      I'm wondering if mine just needs a valve body. Its 100% slipping now on 1-2-3-4 shifts at WOT.
      Is the filter behind the VB?
    27. #480
      Jan 2012
      Santa Cruz, Ca
      Itís in the case. Ensure you have proper fluid level when you put the trans back in 1/2 quart after VIDA says its full and the plug is in, and ONLY use Mobile 3309 fluid. Anything else will make it slip.
    28. #481
      Nov 2014
      I've been using Valvoline MaxLife. I'll switch to that one next.
      If the engine block is safe to reuse, I'll just leave this trans in and have the valve body rebuilt or replaced and change the filter then try again with the currently installed one. Well see how it goes. I need to get an auxiliary cooler on it too.
    29. #482
      Jan 2012
      Santa Cruz, Ca
      You have to split the trans cases to change the filter. Iíd recommend refreshing the other trans and doing a swap. Donít add additives whatever you do.
    30. #483
      Nov 2014
      Got it. Thanks Neal!
    31. #484
      Sep 2020
      The silver color is bright and fresh
    32. #485
      Nov 2014
      Quote Originally Posted by lyuluck View Post
      Thanks man! I love this silver and how it changes color depending on the lighting.
    33. Remove Advertisements
