thefisch33's progression thread ODIN II
    Page 1 of 3 1 2 3 LastLast
    Results 1 to 35 of 82
      Member thefisch33's Avatar
      Mar 2011
      CASTLE ROCK, COLORADO
      from Nov '13 at the dealership. Was a lease, 57k on the odo. Took forever to find a m66 AWD.
      first up was the badgeless grill from dubstop
      next up pedals from autovation
      6k leds from vled everywhere except turn signals and brake lights
      had to bring back the moose and yellow calipers
      injen intake and yellow covers
      and most recently the custom cat back muffler delete
      short term goals:
      shift knob, weighted from TWM or the Heico one...tough choice
      strut tower brace from Viva
      brakes are still original, need to get some slotted rotors and new pads
      dual port CBV, and HD TCV
      long term goals:
      coilovers. want to invest in the KW's but just saw the ISC ones...
      tune, still haven't fully decided the vendor..
      BBK, 18's Pegs,
      v50 bumper swap (eventually)
      and the rest of the engine goodies
      that ought to do it.
      2010 s40 T5 AWD M66 a tribute to Heico's ODIN HS4
      Global Moderator MyNameIdeasWereTaken's Avatar
      Jan 2010
      Dahlonega, GA
      Looks good! I'm still trying to decided on my new engine bay color theme. Definitely blue... But there are so many different blues to choose from.
      Mar 2011
      I'm trying to find a yellow cone filter or something equivalent to match. Yellow vacuum lines too I just need to get the correct sizes
      SwedeSpeed.com
      Mar 2011
      Following up on progress. The TWM heavy weight knob is in. And I got slotted rotors and 17" Pegs. Yes, as seen in this pic they were drilled and slotted but they ended up warping, so the manufacturer replaced them an my request with slotted.
    7. #5
      Mar 2011
      It's now time for a new windshield, the top seal is leaking. A trailer hitch(I'm guessing) smashed my dubstop grill today. And the past year in Wyoming has not been nice to the paint. Also caught a shopping cart to the rear left quarter panel. That will require body work and paint.
    8. #6
      Mar 2011
      No mods for a while, have to replace the front CV axels...$1,800 job at least at the dealer. Lifetime warranty parts and labor should it ever fail again though. That means I can lower it too and not worry about the added stress
    9. #7
      Aug 2016
      San Diego, CA
      Pics of the shift knob!
      2005 Volvo V50 T5 AWD M66 (2017 - ) || 1987 Toyota MR2 (2016 - ) || 2002 Lexus IS300 (2016 - ) || 2005 Volvo S40 T5 AWD M66 (2016 - 2019) || 2008 Volvo V50 T5 (2015 - 2016) || 2001 Acura Integra GSR (2010 - 2010) Stolen lol
    10. #8
      Mar 2011
    11. #9
      Mar 2011
      This is my next project...fabrication of this air intake
    12. #10
      Mar 2011
      You'll notice that's a R engine. This is Heicos HS4 Odin s40
    13. #11
      Mar 2011
      This is where I'm at. Would be a simple design if the air didn't have to go up and over this piece of frame. It's thin gauge but is shaped to be rigid. I'm no structural engineer so I don't know how crucial it actually is. I could easily cut this square out with a wheel saw
    14. #12
      Jan 2010
      Dahlonega, GA
      I'm working on something VERY similar for my Injen intake. I've been planning on cutting that part out, but I'm curious to see what you come up with.
    15. #13
      Mar 2011
      Aerodynamically it makes sense to remove it. I understand the reason it's curled over at the top...to make it rigid. I may consider cutting a rectangle out if the glass surface some air can pass thru and the rest can flow over the top.
    16. #14
      Mar 2011
      Looks like polestar beat me to it. Time to get cutting
    17. #15
      Mar 2011
      Real Cold Air step 1
    18. #16
    19. #17
      Member V50R's Avatar
      Nov 2014
      Rochester Hills MI
      Ha.... looks like i found another project for my V50... time to look for an intake>
      2010 XC90 V8 Executive R-Design Exhaust (MINE)
      2008 XC90 V8 Executive Edition, fully loaded, 177k, STOCK (MOMS)
      2008 XC90 V8 Executive Edition, NAV, DVDs, 152k, STOCk (DADS)
      2005 XC90 V8 Black, VB replaced, (SIBLINGs) S60R Brake Swaped
      2007 XC90 V8 Dark Grey BASE MODEL 85k STOCK
      2013 GOLF Sportwagen GTD 6spd. Malone S2+ tuned 192fwhp/343fwtq.
      2013 Audi A4 Quattro. APR S2, DP, IC, E85 Tune 330hp/410tq.
      SOLD:: 2006 V50 T5 AWD AW55, 320mm FR Brake upgrade, Elevate Intake, OBX Exhaust_
    20. #18
      Mar 2011
      Odin II is now a fastback
    21. #19
      Mar 2011
      So I realize that true cold air is a negligible difference. What this should do is greatly increase airflow and lower under the hood temps. I ordered a water-(resistant) pre filter from Outerwears. It was the only company I found that makes one in yellow. I pulled the passenger side axel. Not as easy as MNIWT videos make it look. I had to drop the LCA and loosen the oil lines or whatever lines those are that block removing the lca bolt. Took the axel to CVJ and they said it was too messed up to repair. I guess what they do is cut if off and weld a new joint on. So now I ordered one from FCP Euro that has their lifetime warranty. Jacked up the car as far as I could on one side and didn't lose a drop of transmission fluid.
    22. #20
      Mar 2011
      Installed the do88 intercooler and got the cv axel installed. Front bumper is back on. I haven't driven the car in over a month. Smooth like glass on the highway now, no vibration. Also got a new windshield. So clear, you don't even notice it's there!
    23. #21
      Mar 2011
      Also re-painted all the engine bay pieces, and the hood strut.
    24. #22
      Mar 2011
      Replacing the R design trim with what I think is called Bright Aluminum. I still need to find rear door handles that match. I have to take the center console back out to access the screws for the waterfall. If anyone knows where I can find rear door handles in this color let me know. It's definitely different than brushed aluminum.
      '10 s40 m66 awd
      '12 c30
    25. #23
      Mar 2011
      Got the Bright Silver trim installed. Also mounted my iphone7+. I purposely bought a case with a belt holster for this purpose. I used a folding drywall anchor to secure it to the ac vent. I also just finished removing the rear seat, since the only passenger is my dog. Now there's the problem of the center seat bracket which is not removable and I think it's definitely dangerous for the dog. I have a solution in mind. Going out to the store now.
      '10 s40 m66 awd
      '12 c30
    26. #24
      Mar 2011
      Grill is done. Ready for install.
      '10 s40 m66 awd
      '12 c30
    27. #25
      Mar 2011
      Grill is in!
      '10 s40 m66 awd
      '12 c30
    28. #26
      Jan 2010
      Dahlonega, GA
      I really love the way that looks! Are you going to make a funnel between the opening and the cutout in your bumper to the filter?
      Also, any tips on how you cut out that section of bumper? I got out the cutting wheel and then got worried about where all the sparks would be flying...
    29. #27
      Oct 2012
      Lembeek, Belgium
      You can put a small mesh to keep most of the little rocks/bugs/water droplets away from your filter, while retaining the airflow.
      quick sketch in paint, cause photoshop is still not installed on my new workstation
      Also take a look at aircon ducting etc, you can find some square/rectangular tubing that'll fit the hole.
      Ice White V50 2.4 D5 Progression Thread:
      https://forums.swedespeed.com/showthr...-4-D5-R-Design
      Titanium Grey V50 2.0D Progression Thread:
      https://forums.swedespeed.com/showthr...ression-Thread
    30. #28
      Mar 2011
      I'm not sure that it actually needs ducting. As for the rain I was driving in extreme downpour with no grill at all and it was fine. I didn't use a cutting wheel because I was also worried about sparks. Hand saw was the way to go. Cut like butter, 5 minutes total. My only concern was once I folded the metal down, I didn't want the edges cutting the coolant lines so I put weather stripping on those surfaces.
      '10 s40 m66 awd
      '12 c30
    31. #29
      Jan 2010
      Dahlonega, GA
      Lucky for me, I don't have coolant lines there.
      Thanks! Hand saw it is.
      If water really is of concern, Injen has a hydro shield cover for the filter. My filter has gotten misted with the cover on and it remains dry underneath.
    32. #30
      Mar 2011
      I have a hydro shield on my cone filter. It does bead off rain drops, but i tested it in the sink and it fails miserably. Where do your coolant lines go?
      '10 s40 m66 awd
      '12 c30
    33. #31
      Member Slasher's Avatar
      Oct 2010
      New Jersey
      Quote Originally Posted by thefisch33 View Post
      Grill is in!
      '10 s40 m66 awd
      '12 c30
      awesome.
      2006 V50 T5 AWD M66: 19" Heico's w/ Hankook & ISC Coilovers
      IPD TCV, skidplate VIVA CBV, Prosport boost & AFR gauges, 6000k hid
      ELEVATE: Turbo Pipe, RSB, autotech III, body kit, intake. IC piping
      EST: grille, Exhaust, DP, BELL FMIC Streetunit trans mount.
    34. #32
      Oct 2010
      New Jersey
      Quote Originally Posted by LeemansJ View Post
      love this. well done sir.
    35. #33
      Jan 2010
      Dahlonega, GA
      Because my reservoir is on the driver's side, the lines don't have to cross over the top of the radiator.
    36. #34
      Mar 2011
      I went out to high plains raceway over the weekend. I rode shotgun a few laps in a c7 corvette to get a feel for the track. An Audi TT lost a wheel on the main straight. The damage was moderate. The driver suspects the plastic hub ring melted, however the TT is bolt centric, so the bolts were taking the load and ended up shearing off, destroying the wheel in the process. Needless to say, I just ordered metal hub centric rings. http://us.hubcentric-rings.com
      '10 s40 m66 awd
      '12 c30
    37. #35
      Aluminum lug nuts probably. No good!
      Garage Queen - 2010 C30 R-Design Vrooooooom
      Daily - 2016 V60 T5 Drive-E Vrooooooom
      Zichrona Livracha - 2004.5 S40 T5
    38. Remove Advertisements
