What did you do to your wagon today? - Page 197
    Page 197 of 223 FirstFirst ... 97 147 187 193 194 195 196 197 198 199 200 201 207 ... LastLast
    Results 6,861 to 6,895 of 7779
    1. #6861
      Member Exocet's Avatar
      Nov 2017
      Southern Tier NY
      Quote Originally Posted by ScottishBrick View Post
      The turbo 6 starts as 2.8, an under bored 3.0. Then it became lower pressure and 83mm bore. They were limited by the absolute trash 4T65 gm sourced transmission. an 81mm bore 6 with a big single can make 600+ hp. Naturally we didnt get that in any production cars.
      Frame rail spacing is for safety, besides the R's p2s have killer turning radius, at least mine does?
      I always wondered what potential there was in the 6. But, if the transmission was crap, I can see why it was never developed much beyond what it was.
      I had always heard that the P2 frame rail spacing was driven by the desire to accommodate the 6.
      It's sad when my crew cab, long bed truck has about the same turn radius as my V70.
      2007 Volvo V70 2.5T - Mine
      2008 Nissan Titan SE 4x4, Crew Cab, Long Bed - Also Mine
      2012 Toyota Camry LE, 2.4 - Wife's
      2003 Mazda Protege5, 2.0 - Daughter #1
      2010 Mazda 6 Grand Touring, 2.5 - Daughter #2
      Aug 2017
      Northern New Jersey
      I completed some pre Vermont trip repairs and maintenance on the 02 XC. Started with a passenger front axle, front brake pads and pass engine mount, installed new style PS reservoir and hose(No more leak!!),
      oil change, B4 servo cover and trans drain and fill(old style cover, washer just fell out!!),VIDA TCM adaptation, new wiper blades and adjusted the arms, and finally mounted the roof box for the snowboards.
      Quite a busy day, but start to finish with a few breaks and dealing with customers took about 5 hours
      2006 V50 T5 AWD Black(The Wifes)
      2002 V70XC Dark Blue(Mine)
    4. #6863
      Senior Member ScottishBrick's Avatar
      Dec 2014
      Connecticut
      Quote Originally Posted by Exocet View Post
      What steering stops are you using? My 03 has about a 20 foot turning circle
      2003 V70 T5 - Mystic/Graphite - M56LK - 206k - K24/Greens/Do88/Quaife/SMF/P2R Clutch/DW300C/H&R/Bilstein TC/316mm & 308mm Brakes - SteveO Tuned
      1999 V70 T5 - Pewter/R Graphite & Alcantara - AW42 - 299k - Daily/Work Wagon
      1999 V70 T5 - Nautic/R Graphite & Alcantara - M56H - 177k - Rescued
      1999 V70 T5 - Emerald/Graphite - M56H - 119k - Garage Queen
      2000 V70 T5 - Mystic/Graphite - AW42 - 243k - Moms Unicorn
      2000 S70 GLT SE- Mystic/Graphite - AW42 - 218k - Sisters
      SwedeSpeed.com
      Nov 2017
      Southern Tier NY
      Whatever is used for the 235/45-17 wheel/tire combo. They are black, IIRC. And things still rub, worse now that it's lowered. Even the 215/55-16 winter setup rubs slightly.
    7. #6865
      Senior Member ZZZZZZZ's Avatar
      Aug 2005
      Northern MD
      One massive benefit of daily driving the XC: THIS. Stark difference. Stark.
      "The Real IPD" - ZZZZZZZ's thread
      2007 Passion Red/Gobi VRgt; 2005 Silver/Beige Leather S60 2.5T AWD; 2002 Silver/Off black leather V70XC
      Past: 1999 Tropic Blue/Green/Oak leather V70 (NAa); Mom traded 1975 Maroon/Maroon leather 164E
    8. #6866
      Dec 2014
      Connecticut
      Hmm. Were running the same exact wheels (your summers) but im running a 225 width. No rub even lowered and your exact springs were on my car at one point. How much front camber are you running? Orrrrrr actually does your wagon have the steel lower control arms that start in 07?
    9. #6867
      Nov 2017
      Southern Tier NY
      Steel LCAs.
    10. #6868
      Dec 2014
      Connecticut
      Steel LCAs.
      Hm. Well that may be the difference then. How ambitious are you about a subframe swap? IIRC you dont have delrin subframe bushings yet?
    11. #6869
      Nov 2017
      Southern Tier NY
      Not that ambitious, unless a manual transmission swap ever happens. Then, I'll have so much money sunk into that, that I won't want too spend anymore anyway. I thought the only LCA difference was on the ball joint end, not in how they mounted to the subframe. But, I've never seen the two side by side.
    12. #6870
      Dec 2016
      Hamilton
      Some time ago I replaced driver side mirror assy. Needless to say, I have a wandering non heated mirror. Is there anything in VIDA I can do to Ďreprogramí the car so it accepts donor mirror and functions properly. Though I could live with it as is, in $hitty weather the mirror is not dry and is unusable.
      As an aside, for those in Canada and primarily in GTHA (Toronto area) volvo of Toronto has really reduces their prices up to 15% to 20%. As my AOC pump bass started crunching at startup, I picked up an OEM about $370 CAD. Much better that about $500 quotes at other dealership.
      Thanks and cheers.
    13. #6871
      Dec 2014
      Connecticut
      Quote Originally Posted by Oliovlov View Post
      Some time ago I replaced driver side mirror assy. Needless to say, I have a wandering non heated mirror. Is there anything in VIDA I can do to Ďreprogramí the car so it accepts donor mirror and functions properly. Though I could live with it as is but Iím $hitty weather the mirror is not dry and is unusable.
      Thanks and cheers.
      What year did the new mirror come from? Needs to be on the same side of the 05 split as your car.
    14. #6872
      Member Antherzoll's Avatar
      Dec 2013
      Toronto
      Thanks and cheers.
      Great price!
      2005 XC70 Crystal Green | Hilton | 16T | Bad Swede | 145k mi
    15. #6873
      Dec 2016
      Hamilton
      Same 2004. Same side. Thought it would have been drop in but alas ...
    16. #6874
      Dec 2016
      Hamilton
      Quote Originally Posted by Antherzoll View Post
      Great price!
      ever the fluid and filter is better price comparatively...
    17. #6875
      Dec 2014
      Connecticut
      Somethings funky then.
    18. #6876
      Dec 2016
      Hamilton
      Ok good to know. Maybe the mirror is just crap ... wasnít tested beforehand but I was told was good.
      Also it was free so ...
    19. #6877
      Member Racer_S's Avatar
      Jan 2011
      Ithaca, NY
      Replaced the windshield on my 03 after a cargo mishap.
      Roof was started to rust along the leading edge and Safelite refused to do the install because of that. Ended up doing it myself after some minor rust repair.
      Cut down some silver S60 trim pieces I had laying around to fit the XC70. The old ones were crumbling to nothing.
      Sorry no before photos.
      2004 XC70 2.5T AWD Crystal Green Pearl/Charcoal [240K] Mud Guards, 05- Wiper Arms, 305mm brake upgrade, Full LED Exterior, 1-inch lift Pic
      2003 XC70 2.5T AWD Silver/Charcoal [190K] XeMODeX, Mud Guards, 05- Wiper Arms, LED Headlights
      2004 S80 2.5T AWD Crystal Green Pearl/Light Sand [240K] Bi-Xenon, LED Foglights, 07 Turbo and rear diff
    20. #6878
      Apr 2017
      Seattle, WA
      Hit 120k in the T5M
      2001 V70 T5M Mistral Green/Graphite
    21. #6879
      Nov 2017
      Southern Tier NY
      Started prepping the V70 for a road trip this morning in the sunny 14 deg weather. Topped fluids as necessary. Then, decided to check the LF inner CV on the axle I just swapped. Reached in to find more grease than expected. Hmmm. Not feeling the boot clamp. WTF? Get a flashlight for a better look. Sure enough, inner boot clamp MIA. Boot still on the inner cage, which was good. So, it popped off sometime in the past 3 days. No big screw clamps around for a temporary fix. A less than 30 minute fix, if I had the time. Parking the V70 and taking the Camry I guess.
    22. #6880
      Member zmarshm1's Avatar
      Mar 2019
      Binghamton NY
      Man you canít catch a break the past month
      ||1998 s70 t5m - Stock, future gambler 500 car | 140k? miles
      ||2001 v70 t5 - IPD Sway bars | Delrin subframe bushings | Transmission cooler & mounted inline filter | Rostra long snout transmission solenoids | IPD catback exhaust & Rolling Motors 3" downpipe | Simota Carbon Charge Intake | Bilstein B4 & Eibach prokit lowering springs | 124k mi
      ||2003 v70 2.4t - First volvo | SOLD! Still driving around with 190k+ miles.
      Kanjo!!
    23. #6881
      Nov 2017
      Southern Tier NY
      Quote Originally Posted by zmarshm1 View Post
      Well, putting the original axles back in appears to have eliminated the vibrations when accelerating. So, that's good.
    24. #6882
      Aug 2005
      Northern MD
      But no Nokians back on yet, right? I love mine on both cars. Waiting for Presidentsí Day sale.
    25. #6883
      Nov 2017
      Southern Tier NY
      Quote Originally Posted by ZZZZZZZ View Post
      Not in the middle of the winter. I figure I'll get to them at some point.
    26. #6884
      Jan 2020
      De
      So it turns out that when you cut off 1/2" of material and retap a new hole that 2012 kia sorento roof rails fit a xc70
      Sent from my SM-G900V using Tapatalk
    27. #6885
      Feb 2020
      CA, USA. But English.
      Saturday the two tailgate struts I ordered two days previously arrived. Looked on YT on how to replace the ones that were shot, took about twenty minutes to do. Fiddly part was the little clips on the ball joints. I discovered a little switch on a length of coiled cable under the rear fuse box; I wondered if perhaps it was to turn on/off the parking sensors? It seems to be wired into the rear left lighting cluster.
    28. #6886
      Global Moderator R-Pow3R3d's Avatar
      Apr 2015
      Pittsburgh, PA
      Quote Originally Posted by Brit_Steve View Post
      This is on my list of things to do, as well.
      Walked out to use the 06 XC70 yesterday only to find one of the crappy old Mastercraft tires, that it came to me with, nearly flat. Decided it wasn't worth bothering with and ordered new Nokian eNTYRE 2.0's.
      Worked today on getting the new-to-me 07 XC70 up to speed. Part of the negotiation on the car involved a vibration under acceleration (and also when sitting still). First thing to address was the very failed upper and lower torque mounts (replaced today). The driver's seat panel was broken, as usual, so I replaced that item. I removed the 1" cabin filter (which was shockingly clean) and replaced it with a 1.5" activated filter. I was going to replace the engine air filter, but it looked basically new. In the last few miles of my several hundred mile drive home from picking the car up, I got an incredibly brief and intermittent "No Oil Pressure" message. The car was very due for an oil change and the last filter change was done at a quick lube using conventional oil and a non-OEM filter. I decided to add some Seafoam to the oil, then took it out and ran it good and hard for about 20 minutes. I drove it back home and then immediately dropped the oil. It was super dirty, thin, and brown. Of course, adding some fun to the adventure, I had to use an impact wrench to remove the oil filter housing. I started off with my cheapo 3/8" drive filter wrench and the filter wrench broke. I switched to my "Heavy Duty" 1/2" drive filter wrench and after applying full torque finally got it free. I replaced the housing, in case it had been ruined. I'm going to run some short intervals, with Seafoam at the end of each, to try and clean out the system. We'll see if dropping the oil pan ends up needing done.
      Coming up soon will be replacing the droopy sun visor and tailgate struts.
      2004 V70R MT TiGray/Nordkap - Replica 18" Pegs - Handbrake Mod
      2007 XC90 V8 Sport Passion Red/Off-Black - Serpentine Belt, Tensioner & Idler Pulleys - Spark Plug Replacement - Y-Pipe Replacement
      1990 745 Turbo Intercooler White/Beige
      2007 XC70
      VIDA/DICE Owner - SS Lurker Since 2009 - '06-'07 Transmission Valve Body Info - SR/VR Failing Throttle Body
      Current Non-Volvo: 2007 VTX 1800 F3, 2002 VT750DC
      Previous: 2006 S60R
    29. #6887
      Member
      Apr 2013
      Toronto, Canada
      Had two DIM lights go out last week, fiddling with them caused another to go out too...Decided it would be interesting to see if I could get my '04 "executive" DIM to play nice in my '02 XC...nope, now I've got no lighting on bottom displays AND a yellow exclamation mark (presumably suggesting that someone screwed with the DIM). Nothing VIDA can't clear, I'm sure but for reference, an '04 DIM won't work in an '02 even though plugs are compatible.
      2010 V70 3.2 125,000miles
      2002 V70XC, 175,000 miles
      2004 S60 2.5T, 160,000 miles
    30. #6888
      Apr 2015
      Pittsburgh, PA
      Quote Originally Posted by R-Pow3R3d View Post
      ...droopy sun visor...
      Got this swapped today. Couldn't have been much easier. Also replaced the missing door lock bushings on both the 06 & 07. Tailgate struts will have to be another day.
      Also began the interior deep cleaning process on the 07. Vacuuming and scrubbing and vacuuming and scrubbing. At least all the interior plastics and buttons look clean now.
      Edit: When I got the 07 I noticed the windshield (original) is very worn (like the windshield wipers were run when it was dirty and dry). In certain lights it's pretty annoying to look through. Definitely livable, but not ideal. Looked up my auto insurance coverage and found a $250 glass deductible. Got the thought; I wonder what it would cost to have Volvo "Blue Box" glass shipped to me from an online Volvo parts dealer. Well, several of the common names we're familiar with put that shipping cost at >$250 (the same amount as the cost of the glass). BUT....I found one who quoted shipping at ~$30 and was offering a 15% coupon code. I added the glass, plus the Volvo adhesive kit, and checked out for $290. Now, time will tell if they actually honor this or not. I wouldn't be surprised if they will not, but I figured it was worth a shot. Fingers crossed!
      2007 XC70
      Previous: 2006 S60R
    31. #6889
      Dec 2014
      Connecticut
      Quote Originally Posted by bigtimemcalpine View Post
      Annoyingly the DIMs are only 03+ compatible
    32. #6890
      Dec 2013
      Toronto
      For my Canadian brothers.
      Pennzoil Platinum Euro LX 0w30 is on sale at CT for $32.99ea. That's $27 off regular. Sale ends today!
      Pennzoil also has a $10 rebate on 5L
      https://www.pennzoil.com/en_ca/promo...S9PMTkwNi9jYS8
      $22.99/5L for some great oil!
      Been told that it's rebranded Sheel Hilux and is a heavy 0w30, but check it.
      https://www.ato24.de/en/blog/compari...30-engine-oils
      Cheers!
    33. #6891
      Dec 2016
      Hamilton
      Iím somewhat leery of 0w- for these engines. My buddy ran 0W-40 and spun a bearing so I stay with 5W or 10W.
      Just superstition I suppose ...
    34. #6892
      Dec 2016
      Hamilton
      Also, part source has Total on sale for 50% off. Itís quartz 9000
    35. #6893
      Apr 2007
      Nashville
      I've run 0W-40 in 7 different white blocks over the course of 6 years, absolutely zero issues. I think your buddies car was just going to spin a bearing no matter what oil was in it.
      On topic: I put in those Osram nigh breaker bulbs in the ABL's and they are wonderfully bright. Don't have a standard bulb comparison, but I can tell a big difference in output. For $150 I should right?
      Also installed GROM3 unit because FM radio was killing me.
      04 V70R Flash Green/Atacama6MT
    36. #6894
      Dec 2013
      Toronto
      I've been running 0w40 for years. This 0w30 is on the heavy end so I don't feel worried using it.
    37. #6895
      Dec 2014
      Connecticut
      The (#)W doesn't really matter except at cold start. Lower numbers mean better flow when its at freezing or below. The W(#) is viscosity at boiling point of water and most likely where your friend spun a bearing. Were i a betting man i would say he was 3/4 of a quart low and was running an engine that had not had the oil pickup tube updated or oil pickup system o rings refreshed.
    38. Remove Advertisements
