Difference between Variant 3 & Variant 4 Motors....
    Results 1 to 7 of 7
      Oct 2004
      What yields the extra 18 hp for the R models? It is bigger exhaust, more boost, larger turbo? Since both models share the same torque rating, I assume both motors run the same turbo.
      Thanks,
      Jason
      Variant 3: 2.3L inline 5 turbo, 222 SAE net hp, 221 SAE net ft./lbs. – 4-speed automatic
      Variant 4: 2.3L inline 5 turbo, 240 SAE net hp, 221 SAE net ft./lbs. – 4-speed automatic
      Senior Member JRL's Avatar
      Apr 2003
      Devon PA
      Re: Difference between Variant 3 & Variant 4 Motors.... (mans442)
      Another great queston, and personally I would like to know for my own edification
      As much as I fool around with Volvos I never bothered to find out why .
      My GUESS would be different electronics, a slight bump in boost, all of the above, etc.
      JRL
      Email: jrl1194 ( at ) AOL (dot) com
      2007 V70 2.5T White/Oak/Tan/Arena, 114K miles. My DD with no plans to sell it anytime soon
      2000 V70R, Wife's, she won't sell. Now she hit 150,000 miles and still near perfect!
      Member Kaizai's Avatar
      Mar 2002
      Sebastopol, CA
      Re: Difference between Variant 3 & Variant 4 Motors.... (JRL)
      All the hardware is the same, the only difference is ECU tuning from the factory. IPD upgrades both to the same output with their aftermarket ECU.
      The real reason to get an R is the seats, wheels, spoilers.
      His: 2011 Nissan Leaf - No Gas... Just Electrons...
      For Sale: 2007 S80 V8 AWD
      Hers: 2010 XC70 T6 AWD
      SwedeSpeed.com
      Junior Member andrewclee's Avatar
      May 2004
      I believe the only difference is the ECU, which allows more RPM's at WOT for like an extra few seconds.
    7. #5
      I've heard that the R engines have a better balanced rotating assembly and a slightly different head. How accurate is this info? No idea.
    8. #6
      Mar 2002
      Sebastopol, CA
      Re: (andrewclee)
      Quote, originally posted by andrewclee »
      Actually the boost is different, the RPM's are the same.
    9. #7
      Senior Member Ate50Ar's Avatar
      Jan 2004
      they are basically the same motor, where the varient stops making power...the varient 4 will continues to build power via more boost. Varient3:[email protected], varient 4:[email protected]
      they both run the 15G Turbo., high-end is where you feel the differance. however, since they are basically the same engine, a ECU upgrade(IPD) will give you the same HP #'s in either car....35HP increase on the varient 4 & 53HP increase on the varient 3...which makes 275HP in either.
    10. Remove Advertisements
