JaredR's Yellow 1995 850 T-5R Estate progression thread - Page 32
    Page 32 of 33 FirstFirst ... 22 28 29 30 31 32 33 LastLast
    Results 1,086 to 1,120 of 1147
    1. #1086
      Nov 2003
      New Brunswick, NJ
      JaredR: will let you know if i find the 850 articles in my automotive archives. recently went on a cleaning binge and threw out a bunch of stuff, but pretty sure kept the 850 stuff. If i find any of them will let you know.
      The Ferrita on my N/A car has a low pleasant (g)rumble up to about 60-65, above that it gets a little loud for loooong trips. Anything beyond 1+ hours @ >65 becomes annoying. By now Im sure whatever sound deadening Ferrita put in the resonator and muffler is long gone.
      1994 850 wagon 5spd N/A
      2007 V50 T5 AWD 6spd
      Senior Member JaredR's Avatar
      Jan 2014
      Boston, MA
      Quote Originally Posted by davidw View Post
      Sounds good! looking forward to any findings in your archives!
      Ha, 1 hour would be a very short trip for me in this car. I've been driving it around more locally so far this season but that's mostly been because I'm trying to figure out the brake issues, and also because it's the only estate car we have in service at the moment and I've needed to move some stuff recently. 2018-2019 I took it out a total of 26 times times, which totaled up to about 7k miles. My average destinations over that span were over 130 miles away from home!
      1995 850 T-5R Estate. AW50-42LE. Cream Yellow/Graphite. 297k.
      1997 850R Estate. B5234T9/M66D. Bright Red/Graphite. 270k.
      2007 S60 T5. M66W. Black Sapphire/Arena. 140k.
      Instagram: Jared's Volvo Page
      Dad: 1997 V70 T5 SE. AW50-42LE. Frost Green/Oak. 212k.Mom: NEW! 1999 S70 GLT Pewter/Oak. 101k. Past: 2004 V70 NA. AW55-50SN Ruby Red/Tan 269k. Sold to markj
    4. #1088
      Nov 2003
      New Brunswick, NJ
      I found 3 articles. EuropeanCar July 2003, Rolling Nov/Dec 2004, and Grassroots Motorsports, unofotunately no date, but my guess would be 99 or 00. I can scan and email to you if you are interested.
      Jan 2014
      Boston, MA
      That would be awesome. PM incoming...
    7. #1090
      Jan 2014
      Boston, MA
      EBC pads out, Hella Pagid in.
      That's about 500 miles worth of dust from the EBC pads. Absolutely bonkers. I thought Hawk HPS was dusty. And that includes about 150 miles on the highway of absolutely zero brake use.
      Cleaned my wheels so we can get an idea how dusty the Pagid pads are.
      Got in some new LEDs. Supposedly 9,000 lumens per bulb........not sure I buy that lol but H1 Halogen is 1,450 so it'd have to be WAY lacking to not be a massive improvement.
      Uh oh. That's not gonna work. This is the high beam, which is at a wack angle in the ECE housing, so I need to be able to rotate it. This clearly is not going to work here.
      Luckily, I have access to many files 👍
      Since I already had this housing out, I decided I'd just try both in the same housing and see how they do in the lows.
      Early results are very promising......I'll break out the D700 tonight for further comparison......
    8. #1091
      EBC yellows are a fairly aggressive pad for even spirited street driving. What made you choose those over reds?
    9. #1092
      Jan 2014
      Boston, MA
      Quote Originally Posted by Clarkson'sWagon View Post
      I would use Volvo/ATE over any ceramic pad. These cars are grossly underbraked as built and need aggressive pads, so ceramic is not even a consideration for me. Even slow cars need great brakes. I could jut be cruising down to the grocery store (well, ok, I don't go to the grocery store anymore, but you get the idea) at 31 in a 30 and have some clown pull out in front of me. My dad's NA has 302s and is getting Hawk HPS......
      The stopping power of the EBC yellows was acceptable. The fact that they felt like they were going to shake my rear suspension apart was not. I could overlook the dust if not for that.
    10. #1093
      Jan 2014
      Boston, MA
      update:
    11. #1094
      Member sventastic's Avatar
      Nov 2013
      British Columbia
      That looks like solid light output. What halogens do you have in there now? That yellow is nasty
      1996 854R | M56H | 16T | 268k
    12. #1095
      Jan 2014
      Boston, MA
      Quote Originally Posted by sventastic View Post
      Osram I think
    13. #1096
      It's strange that they were causing that much vibration.
    14. #1097
      Jan 2014
      Boston, MA
      297k.
      Gave the Pagid pads a few drives to break in and they just weren't impressing me with their stopping power. So I took the S70 for drive with the ATE pads and realized the Pagids were straight up depressing. Had enough of this experiment and put the Hawks in.
      Yeah I don't get it. It was really bad. Like I was driving over a rumble strip bad. Didn't come back with the Pagids but I only ran them for about 20 miles. Have about 70 miles lined up tomorrow so that should be plenty to make sure the Hawks are good to go.
    15. #1098
      Member CYB3RBYTE's Avatar
      Oct 2016
      Milwaukee, WI
      Did you have pagid fronts as well? I was going to buy them...
      In the Garage
      Viveka / 1996 850 N/A, Polar White + Oak / 135,5xx /
      Quicksilver / 2011 C30 T5 M66 / Silver Metallic + Off Black / 91,6xx
    16. #1099
      Jan 2014
      Boston, MA
      Quote Originally Posted by CYB3RBYTE View Post
      Yeah, Pagid all around. Not recommended. Get Volvo/ATE all around.
    17. #1100
      Jan 2014
      Boston, MA
      Vibration is back with the Hawks . Thinking my calipers might be unhappy about being opened up all the way for the new pads.
    18. #1101
      Junior Member TG850T5R's Avatar
      Jun 2004
      Seattle, WA
      Jared, My car did the very same thing after I painted the rear calipers and got some paint on the rotors. Try cleaning the rotors on both sides and see if that fixes the problem.
      You would think that pads will eventually clean them real good but that wasn't the case on my car.
      Volvoless in Seattle……………
      Yellow 854 T-5R - 42K miles
    19. #1102
      Jan 2014
      Boston, MA
      Quote Originally Posted by TG850T5R View Post
      What did you clean them with? Brake cleaner? or something abrasive? Definitely could be worth a shot. Rotor surface looks clean on the outside but who knows how much of the story that is really telling me.
    20. #1103
      Jun 2004
      Seattle, WA
      I sanded them down by hand real good.
    21. #1104
      Jan 2014
      Boston, MA
      I'll give that a shot. Hmm.....I wonder if the rotors are contaminated from the EBC break in compound......that would be the only thing i can think of.
    22. #1105
      Did you compare all 4 pads when you removed them? IE: port inner and outer and stbd inner and outer?
    23. #1106
      Jan 2014
      Boston, MA
      They all looked really bad. I wasn't feeling a problem from the port side today so I have left it alone. Only felt it once with the EBC pads but it was so bad from stbd in that instance that I'm not confident it wasn't just vibration transferring across the delta link.
      I put the previous rotor back in to see if that resolves the situation. I couldn't feel a problem, but I could see what looked like chatter marks on the rotor. I sanded that down too so if this works I'll throw it back in and see what happens. And I have reman calipers on order now........so whatever the problem is, it's getting fixed. The EBC pads also might not be dead yet.....once this is solved I'd like to do a better comparison between them and the Hawks. At least I am getting really fast at doing rear brakes. LOL.
    24. #1107
      Did you give the calipers a good bleed? Pads and rotors aside, chatter in a hydraulic system can be attributed by air. ABS fault is another thing but I doubt that could be only happening in the rear unless there is a mechanical fault at the distribution block.
    25. #1108
      Jan 2014
      Boston, MA
      I bled that caliper when I attempted to replace it (new caliper has pistons that weren't machined flat wtf so I had to abandon). Could try that again but it was fine before the pad replacement and started with the EBC pads before I touched the line, so I doubt that is the issue......unless it's possible that this issue has been present all along and the previous pads just weren't bothered by it. I was thinking caliper because I had to open it up farther than it had been open before to get the new pads in, but Ted's idea definitely seemed worth exploring given the disaster than the break in compound appeared to be creating.
      850s have three channel ABS so (or at least 96+ does......never had a -95 ABS system apart so not really sure what's in there but it's certainly at least two channel) so it's theoretically possible that it could be an ABS issue, but the car is not showing any ABS faults so I don't think that's the issue. This also doesn't feel like ABS intervention.
    26. #1109
      Hmmm. Well, now you got me frustrated trying to figure out what it is. While I do enjoy trouble shooting...it proves difficult via the web.
    27. #1110
      Jan 2014
      Boston, MA
      Honestly probably not a lot more difficult than in person with this problem LOL. Did 7 miles dropping some stuff at the mailbox today and so far so good. Need an excuse for a few more miles now lol.
    28. #1111
      7 miles!? Boy, you have a long driveway! Ha.
      1980 242 - Weinrot/141 4-speed - First car
      1995 855 - Ruby Red Met./454 5-speed - One owner with rod-knock
      1996 854 - Pearl White Platinum/424 Automatic - Daily
    29. #1112
      Jan 2014
      Boston, MA
      Mailman came crazy early today so I had to go to their place 🤷*♂️
      I wouldn't mind a 7 mile driveway though LOL
    30. #1113
      Aug 2005
      Northern MD
    31. #1114
      Jan 2014
      Boston, MA
      Yeah that's been for sale for a while.
    32. #1115
      Junior Member Saffron-R's Avatar
      Aug 2008
      Portland, Oregon
      It’s been listed on the Hemmings site for at least a year, I believe. Not that I have an iota if interest, but I wonder what it would end up costing to get the car here and registered?
    33. #1116
      Oct 2014
      Quote Originally Posted by Saffron-R View Post
      With broker fees, import taxes, shipping and misc port charges and custom fees. . Over 6k in fees( if buying for that price). when I was trying to running numbers last year and looking at different price ranges from different countries to import from. It's the import tax that gets all over the place because it's based on your buying price.
    34. #1117
      Jan 2014
      Boston, MA
      Got some cassettes to try out for today's adventure. I've been told by people who know WAY more about sound systems than I do that the original Pro Logic system in these cars was designed for tape, which makes a lot of sense given where tech was at the time. The sound was quite good, too, even with everything set in the middle with the stock V70 soundstage, with MUCH less distortion than I get from CDs or the Grom. I ended up turning up the treble just a tiny bit to get the sound I wanted, with everything else still set in the middle. I found the impact on the surround sound particularly remarkable; it was clearly working as intended even with it set in the middle, whereas I usually turn it all the way, up or close to it, to get the sound I am looking for from digital formats.
      But then my heater hoses decided my cooling system refresh I had planned for this weekend after I got the remaining parts today to do cooling system/turbo/head-back exhaust all in one shot wasn't quite soon enough. So doing a little more refreshing than I had planned. Oh well, knew it needed to happen someday anyway so one more thing I can cross off the list of future projects 👍
      Oil thinned down so much from the heat that it was coming out despite there being no particular oil leak. I didn't realize there was a problem for probably about 15 miles since the engine was getting air cooled on the highway at 75 and the low coolant light never illuminated. I initially thought it was an oil problem when the low oil pressure light started flickering on the exit ramp, so I killed the engine mid corner on the ramp and coasted into a driveway just down the street from the ramp. I was super confused when I got out and discovered that there was no coolant......until I realized what had happened and that the turbo had probably way overheated the oil and thinned it down to nothing.
      The oil looks hardly any thicker than water, and this car had a consumption problem on 5w30.... There was a LOT of very thin oil in the IC hoses.
      cyl 2 and 3 super toast everything else still 130-150.
      Head off. Headed off to Carlquist for a refresh. Also FµCK working on -95s. Nobody should ever buy one if it's not yellow. This is absolutely insane the way these engine bays are put together. There are bolts in this exhaust system that I legit cannot remove. Idk I guess you need some kind of special tools to remove the DP? There is not enough space for a socket or any kind of wrench that I have to get on some of the nuts. And why is there a bracket attaching the DP to the block? Had to cut that off with a hacksaw because I couldn't unscrew any of the fasteners. Oh and the best one was the exhaust manifold stud that I couldn't unscrew because there was an EGR port in the way. Took me like like twice as long to figure out how to get this head off as it should usually take since every usual option was littered with opstacles.
    35. #1118
      Indy, IN
      Well, that escalated quickly.
      '97 854 T5 & '97 855 GLT(RN LPT swap/16T/302's/ETC) (wife's)
      '78 264 (Future Whiteblock/T5 swap)
    36. #1119
      Nov 2002
      Russell Twp, OH
      So what happened here - blown head gasket, overheated due to loss of coolant, burnt valve, or some combination of the above?
    37. #1120
      Most likely deck lifted on 2 & 3.
