JaredR's 1997 850R Estate progression thread - Page 16
    Page 16 of 17 FirstFirst ... 6 12 13 14 15 16 17 LastLast
    Results 526 to 560 of 588
    1. #526
      Junior Member raivis_rsn's Avatar
      Latvia
      850 interior with proper black 901. Mmm.. just do it!
      But if you think that 901 without Dolby is pointless, then you're wrong. It has several unique features - Radio Text, equalizer, 3-CD and diversity antenna system. There were configurations with 901 but without Dolby. That head unit was ahead of its time.
      Dolby unit makes full premium sound experience but 901 alone still has very nice package with features.
      1999 V70 D5252T M56 - Nautic Blue/Graphite
      Senior Member JaredR's Avatar
      Jan 2014
      Boston, MA
      Quote Originally Posted by raivis_rsn View Post
      That's certainly true, I just meant from a perspective of what it would make sense for Volvo to offer. I doubt very many people with 850s were looking to upgrade to a SC-901 in the '90s.
      Regardless, I'm getting excited for some black face 901s!
      1995 850 T-5R Estate. AW50-42LE. Cream Yellow/Graphite. 296k.
      1997 850R Estate. RN/M66D. Bright Red/Graphite. 270k.
      2007 S60 T5. M66W. Black Sapphire/Arena. 138k.
      Dad: 1997 V70 T5 SE. AW50-42LE. Frost Green/Oak. 212k.Mom: NEW! 1999 S70 GLT Pewter/Oak. 100k. Past: 2004 V70 NA. AW55-50SN Ruby Red/Tan 269k. Sold to markj
    4. #528
      Jul 2015
      Charlotte, NC
      Yeah, I really like the 901 in my old GLT without the Dolby speaker/processor. But it's definitely better with it!
      2000 V70R Venetian Red/Charcoal M56 Swapped 195k
      2003 S60 2.4T Silver/Black 112k
      2000 S70 GLT Silver/Taupe 253k
      1991 944 Turbo B230FT/AW70 173k
      1992 245 some of a B230F/AW70 249k
      1993 944 B230F/AW71L 221k
      2007 XC90 V8 AWD Sport Titanium Grey/Black 165k
      Sold-
      1998 V70 GLT Black/Beige 193k
      1998 S90- Silver/Gray 207k
      1995 850 GLT Tropic Green... crushed
      2001 S60 2.4T Black/Black 230k
      1988 744 Turbo M46 Beige Metallic/Beige 188k
      Need used parts? PM me!
      Jan 2014
      Boston, MA
      After a bit of testing, the RN and N coolant temp sensors definitely don't read the same. Either need to make an adapter to install the N sensor in the RN thermostat housing or repot the thermistor from the N sensor into the RN sensor. Certainly would be cleaner to do the latter.
    7. #530
      Jan 2014
      Boston, MA
      Gutted the electronics out of the RN temp sensor.
    8. #531
      Indy, IN
      Any reason you don't just use the N thermostat housing? (Not sure if I missed something earlier in the thread)
      '97 854 T5 & '97 855 GLT(RN LPT swap/16T/ETC) (wife's)
      '78 264 (Future Whiteblock/T5 swap)
    9. #532
      Jan 2014
      Boston, MA
      Quote Originally Posted by Chuck W View Post
      Yeah, it is missing a PCV fitting for the RN PCV. Most people do it the other way around and make the N PCV and intake manifold fit the RN engine. That has its own subset of problems that are more well documented.
      Basically I'm taking the opposite approach and making the car fit the engine instead of the engine fit the car. Ultimately it'll be a better way to do it since now I'm getting all of the upgrades instead of just some of them. This build has been a bumpy ride since it's a new way of doing it as far as I'm aware. My friend Zach who bought my white 850R wants to do a lower budget version of this build in a couple years, so we'll get to find out how cleanly it goes together the second time around on that project. If we build the new setup on another subframe out of the car like I did here, I bet we have the whole project ready to send to Ben/Bobby/Steve for the electrical work and tuning in a weekend or two.
    10. #533
      Indy, IN
      Oh yeah, that.
      Our swap kept the N intake because I wasn't in the mood to mech throttle the RN intake. We've had zero PVC issues with the PTC PCV mod.
    11. #534
      Jan 2014
      Boston, MA
      Would be cool if this car had a coolant reservoir.
      Even with the ribs bent in it was still super bouncy. Needed a second support point.
      Hey look! No holes in the car!
      Still a little bit bit of undamped vibration on the outboard side. I'll probably stuff some rubber or something under the bracket between the lip and the strut tower to try to kill that. Also need to paint in 609 at some point.
      On to the throttle linkage. Needed to be about 15" long lol. Copper wire had a hook in the left end so I just hooked the ball on the throttle body and marked where the ball on the throttle actuator was to get the length. And, as usual, I̶ ̶w̶a̶s̶ ̶t̶r̶y̶i̶n̶g̶ ̶t̶o̶ ̶m̶a̶k̶e̶ ̶t̶h̶e̶ ̶p̶r̶o̶j̶e̶c̶t̶ ̶a̶s̶ ̶e̶x̶p̶e̶n̶s̶i̶v̶e̶ ̶a̶s̶ ̶p̶o̶s̶s̶i̶b̶l̶e̶ the only thing I had on hand to do anything with was some bronze rod, so I just brazed that on to the existing ends. I had two throttle linkages on hand and used the adjustable end on both ends because brazing to a rod with a piece of fixed plastic on it was definitely going to work out a little too hot lol.
      Overall it doesn't seem as insane as I hand anticipated.
      Fits perfect, works as intended.
      This now leaves me with the coolant temp sensor as the only remaining solution. Decided that I am really not comfortable with having to make a custom coolant temp sensor for this car so I am going to solve the problem the right way. Fortunately, the 03+ thermostat housing has a huge amount of material surrounding the coolant temp sensor, so I can just bore that out and throw a sleeve in there that I can tap with the proper thread to screw in the 850 ECT sensor. I will need a patch harness to extend the original harness as it is too short with it in that position but that is pretty easy. Also have to do some minor disassembly to get the thermostat housing out again but even with that it still seems like the best and simplest solution. 99-02 housing for comparison, with less material to bore out.
    12. #535
      Aug 2005
      Northern MD
      If you do bring this to Carlisle, park next to the same one but 100% stock if possible. I’d love to look left and right and left again to see these side by side. So cool.
    13. #536
      Jan 2014
      Boston, MA
      I'll just park next to myself lol. If all goes to plan, I might have 2or 3 cars there this year. We'll see how the next few months play out.
    14. #537
      Jul 2015
      Charlotte, NC
      Very nice work! I like the throttle setup.
      Sold-
    15. #538
      Latvia
      That body is incredibly clean. Red has never looked so good.
    16. #539
      Jan 2014
      Boston, MA
      Thought I was going to wrap up the front brakes today but things are not going to plan with the front brake lines
      However I did get the rear calipers painted so hopefully I will get the mess up front sorted out this week and move on to the rear end. Hopefully. Lol.
    17. #540
      Jan 2014
      Boston, MA
      Decided I should put the rest of my brakes together even if I am having brake line challenges.
      Hawk HPS has been discontinued for P80 front caliper (bought from 3 places got 3 refunds lol) so I'm trying the Pagid pads since they have been good on P2 and they were too cheap not to give them a shot (and from FCP so warranty).
      Hmm next up this should be fun.
    18. #541
      Jul 2015
      Charlotte, NC
      I have Pagid pads on the rear of my R, no complaints!
      There's something about new brake components that just looks good good... the painted calipers and brackets are just icing on the cake!
      Sold-
    19. #542
      Latvia
      Aren't there any aftermarket handbrake shoes that would be worth buying?
    20. #543
      Jan 2014
      Boston, MA
      Nope. I would get ATE if I could. I've had aftermarket handbrake shoes delaminate in storage awaiting use!
    21. #544
      Member SonicBlueR's Avatar
      Jun 2010
      Newtown, CT
      Yeah there’s none. Aftermarket ones don’t even fit right.
      06 Sonic/Nordkap MT SR with 18" Anthracite Pegs |63K Miles
      00 Laser/Charcoal 2 Tone AT VR 16" Anthracite Satellites/ 17" Pegs |201K Miles
      99 S70 N/A
    22. #545
      Junior Member nick_rabbo's Avatar
      Dec 2009
      Dallas/Fort Worth
      Brakes look delicious!
      Sent from my ONEPLUS A5000 using Tapatalk
      2004 Volvo S60R - SOLD - Elevate Body Kit, Tune, Downpipe and Exhaust, Snabb Intake.
      1997 Volvo 850R - 130K - 16t Angled, R Manifold, Maximizer OBX Downpipe and Exhaust, Snabb Intake, Snabb FMIC, Blue Injectors, Beust/Vast Tune, 302mm BBK, CherryTurbo Strutbrace, Do88 Silicone Hoses (All), Koni Sports Front & Rear, IPS Sways, H&R Springs, H&R rear 20mm spacers, Nokian zLine A/S 215/45/17. (Soon to be installed: S90 MAF, Quaife LSD, 7+7 hybrid K24, DW 900cc Injectors, DW200 Pump, e85. Then I'm done, I promise. Maybe.)
    23. #546
      Jan 2014
      Boston, MA
      Knocked out a couple annoying issues tonight.
      As you may recall there was an issue with coolant lines all fitting together. Well the correct one surfaced in a early 01 V70 T5 at the JY a couple months ago. Problem solved.
      The brake line on the other side got super messed up with the approach I took there so I did this one the right way. Look hard enough you can see the brake line smoking in the first picture lol. Need to hit the JY to get another line for the other side.
    24. #547
      Junior Member Flat467's Avatar
      May 2015
      Lancaster
      That's the same coolant line I replaced recently! Well different engine and coolant line config, but same in principle!
      I wish I used crimping hose clamps...thankfully I had a lift, I couldn't have done it on my back...
      All that work to clean the engine bay and no love given to the wheel wells...and to think this is my inspiration for my R hahaha kidding, of course!
      Present:
      '87 240 DL - 177k -
      '97 855R - ???k work in progress
      Past:
      '94 855 Turbo
      '95 854 Base
      '95 854 T-5R
      '00 V70 R
    25. #548
      Jan 2014
      Boston, MA
      Quote Originally Posted by Flat467 View Post
      Oetiker clamps are flames. I think a lot of working on your back is a mindset thing. Once you're there it's not that bad. Fresh sheet of cardboard and it's soft and clean. Almost like working on a car in bed. Lol.
      I could clean the wheel wells but I'm sure I'll drive this thing in the wet so kinda pointless.
    26. #549
      Jan 2014
      Boston, MA
      Let's try this again
    27. #550
      Jan 2014
      Boston, MA
      Brake line situation has been resolved.
      That'll be the last JY trip I have time for for a couple months so I reorganized back into the home toolbox too
    28. #551
      Nov 2002
      Russell Twp, OH
      Are you replacing those struts?
    29. #552
      Jan 2014
      Boston, MA
      Quote Originally Posted by Wayne T5 View Post
      Yeah so that kinda got complicated. Was supposed to be putting the Öhlins in but getting those rebuilt is turning out to be more complicated than anticipated so I'm going to just throw in fresh Sachs for now.
    30. #553
      Dec 2009
      Dallas/Fort Worth
      Noice steel lines.
      I don't think I ever did the small rears, did you?
    31. #554
      Jan 2014
      Boston, MA
      Quote Originally Posted by nick_rabbo View Post
      Noice steel lines.
      I haven't touched the rear yet.
    32. #555
      Junior Member Zoinks's Avatar
      Jul 2018
      Milwaukee, WI
      I've tried multiple times to get my front lines off to not even a bit of success. Flare wrenches, PB blaster, mild heat nothing helped. And it seems the PO also tried so the hard line flare nut is nearly stripped
      That's a good looking tool box layout too. . . I need to find a cheap metal one on craigslist one of these days
      1998 V70R Mystic Silver/Graphite
      1996 RN Swapped 854R Bright Red/Graphite
      Past:
      1998 V70 NA/m Classic Red/Light Gray
    33. #556
      Jul 2015
      Charlotte, NC
      Just gonna throw in that I just replaced my front hoses on my '91 940 the other day, came off like butter!
      Sold-
    34. #557
      Member sventastic's Avatar
      Nov 2013
      British Columbia
      Quote Originally Posted by Zoinks View Post
      Where are they seized? At the caliper end and the hard line too? When I first did my brakes a few years ago I had to cut a rear hard line and reflare it, and replace the caliper because I couldn't get the hard line out of it.
      1996 854R | M56H | 16T | 266k
    35. #558
      Jul 2018
      Milwaukee, WI
      Quote Originally Posted by sventastic View Post
      Caliper end comes off easy, at the hard line is where I'm getting issues.
      Past:
    36. #559
      May 2015
      Lancaster
      Question concerning this;
      What is Ohlins? haha
      Sachs was the OEM provider of the Nivomats in the Volvo 850R, correct? Nivomats, or self-leveling suspension on the 850R, are only present on the rear suspension, correct? The front suspension on the 850R is not self leveling, correct? Therefore any front strut assembly can be used, i.e. an 850R's front suspension wouldn't require an OEM equipment delete like the rear requires a nivomat delete process.
      How would you compare Sach's front strut assembly to the Bilstein Touring Struts? What makes you choose one of the other? right quality, build quality, price point?
      Present:
      '87 240 DL - 177k -
      Past:
      '94 855 Turbo
      '95 854 Base
      '95 854 T-5R
      '00 V70 R
    37. #560
      Jul 2015
      Charlotte, NC
      Ohlins made upgraded dampers which were an available option for P80s from Volvo. Very rare option.
      Sold-
