Shaving the Engine Bay
    Page 1 of 21 1 2 3 4 5 11 ... LastLast
    Results 1 to 35 of 729
      Member boostednbagged's Avatar
      Jul 2010
      East Ohio
      not doing a full shave just yet (probably should have during the build) but i want to clean it up as much as i can get to now.
      AC is already ripped out, vacuum brake boost pump is gone, ripped out the stock cloth firewall and am installing that gold heat shield stuff, and am removing all the stock crap wire looms to do everything up in heat shrink wrap stuff.
      its gonna be a pita but if i can remove most the unused wires, cut the wiring harness thickness down by half, and tuck as much as possible, it will be one sweet looking engine bay.
      my question is what else can i dump?
      what about this ~1/2" vacuum line with some sort of valve that goes from pre turbo intake to the intake manifold then has a thin hard plastic line running somewhere for fuel? what exactly does that do?
      what about the PCV system? i am also installing a catch can and would like to just vent to atmosphere and avoid the whole pre turbo heating element and stuff, but what is the part of it that connects under the intake manifold - to the breather box - to the coolant housing on the head? whats the point of that?
      ill be posting pics in my build thread along the way and thanks for the help!!
      Member Hounddogger's Avatar
      Oct 2014
      Northern
      That brake pump serves an important purpose. And the car will be angry with it gone.
      Exponents kill
      Elsa: 2004 V70R Silver Metallic&Nordkap Back from Valhalla @ 357,098 miles
      Jul 2010
      East Ohio
      Quote Originally Posted by Hounddogger View Post
      really? because i read a lot of people unplugged theirs when they go bad instead of replacing them and never noticed a difference. it is just there to assist the brake booster when the engine is cold and doesnt have full vacuum.
      SwedeSpeed.com
      Senior Member JRL's Avatar
      Apr 2003
      Devon PA
      Under certain (vacuum) situations, you WILL notice the lack of vacuum!!! (big time, like no brakes)
      Email: jrl1194 ( at ) AOL (dot) com
      2007 V70 2.5T White/Oak/Tan/Arena, 114K miles. My DD with no plans to sell it anytime soon
      2000 V70R, Wife's, she won't sell. Now she hit 150,000 miles and still near perfect!
    7. #5
      Oct 2014
      Northern
      Quote Originally Posted by JRL View Post
      Creating a hill under boost and hitting the brakes you'll notice.
      Exponents kill
    8. #6
      Member StealthyS60R's Avatar
      Feb 2010
      Trinidad, CO
      LOL, I'm not sure what wires in that loom are optional since its every one is required for a running engine.
      Just clean up what you got, there is nothing 'extra' in there for you to get rid of.
      Also, that extra line you speak of is for the EVAP system. Check the check valves to make sure they are still working since when both fail they will create boost and vacuum leaks. Don't get rid of it unless you always want a check engine light for a EVAP system failure.
    9. #7
    10. #8
      Member SonicBlueR's Avatar
      Jun 2010
      Newtown, CT
      Tony if you take the wire harness off for the injectors it'll really clean up your cam cover.
      06 Sonic/Nordkap MT SR with 18" Anthracite Pegs |63K Miles
      00 Laser/Charcoal 2 Tone AT VR 16" Anthracite Satellites/ 17" Pegs |201K Miles
      99 S70 N/A
    11. #9
      Junior Member taloras's Avatar
      Feb 2015
      PDX
      Quote Originally Posted by SonicBlueR View Post
      The OTE pipe is also unsightly and can be removed.
      2004 Moose Longroof Go-Fast Row-It-Yourself
    12. #10
      Jul 2010
      East Ohio
      Quote Originally Posted by StealthyS60R View Post
      ill deal with the CEL later. if i cant run it hidden i will remove the evap can and vent the gas tank to atmosphere.
      the wiring harness is FULL of wire that arent needed. think about how many different cars this wire harness was used for across the world. i know of at least 5 visible plugs that are in the engine bay not doing sh*t. plus just by stripping the plastic loom off and doing a shrink tubing wrap will save a TON of room and make it look SO much cleaner.
      i dont think you guys understand the look i am going for
    13. #11
      Oct 2014
      Northern
      And every one of those cars is identical... Volvo's ME7 harness was used on 5 cylinder ME7 cars... Which are all identical... Only plugs that wouldn't be connected are lighting related.
      Exponents kill
    14. #12
      Jul 2010
      East Ohio
      it will be less brakes, but not NO brakes.
      cars have been running fine without evap and vacuum boost systems for decades. ill be just fine
    15. #13
      Jul 2010
      East Ohio
      wiring for the AC, this vacuum pump, lighting, power steering (once i remove that), the 4C system, etc.
      there are PLENTY of wires i can remove lol
    16. #14
      Oct 2014
      Northern
      Quote Originally Posted by mullen1120 View Post
      Uhhhhhh you really don't want to drive an R without power steering. Seriously. Ever. It's not fun, it doesn't get easier with speed.
      Exponents kill
    17. #15
      Feb 2010
      Trinidad, CO
      So you think that power wire for the A/C is really bulking up that harness? Dude, you are going off the deep on a fools errand. What is there to see about the evap system, it lives UNDER the intake manifold so unless you have x-ray vision I don't see why this is a problem for your sense of aesthetic.
      Think about the fact that you have 15 wires for the coils, 10 for the injectors, 6 for the cam sensors, 4 for the CVVT solenoids, 3 for the crank sensor, 4 for the knock sensors, over 10 for the O2 sensors and a giant power cable going to the starter and alternator. Add a few more for the evap solenoid and oil pressure sensor and that's the bulk of what's running around your engine compartment.
      So which of those do you plan on ditching for some crazy idea?
      The bulk of all this runs along the subframe where no one can see it so why is this such an issue?
    18. #16
      Member CKAVolvo's Avatar
      Dec 2009
      Healdsburg
      NEVER valet park your car. I know with the Enem cams I have to remember on start up = pedal to the floor.
      2006 V70R Black GT 377 awhp TME Exhaust, Girodisc 2 piece rotors IPD Sway bars, HD end links, Strut Brace, Poly engine mounts EST CAI, Silicone hose kits, SNABB intake, IPD HO coils,Enem Y21, CamsRaceS60R FMIC,Majestic Hybrid Turbo, HFS-4 water meth ElectronicsSPA digital Boost/EGT, ScanGauge II, Bel STiR ,Laser Interceptor HD front jammer, Mobileye collision avoidance system , LED interior lighting, ImiV, 2 USB, AARP member,
    19. #17
      Member BaxtR's Avatar
      May 2014
      Tampa,FL
      id like to see this when its finished. dont let these old fart's discourage you (i do like you old farts for the record or else i wouldnt be here)
      2007 S60R Nordkap & Black Sapphire Metallic. Auto. Holset HY35, 2.3 Block shimmed, Forged pistons, H-Beam Rods. 3" DP, Meth Inj.
    20. #18
      Oct 2014
      Northern
      It's gonna be a while till I remove the power steering but I've driven plenty of cars without it and I don't see why the R would be any different. You must have little girl arms lol.
      And you guys are very confused on the brakes. I'm not removing the booster.
      If I was running cams then I could see keeping the vacuum pump. But other than that the Car really doesn't need it.
      Sent from my VS986 using Tapatalk
      Oh there have been times that pump is helpful. If you shove the clutch in on boost and slam on the brakes you'll want that pump.
      As for the power steering it's almost impossible to turn the wheel without it.
      Exponents kill
    21. #19
      Nov 2014
      Central Oregon, US
      I think you're on the wrong forum for this sort of thing...
      I think you're missing the point of shaving an engine bay. The point isn't to eliminate "unnecessary" components (like AC or power steering), but to cleverly route them in a neat, organized fashion. This is a difficult vehicle to achieve that with. You should maybe consider why some people haven't done this yet. Just because it's different doesn't make it a good idea.
      Do what you like, but if you ask a forum for answers, especially one like this with many learned people, don't disregard information provided with snarky remarks.
    22. #20
      Jul 2010
      East Ohio
      To me it is unecessary. I drive this car maybe 1,000 miles a year. After this it'll be the interior and roll cage time.
      I think you are missing the point. I'm turning this R into a show car. I could give 2 fu*ks about AC and other "luxury features"
      So, now that we have that aside, y'all can stop telling me how hard the wheels will be to turn without power steering and help me with what I need to do to remove things
    23. #21
      Jul 2010
      East Ohio
      Anyone have a diagram on the evap canister system?
    24. #22
      May 2014
      Tampa,FL
      i think vida does.. im not home atm or else id go on and check :P
    25. #23
      Oct 2014
      Northern
      Ask ScottishBrick what his ME7 harness looks like. He has a complete one from a 99 T5M. Aside from the extra CVVT solenoid and grounds being in a different location they're pretty identical. That should give you an idea of what can go.
      I still think leaving power steering would be smart. Moving 2 235+ wide tires with all the weight on them is not fun without power steering.
      Exponents kill
    26. #24
      Jun 2010
      Newtown, CT
      I don't understand why you would sleeve the motor and put a big turbo on it if your not even gunna drive it..
      And why when you had the motor apart you didn't even clean it up that much or powder coat things like mine 😄
      99 S70 N/A
    27. #25
      Jul 2010
      East Ohio
      I'll prob end up keeping it. See if I can't get the pump mounted where the AC compressor used to be. That would work perfectly.
    28. #26
      Jul 2011
      Madeira Beach, Fl
      Haters gonna hate. Let this guy do his thing.
      05 SR 6M Sport Ti/Atacama 18 inch pegs -purc 4/1/11... OBX turbo back and K&N, Snabb FMIC and intake pipe,Ipd upper/lower, IPD strut tower conv .
    29. #27
      Jul 2010
      East Ohio
      I should have. But I wasn't planning on going this far then.
    30. #28
      Member n23's Avatar
      May 2009
      Tampa, FL
      I don't understand shaving the engine bay, although I do like a neat and clean bay. I don't get ridiculous, hilarious camber. I don't get people urinating on their hoods to get that sweet rust look.
      But hey, it's your car. As long as you aren't violating your local inspections (or, like FL, have none) and aren't a safety hazard on the road, who am I to disagree?
      Even if it's phenomenally stupid. Personally I think it's a troll on the similar level to dougy's improvised hood scoop.
    31. #29
      Jul 2010
      East Ohio
      I love the look. Go to H2Oi or SoWO and you'll understand
    32. #30
      Feb 2010
      Trinidad, CO
      Quote Originally Posted by n23 View Post
      ^ This. If someone asks for my input I give it, even if its that their idea sucks.
      I would never go as far as saying he shouldn't be posting this here though, to each their own after all and its their property and money to do with whatever they desire.
    33. #31
      Feb 2015
      PDX
      People have been driving for decades without power steering in cars with steering racks designed for no power assist (no hydraulics, higher ratios, less caster). Doing it with a car/rack designed for power assist is another matter entirely.
    34. #32
      Jul 2010
      East Ohio
      Quote Originally Posted by taloras View Post
      This is a good point.
    35. #33
      Feb 2010
      Trinidad, CO
      He should test his theory by getting up to speed on some twisties and shutting off the engine to see what its really like. It might actually cure him of this crazy idea.
    36. #34
      Oct 2014
      Northern
      Had a boost hose pop off at 20-30mph... car stalled. Honestly didn't expect it to be that bad... But it was.
      Exponents kill
    37. #35
      Jul 2010
      East Ohio
      No power steering is actually better for handling.
    38. Remove Advertisements
