Towing with 04 v70 2.5t - hitch & towing suggestions
    Results 1 to 2 of 2
      Dec 2010
      Hi I am considering hauling a Uhaul 5x10 trailer (3000 lbs) about 2100 miles with my v70 2.5t and looking for help.
      I need to get across country and need to move my car and some stuff.
      - Hitches ( looking at Reese and Curt)
      - Transmission cooler ?
      - What other concerns (ie dont do it).
      The car has 150k and always had factory recommended service (timing belt, radiator, synthetic oil every 4k) and a totally redone suspension w/ Bilsteins @ 100k.
      Any suggestions regarding towing (including warnings) and such would be welcome.
      Thanks!!
      Member Antherzoll's Avatar
      Dec 2013
      Toronto
      Here's a cut and paste to a response I sent over PM recently.
      Quote Originally Posted by Antherzoll
      Ordered these two parts from hitchweb.com
      If you need 2" you can buy an adapter
      Install is a breeze, 6 bolts that are already tapped into the frame. Just need to remove the rear tow hook. Wiring harness is straight forward.
      I installed a Hayned/B&M transmission cooler and a Magifine inline filter, and perform regular fluid changes, which I strongly recommend.
      http://www.volvoxc.com/forums/showth...ion-Cooler-Kit
      Also upgraded the front brakes, but that isn't necessary.
      My trailer is 1000lbs unload. We usually load all of our gear into, (mind you my XC is approx. 300hp, 336ft/lb). I've towed this trailer almost clean across the country, besides the extra room needed for stopping the XC handles it very well.
      Sent from my LG-H815 using Tapatalk
      Also if needed, I had to purchase a set of tow mirrors for my XC as the trailer is quite wide. Bought a set from Milenco, while pricy they perform very well. They stay firm in place, and the reflection is quite stable.
      http://www.milenco.com/products/mirr...towing-mirror/
      One additional suggestion. Keep the transmission in low gear when acellerating or climbing hills.
